MikeSharp01
    16
  1. Refer her/him to the BCO drawings and package you sent them with email confirmation then sit tight!
  2. Welcome to THE forum for people like us.
  3. Seems wrong to have mini as 'a second car' they are such fun.
  4. Is it an Olympic size pool - 700m2 is 3 tennis courts!
  5. How do they may them so cheap? Wonder if that 3OA relay really is?
  6. Yep - it happens to be one of my biggest challenges, while thinking is not a bad thing it sometimes helps to be shaken out of it, so thanks!
  7. On the other hand - like too many things I stick my nose into this challenge is expanding greatly and I need to learn to control the levels of detail a bit better. While doing the 'what do / does current systems do.' I hit this problem; Stepping out from just counting pulses we have energy monitoring and stepping out from that we have energy / cost minimising. When you get out here the path back to pulse counting is obscured by many other factors. So, for instance, we - well some of us, could start to live our lives 12 hours out phase. This would level out demand and flatten prices and I need not worry so much about how much I use. We might extend this idea and in combination with others we can see that living our lives looking ahead based on; the 30 minute import / export tariffs, what our food preferences are, how much sun we are expecting & when and what's in the fridge the system might work out a good recipe (or small selection of same) and give instructions as to when to cook it. So now in designing my pulse counter I need also to agree how it will fit with all these other futures. Not to mention how to deal with export and the various flashing behaviours of meters from different suppliers when export happens. My head hurts!
  8. Well its basically ready, but I have sort of expanded it a bit to make the block do much more than just log the meter but also manage DHT22s and the like. I have not managed to get the RTC working reliably so have switched over to NTP, as @Radian, suggested. I have sort of written up the first, discover / define (Does/Should), part and am about to start testing the whole system, then I will publish and be damned.
  9. Just read that thread and it struck me that you might be able to calibrate 'waste' by synching up your measurements with the meter readings, assuming you have access to your 30 minute IN/OUT readings, over a period of hours or even days just to get a feel for it. It looks like the Joule bucket is not constant for all makes thus challenging assumptions on how your system works but if you could work it out then it's another shareable commodity. Finally it is possible to infer one of two things from the thread: that either commercial units don't care about the occasional mismatch or that they know something you (and the other thread members) don't. I know where I stand on that one.
  10. How far in advance does one get the tarrif from Octapus?
  11. But you do have Buildhub - although non commercial loads of people come here to get great ideas. I have been thinking along the same lines about how the market we are in sees the UK as treasure island. If its going to be sold direct in the UK the price will be X while elsewhere you can get it at X-significant chunk of money and because importing is not well understood people don' do it. Some of it is about our lack of the 'delayed gratification' Gene but I suspect most of it is about being uncertain when buying from France / Germany / China direct what the admin needs are. Basically none really, although that may change if we put up barriers. What is needed to get EMC compliance signed off these days - big grey box no use here I suppose? This might be worth a read: https://www.ul.com/insights/ten-things-know-successful-smart-home-product-launch from UL, one of the bigger test houses so watch for bias, but not all about just EMC.
  12. Perhaps because they don't think things through so as to get the intended consequences by intervening in the right place(s) in correct proportion. They make no use of cause/effect analysis or systems thinking of any type so no wonder things don't go the way intended. Markets are highly predictable on the surface much less so below and they create socio-technological gaps where innovation, of all sorts, can thrive.
  13. I did keep them but sadly have thrown them away in a clearout last year. One had a blown relay the other just stopped showing anything on the screen and if the wedded bliss is to be maintained its straight down to screwfix and get another without worrying about why it's bust.
  14. Two of ours have - the current (no pun intended) one seems to be standing up to the load though.
  15. Welcome to THE forum for people like us.
  16. This is getting very unstable, and for many it must be very stressful, and you must consider the possibility of wide scale revolt unless someone gets a grip - the question will be positive or negative grip as getting it wrong will perhaps lead to a very difficult situation.
  17. Octopus not taking on new clients for this yet, I tried last week. They say we should stick with our current supplier, EDF, but I figure that if I install the PV now, about a year to go until occupation, I could get some income as we only use a couple of kWh a week on site.
  18. Keep the basket from your old one and try both. We would not go back to basket as the top self idea is great. As above, load the tray in groups throw the serving spoons / carving knives etc in the other side and Bosch its all done ready to be taken out and put into its various places.
  19. The RCCB must be doing it? Would just current measuring the earth return on the consumer unit not be a good proxy. Fluke have a good article on it https://www.fluke.com/en-gb/learn/blog/clamps/leakage-current-measurement-basics
  20. Can you not measure and log the leakage current and see what's going on as you bring the breakers in. If it trips immediately does that not suggest something starting up oddly rather than staying odd.
  21. We have a similar problem - the fibre runs the other side of the road and comes up a pole opposite us and into our neighbours opposite. Our side of the road, 8m, is not destined to be fibred until next year. Bonkers.
  22. Yes - you could demonstrate it in a biscuit tin if you wanted to!
  23. We used Helifix Inskew helical nails, you can drive them in with and SDS drill, they come in all sorts of length and they don't pull out! However the also do not pull in very well. So with our vertical battening we screwed the vertical (counter) battens on using long stainless screws at 600mm centres to get them tight against the insulation then Inskew'ed them as the Helifix spec (240mm IIRC.
  24. Yes as long as you block the UV I would have thought it would last well.
  25. Is that going to last well outside in the driving sun that is West Kent these days - or is it too shady to ever be a problem?
