nod
Everything posted by nod
Both ok He’s very cheap on the K rend Thats about what I pay the renderers that work for me and I supply a pump and van 2 coats if he’s not spraying it Ask to see his last two jobs Lots of plasters out there that will be happy to practice on your house
We have eight SS in the bedrooms landing etc We are unlikely to use them But when we have tested them They don’t run hot from a HP The same radiators ran very hot from a gas boiler on our previous build You would have to use them like UFH man’s let them heat up slowly and let the thermostat keep the temperature within a couple of degrees of what you want Our upstairs tracks the ground floor UFH by about 1 degree less Same as our previous
Hollow out door porcelain tile, no movement
nod replied to Oxdale's topic in Landscaping, Decking & Patios
NO -
Decommissioning an old brick septic tank - DIY or not?
nod replied to jumbletons's topic in Waste & Sewerage
Only empty mine every five years -
Straight on a field or mixed in with his silage Not that I’d do this -
Boiling water tap - Quooker alternatives
nod replied to canalsiderenovation's topic in General Plumbing
I don’t sorry I may have spelt it wrong also I can ask -
Sorry read it all But I’m installing a TP for a neighbor on Saturday and decommissioning there’s which is on my land It’s 3 meter square I’ll get the farmer to suck it out Then fill two thirds with clay Compact with the digger Put a layer of hardcore in the 300 mil of topsoil Then grass over -
A friend has a insincuted boiling tap It went wrong after two years and they replaced it free of charge a cup of tea tastes the same out of his boiling tap as ours £350 -
A ballpark figure is around £2500 m2 for an extension Builders won’t do a detailed quote for something you might be doing next year But there are builders that will do a detailed quote for a fee 500-750
Self adhesive window film is quick and cheap
I think they make the prices and discounts up as they go We where quoted 55k supply only plus vat from one of the main players Which we couldn’t justify for windows Shop around I put a post on on Thursday showing a door frame combination That has cost 90k I’ve had to pull the Ally clad trim off one side where the strips lights are going as it’s all I’ve the place Your better with your joiner fitting the windows
BUS grant: what evidence to qualify ?
nod replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
If you pay it You will never see it again Part of why they charge so much is because of waiting for grant money to come through The two guys that did mine take alternate Tuesdays off sorting the BUS grants out -
Some will tell you yes The difference with ours was just under 5k for a 11 KW Mitsubishi Cylinder pumps buffer control panel and commissioning my UFH instal I couldn’t buy the equipment in for 5k I did try
Once the contractor had finished the installation We where sent a questionnaire from the MCS Asking if we where satisfied and happy for the Buzz grant to be paid directly to the contractor
Unfortunately it’s one or the other Contractors with a grant Or self install No grant
You can’t on a level threshold You will have to go either side
I think it’s planning consultant code
VAT on empty property
nod replied to HAIGHY's topic in Self Build VAT, Community Infrastructure Levy (CIL), S106 & Tax
Until recently when HMRC brought in the end user to apply to vat You wouldn’t have been given as clear of an answer as Temps 👏 -
Probably depends on the finish TF would obviously be more like 60-40 But it would be quite easy to break down into percentages
Our neighbor has been granted planning for a leisure building Lots of restrictions No one to live or stay overnight I would imagine that if they moved there sons in it would be very difficult to enforce But could never be sold as a dwelling
Just to add Build to watertight Then to completion has come out as 50-50
Most on here will have detailed spreadsheets Which it would be quite easy to make up a pie chart from
Oh god House builders bible 😂😂😂😂😂
