Redbeard
Everything posted by Redbeard
  1. Silly me! Posted asking where the Duke was, without looking at the 'thumbnail' pic! Too little of it to guess which model, for me.
  2. Rather than metal straps we use to use (for a range of timber buildings) 50 x 50 sticks fixed to the face of the bottom beam and purlins and then screwed sideways into the rafters. Don't have a pic to hand.
  3. No, but have you tried Allan Brothers? Never used their alu clad (which are imported) but a client has used several 'batches' of their UK-made timber windows and was v satisfied.
  4. Good call, but the use of squirty foam at all will be governed by the answer(s) to the ventilation question posed previously. Squirty foam should only be used in well-ventilated conditions which, in my experience, often do not exist in sub-floor voids. Also having to use the gun at an angle increases the risk of sputtering and 'bounce-back'. ('Sputtering' when gun delivers liquid propellant instead of foam because the canister is not vertical, and 'bounce-back' when that liquid his a joist and splashed back, under your safety glasses (which you wear because goggles steam up) and you go to the local eye casualty. Don't ask me how I know...
  5. ... or is it just the bottom flange of a 'box and tray'-type lintel?
  6. @Iceverge, I definitely agree with you in principle, but the part of the world you are in (and the size of the job) can have a big bearing on whether you'll get a cellulose blower out of bed... I've known colleagues struggle for large extensions, let alone one floor. I don't know if it still is, but Wales used to be a good place to be for cellulose. Is Ireland similar? I don't know where @Rocket Ronlives, but it could be pivotal w.r.t cellulose. I've talked about blocking 'unintentional ventilation', and you @Iceverge, have suggested cellulose and membranes, but I don't think any of us yet has (in this thread) explicitly stated the need for excellent cross-ventilation below the insulated 'sandwich'. Yes, getting rid of warm moist air from the house entering the void is good, but if *any* vapour-laden air gets into the void, which is now colder because of the insulation, there's a potential chance of condensation occurring on the bottom of the membrane. Good, unimpeded cross-ventilation (straight lines and diagonals) is a life-saver for suspended floors. Vents in one elevation only mean you have 'ins', but no 'outs', and the air 'short-circuits'. Edit: Come to think about it @Iceverge's idea of adding to the bottom of the joists could be done in home-made OSB/plastic insulation/OSB 'fillets' to cloak the thermal bridges of the joists. For example, perhaps instead of 50 x 50 PSE, 2 x lengths of 12mm x 50mm wide separated by 25mm PIR or EPS/XPS and glued up with waterproof glue. (I used EVA nearly 40 years ago and the 2 elements are still stuck together!)
  7. Heat is lost by conduction (in this case through the floorboards, which you aim to limit by insulating - though note there will still be heat lost via the joists) and convection - air-borne heat loss. Yes, you want the floor structure air-tight, but water-vapour permeable. Water-vapour-permeability is what energy geeks call 'breathability'. You need to sort both sets of losses.
  8. If the house is Edwardian there is a fair likelihood that the skirting boards were hollow-fixed first, then the plaster carried down to the skirting. If this is the case one of the few ways you'd get the floor airtight at the perimeters while leaving the skirtings on would be to pump air-tight foam up behind the boards from the bottom. This has the disadvantage that you are very unlikely to be able to use a foam gun safely (i.e. with the can upside down). In my relatively limited experience if you attach plastic pipe to the nozzle you do not get enough pressure for the foam to 'stick'. The alternative is to find something with the consistency of 'sticky chewing-gum' and ram it up the back of the skirting from below. (You can see why foam was my first thought!). @Russell griffiths's suggestion to take off the skirting gives you a chance to get really good perimeter air-tightness.
  9. Talking of reading the photo, is that a notched 'plated' purlin bearing on that rafter/Truss? Or is it some sort of decorative 'trunking'?
  10. I should probably advise a condensation risk analysis for IWI on top of CWI. WUFI is good but Glaser is at least indicative. My reason for insulated stud (in my mind a glued laminate of, say, 12mm OSB, xmm plastic insulation, 12mm OSB) is to reduce thermal bridging. Metal stud leaves a bridge all the way through the sandwich, but is a narrower highly-conductive thing against a fatter less-conductive thing. So the end result may not be so different. I don't know!
  11. I think , off hand, you'd want insulated stud, Intello, secondary (say 25 x 50) stud, plasterboard, but have a look at Pro Clima's site. Ecological Building Systems (UK importers of Pro Clima) may advise too. Note I was writing that when @Oz07's post came in. I like Intello as it acts as a VCL but, if any moisture has got where it shouldn't, can become slightly vapour-open to let it out.
  12. Depends what you are putting it on top of. If it's gypsum painted in vinyl silk then your hopes of breathability are arguably less well-founded than with a lime plaster with breathable paint (opinions vary!!). I would make insulated studs and I'd use Intello membrane as VCL.
  13. Can I suggest you use Illbruck FM330 air-tight foam? Pretty well all foam will help, but not all is air-tight, nor dries as flexible as FM330. More expensive, but just better.
  14. Here's a link to one size of overcill: https://ewistore.co.uk/shop/external-wall-insulation/over-sill-2-5m-110mm-depth/?Size=110mm&mh_matchtype=&mh_keyword=&mh_adgroupid=&mh_network=x&gad_source=1&gad_campaignid=22700066520&gbraid=0AAAAADhexNg4SlS0vhlOGHW8qltiU573b&gclid=Cj0KCQiAgvPKBhCxARIsAOlK_Er-hrpGbM79I9UzdR6ULRJrRkfMPUlaJsyl8HDjKihsiIaeqvNunQEaAlohEALw_wcB
  15. As others say, check the glazing spec. 'Skinny' 3G might perform not much better than high-spec 2G. Incidentally I have just had my first triple-glazed unit fail after 11 years (just out of warranty!) which is a bit sad, and expensive, but I am an advocate of 3G. I will cross my fingers and watch the other 20+ panes for signs of failure! This does not seem great against 29 years and counting for 4/16/4 DGUs.
  16. Sorry to hear this. Is that OSB in pic 2 a full-thickness thermal bridge, bridging inside to out of the wall? If so that could be part of your answer. I take it that you are in mid-build (?) without the ventilation system being 'fired up' (?). If that supposition is right then the general atmosphere may/will be more moist than you'd normally expect, and coupled to a thermal bridge (?) that could 'do the business' re mould. Must say I have never had this happen, but I have never done a New build (except an extension) and that horizontal detail, in my refurb works, would normally be 25-40mm rigid WF. Sorry if this does not help.
  17. Assuming lambda values of 0.042 and 0.08 respectively for rigid WF and hemp-lime, and assuming an R value of 0.588m2K/W for the 'base case' wall, your U value with 60 and 45mm would be about 0.39, so yes, short of the requirement (of 0.30), but (a) I think you could argue for stopping there on 'safety' grounds (have you done a CRA for the WF and hemp/lime?) and (b) they may not even ask. Even though things seem to have tightened up in the new Regs and with the Bldg Safety Act it will depend on the individual BCO as to whether they ask the U value. I generally used 100mm of rigid WF which, on a 225 brick wall, gave about 0.34. Under the 'old regime' not only did no-one ever quibble; they never even asked. In fact I used to insist on telling them the U value I had achieved and why I had limited it. Like you, I ignored the adhesive layer (one only in my case) and the plaster layers in my calcs. And I always used RK70 for the adhesive layer, not RK38 - RK70 always felt much stickier. I used RK38 for the parge coat, though. (The calc above is done from R values, and my calculator, not on software).
  18. My advice (for reasons I have stated, particularly on subsequent sale) would be to do it under BC. Re floor insulation you need your exposed perimeter/area ratio to work out the 'base case U value, from which you can work out the base-case R, then add that to the R value of your to get the combined R, then 1/R = U. I'm a bit concerned about the VCL cradle, which puts your VCL on the wrong side of the insulation, but maybe I have misunderstood.
  19. If it's the same system I looked at via T.H.E for a client some years ago then it's a small exhaust air HP in the MVHR system. But you do ask how the THE system (via the MVHR) might 'feel'. If there's any risk that, while the sums (heat in via the MVHR to replace heat loss) might work the 'insurance' might be worth it in case it doesn't 'feel' right *to you* in practice. It's going to be much cheaper doing it at screed stage 'at risk' than digging up the floor.
  20. So BC did visit. Have they agreed in principle your 60mm WF and hemp/lime? Did you state a U value? (I know you do not have to in a BN). The trouble, to my eyes, with the clause which says: "Historic and traditional dwellings 0.10 The energy efficiency of historic and traditional dwellings should be improved only if doing so will not cause long-term deterioration of the building’s fabric or fittings. In particular, this applies to historic and traditional buildings with a vapour permeable construction that both absorbs moisture and readily allows moisture to evaporate. Examples include those built with wattle and daub, cob or stone and constructions using lime render or mortar." (p.3 of Part L) ...is that it is open to debate as to what thickness of WF EWI will "cause long-term deterioration of the building’s fabric or fittings". Some say 'Let WUFI tell you', (which could mean up to 100mm on a solid 225 brick wall) and others say never go above 60mm. I always try to get WUFI to prove that 100 is OK, but the BCO does not *have* to agree. My local BCOs always have, but it may be more hit-and-miss elsewhere. If they quibble you could substitute Diathonite for your hemp/lime.
  21. Can you show us a pic with a little 'boat' spirit level on the cill so we can see the nature of the fall (or not)? I *seem* to see a fatter mortar bed at the back than at the front, which suggests a fall, but an accurate spirit level will be a better judge than my old eyes. I have used the EWIstore overcills with success.
  22. 'Renovation of a thermal element' is 'adding or replacing a layer'. The 50% is *of the relevant thermal element in the room you are in*, so if there are 2 external walls and you IWI them both, you have done 100%, so definitely BC approval required. Theoretically if you did 49%, 49% and 2% in separate tranches you could arguably do it 'outside the Regs'. However when questions are asked when you come to sell the purchaser or their solicitor may not understand the 'letter of the law' under which you carried out the works, and may ask for an indemnity of a Regularisation Certificate. Your walls and ceiling to unheated space would be treated separately if done at separate times, but for counting purposes the 2 external walls are 100% of the wall area and the ceiling is 100% of the ceiling area. I always get BCO approval even for IWI of 1 external wall since, if and when I sell, I would want to be able to wave the completion cert in front of the person who was trying to find reasons to reduce the price. 200mm of wool will not reach the 0.16 U value for compliance (Edit: It might, just, if the exg 200mm was 'extra special' sheep's wool with a (lower-than-mainstream-sheep's wool) lambda of 0.035W/mK) but if it was done at a time when 200mm did 'cut the mustard' then as you are not adding a layer or replacing a layer (the pl'bd) you do not *have* to add anything. I would if I were replacing the ceiling (and of course arguably at that stage you have to stump up the £180 or whatever (may have changed since last I did one) for a Building Notice).
  23. Can I ask what you had there before? I think I understand that there was simply the existing opening - unadorned by frame or anything - and a conservatory bolted on the back. What was on the floor at that junction between room and conservatory - i.e. over the area in which condensation and mould is occurring? Hypothesis is that the brick was 'sucking' enough to disperse the condensation so that you did not see it as droplets. Then you put something else hard and not terribly insulated next to that area and *that* became the 'target area'. As I say, simply a hypothesis....
  24. OP, forgive me if I have missed this, but where do you see the mould and condensation? Is it on the main frame members (perhaps the bottom of the uprights and on all of the horizontal members) or perhaps only at the very bottom of the bottom members? The former could suggest that the specific frame sections are much less well-insulated than many of us thought* and the latter that it's perhaps the cold floor cooling the frame and taking it below the dew-point, in which case replacing the course of bricks immediately below the cill with Compacfoam could arguably warm things up enough to address (I hesitate to say 'cure' as we do not know enough about the specifics) the worst 'manifestations'. *Do they still use galv steel reinforcement at the corners of bigger frames?
  25. @fandyman sounds like a 'bowing-out' post. I was about to trawl back for/ask for further details of the condensation/cold, and exactly how it was manifesting. I thought I had read more of cold spots than of condensation of mould, but I may have skipped past a significant bit. If you're bowing out I won't trawl back/ask my Qs (which would have included what the issues were with condensation and mould on the old door. Edit: I think maybe you did not have a door there at all, as you had a conservatory.). Is the condensation forming on the frame and running down onto the screed, or forming on the screed, *not* on the uPVC? The more detail you can give the more help we can be. I wish you luck with it, whether you pursue it here or by other means.
