MikeSharp01
    16
  1. We have the AFT raft system and very good it is as was the service we received - shame all round.
  2. People get confused about small nuclear and tend to say "they have them in nuclear submarines so why not take that technology and pop it into ships" - sounds like a fair plan until you realise that the fuel for these subs is weapons grade (95% enriched) to reduce / remove refuelling demands to 30 years plus - refuelling less highly enriched 10-20% is very complex and expensive needing specialist facilities. We have limitations treaties on the fuel so that's a limiting factor as well. Also many countries do not allow nuclear powered ships to dock for safety reasons, you need greater security for the ship when travelling and much better trained crews.
  3. Sounds like your system is open to the main sewer, have you got a dry trap somewhere - washing machine for instance or maybe an air admittance valve (AAV) is stuck and your loo flushes are sucking a trap dry.
  4. Seems rather crude just to screw into a casing, might be more robustly done with rivnuts or some such.
  5. Do you run your systems automatically, manually or semi manually. I guess I can see how you could 'mess up' in manual mode but how might you 'mess up' in the other two?
  6. Pretty much sums it up! So are all the walls in your place interactive so you can live in this psychedelic paradise you have prompted into existance- reminds me a bit of a scene from the Ipcress file - @SteamyTea will no doubt find it and add it to this thread.
  7. No, well that might be where the rest of us are. Here is my summary: You started with using local LLMs to develop some automation, tried to recreate 'Alexa' or some such and had some success doing it but you got taken over by the need swell your memory so you handle even more billions of weights etc then got involved in multi modal stuff and games development and now you are lost up the Orinoco without any memory of the journey or the objective - so essentially without a paddle!
  8. Seems to me that you are so far off Piste that you have taken to asking Claude to create new Pistes for you to play in. Just give us a catchup on what you are are actually trying to achieve so we can get some context without pasting all 17 pages into Claud only to have it tell us that its been working on this with you but it has no clue where it might all end up.
  9. We perhaps need to find some common ground here so we can identify the aspects we can agree on and then discuss the things we don't - this is usually (still) a good basis for discourse and otherwise we are contributing to the death of nuance and increasing polarisation which gets us nowhere. All it does is improve our ability to throw language laden bricks into the opposing camp. So to kick this off perhaps: Can we agree that the planet is warming up whatever the cause? If we are able to agree at least that we can perhaps then discuss consequences, mitigation strategies and opportunities it brings. Only after that we can discuss evidence for causal factors, natural cycles, human activity, adjustments by the operators of the simulation we are all living in - the science, or otherwise, of what is happening.
  10. If you think it through the answer must be that it does not. If you watch a toddler you can see the principle at work - they are happy operationalise, they understand it, although they perhaps cannot explain it. It only takes an inspirational teacher in a school to expolain it and suddenly its clear what the method is. Make an Observation: Identify an event or ask a question about the natural world that requires an explanation. (Can I climb this hill thing [stair]?) Form a Hypothesis: Propose a testable, educated guess or plausible answer to your question. (Let's see) Conduct an Experiment: Design a controlled test to see if the hypothesis holds true under specific conditions. (One step , crawl climb of whatever) Analyse the Data: Examine the results gathered from the experiment to determine patterns or trends. (Yep I am at the top / nope I have hit something that stops me - the stair gate!) Draw a Conclusion: Decide whether the evidence supports or rejects the hypothesis. If rejected, the hypothesis is modified and the process restarts. (I can climb / I need to modify my approach and try when the stair gate has been left open.) To operationalise it in any field of advanced research does need a lot more education and experience - that I agree, but not the scientific method itself - that is child's play!
  11. Wow - that's some landscaping - its been so long since one has seen so many terraces in a design- looks great and once it has grown in it will look amazing. Until the epilogue then.....
  12. Dialogue is always a good approach and one thing this place has taught me is that there are often ideas out there that have not hit your consciousness and this thread is an example. It has saved me about £200 in 6mm cable and a lot of working pulling cables through ducts and along trays - so its a win for me. I do need to build a bit of infrastructure to mount the switches but otherwise its a winner. Thanks all.
  13. I could put them in the cupboard below the ovens - the one above would be too high up, would that work? The hob is on the island along with the kitchen ring.
  14. The 'interior designer' has persuaded me to locate the isolators for the ovens on the kitchen island so they do not break up the aesthetic of the oven wall. These would be 1.4m from the Ovens across the gangway from the wall with the ovens. Each oven has a max draw of 3600W so 7.2kW with both on full power. Each of the two ovens will have there own 32A isolator in the Consumer Unit (CU), To achieve the run it ends up as a lot of 6mm cable: CU - Island (12m) & Island - Oven (15m) I am going to have 27m run (Voltage drop 3.5V approx), none in insulation but in duct and trunking. [I would need only 5m of 6mm cable if the switches were local to the ovens] So for these two ovens I will need just over 50m of cable which in itself is not a problem but I thought I would get a sanity check here to be sure I am not breaking any rules doing this - it looks OK to me regs wise. Any thoughts - should I push back on the interior designer?
  15. If your contractor has set up a water supply for the site from your connection point, assume its a water meter but it may just be a stop cock, then they can do all the other work without the water company being involved - they just need to follow the regs eg double non return valves etc.
  16. I am aware that some manufacturers have had issues with condensation in the walls of their machines it may just be that. Why not look at a dry the panels out solution - drill a pluggable hole, connect a pipe to the hole and a tub of silica gel and see how much moisture you can draw out that way. You can get Silica Gel in volume: https://www.amazon.co.uk/Quart-Replacement-Desiccant-Indicating-Silica/dp/B013L31PQ0 that one is indicating - it changes colour as it gets wet and is likely to be toxic if swallowed - IIRC normal, non indicating, silica gel is harmless though
  17. Utilitarianism has some fundamental downsides I think such as how do you assess greater good anyway. It it how all the people see it or just a few who say "this will be for the greater good" alternatively is it for the greater good now or later - hard to know!
  18. Well I had a play today with my old surface pro - it has a GTX 1060 GPU with 6Gb of RAM, its about 9 years old! I thought can I get Gemma4 4b into that and drawing. SO I gave it a try and after some messing about I ended up with this - some HTML code output at about 25 tokens / second. Using an un-quantised Gemma4 4b model - not bad I thought without any flooding into CPU memory.
  19. They could have solved this with education - if everybody thought about the environment, their fuel bills, comfort etc - all those things would happen naturally. In essence you either have the ideological state apparatus or the repressive state apparatus you can avoid either with the other.
  20. My analysis is a bit different - planning is a part of it but the bigger part is developers interests and councils not being allowed to build council housing. The former is a problem because they want to keep prices high and maximise profit so they have no interest in mass production as it rises the supply side and so reduces prices. The councils not building for social rent, I get that housing associations are supposed to do this but funding constraints meam means that they are actually just developers, is a problem because it forces private rental and that removes housing stock from purchasers and so pushes up prices - which just closes the loop again. So sorting planning needs much more out of the box thinking alongside it.
  21. I smoothed our daughters tray underside, which was awful, with isopon and a piece of plate glass, dead flat, to ensure we had a perfectly flat surface to mate with the trap, seems to have worked - all done dry- no ct1 and no leaks 4 years on.
  22. I will get him to drill such a hole and find out. We know the wall was wet but did the remedials in November last year.
  23. Yes defo was but has had breather hole cover to be fitted. Here is a bigger image the floor in here is well above outer ground level and the wall is the party with next door.
  24. Our son had a chunk of the chimney breast replastered and it seems to be effervescent. It feels dry but I don't have my damp meter with me. Any thoughts - can it be cured or does he need to get it redone? I understand the wall beneath has been damp proof injected.
