Redbeard
Everything posted by Redbeard
But the dwg shows a ventilated void. One assumes that is to keep the timber frame 'happy'. You have not got that, it would appear, and the architect, not having seen the builder achieve what the dwg says they should achieve (a ventilated void), as far as I can see, is of the view that it's to a 'satisfactory standard'. I can accept that a cut-in flashing can be OK (though see my earlier comment re render-board and the likely depth of the 'chase') but it neither satisfies you aesthetically nor provides the ventilated void (AFAICS) which the architect specified. The 'finish' may be to a satisfactory standard (to the architect, but not to you, the client) but the 'middle' -the provision of a ventilated void - isn't there, as far as I can see from a none-too-close-up pic. Please correct me if there is some other sort of vent provision in what has been provided. Oh, and almost as an aside, out of interest, what happens at the other end(s) of the 'continuous vent' marked on the detail? To explain, while it appears that you may not have the 'in', do you have the 'out' at the top? The pic does not go high enough for us to see.
... or is it just out of sight? There appears to be a slight 'shadow', which might be a flashing, but the camera angle is not quite right to see. Is your architect engaged to draw and specify only, or to have a supervisory role? If the latter then the arch't should be able to tell you what has been built and what should have been built. How was the contractor engaged? If it was effectively 'build this (house) according to these (plans)' then you can reasonably argue that they haven't.
I may have misread the dwg. It seems like, as drawn, there's a ventilated void, meaning that the render must be on a renderboard on battens. If a typical renderboard is no more than 15mm thick (and often less) then there's precious little to grind into. Or was the detail changed and the EWI was rendered directly onto the insulant, in which case it is not built as drawn and cannot function (in a 'vented fashion') as intended. Or have I read it all wrong? Is the answer to the mystery in 'E.W.3'?
Standing seam vs Slate for pitched roof
Redbeard replied to Mrog's topic in Roofing, Tiling & Slating
Exactly. One more trade to find and wrangle (and worry about if their credentials are not tip-top). Find a good slate roofer and stick to slate. It'll look lovely! (But please don't quote me on that if it doesn't!! 😉). Much more chance of finding a local slater whose work you can look at than a local standing-seam contractor ready to do a small one-off, I would guess. -
Judging (only) by a few posts on here re difficulties with quality on standing seam roofs I wonder if you might have things against you - not least a roofer wanting to 'get out of bed' for 20m2, when there are full houses to be done. Or I may be too pessimistic - 20m2 may be just enough to fill that small gap left after the last job... -
That sounds OK, then. How about all the other 'potentially weak' areas (junctions, intersections and so on)? If you've been taping and sealing with a vengeance then you may be OK. I am not sure what you mean by: I think of dry-lining as a whole-wall treatment. Can you elaborate? You say the cavity wall is rendered. What is the internal wall 'treatment' - hard plaster, or dot-and-dab plasterboard? If the latter, is it 'true dot-and-dab', or full perimeter beads and cross-hatchings?
If that means you can feel 'something of a draught' (at atmospheric pressure) from the sockets I think I'd be a bit worried about other areas. Who has it been built by? Yourself with a concentration on air-tightness, or a general builder with no specific air-tightness 'leanings'?
Full house renovation and retrofit guidance
Redbeard replied to fisnik's topic in House Extensions & Conservatories
I realise you will probably be there for life, but just in case you ever need to sell, might I suggest that you try to 'buy' that 50mm? A client of mine did exactly that, though they at least knew who owned the land. In the case of a 'shared road' it may not be so straightforward to find the 'owner' to buy from. -
I was typing while @JohnMo was posting. His points are very valid. Why rip out if you cannot afford to re-do? If the potential cost is completely unaffordable why not ask for a staged plan? -
Welcome. What's the orientation? Is it conducive to solar? Do you have plans for PV? I assume the house is of cavity construction. is the cavity insulated? If money is tight I am not sure how keen you'll be to completely remove the bays and 'plant' new bays on top of EWI. EWI also needs care to avoid the risk of thermal by-pass via the cavities. If you were to go for internal insulation (IWI) you'd be limited as to what U value you could achieve, due to the risk of interstitial condensation. Detailing can also be tricky depending on the internal layout. On the other hand, assuming you do not own the land to the right, I'm not sure how practical EWI would be, either. Ideally you need to find a way to use one or the other, or a mixture of both. If perchance, there are 'viable' (50mm+ and 'clean') cavities and they are uninsulated, start with that, with EPS beads (not mineral wool, in my view). -
What's wrong with a SIP extension (self build)?
Redbeard replied to Apache's topic in Structural Insulated Panels (SIPs)
The same could apply with a double-skin timber frame with much more choice of insulant and a more 'permanent' 'feel' (both of those 2 words pretty vague in meaning in this context, but clear to my old brain). -
What is this made of? Ceiling wood fibre board type stuff
Redbeard replied to paro's topic in Building Materials
why ply? Why not plasterboard? Some of my sloping soffits have thin wood-fibre (40-50 year-old), plastered over, and almost certainly as an underdrawing to knackered lath and plaster (This year's job to remove and insulate with 260mm wood-fibre and lime plaster over (yes, had the structural calcs done!). The plaster on the aforementioned thin WF causes it to sag, so it looks cr*p. -
What you describe is a hybrid Warm roof - some on top of the rafters and some between. In some circumstances there is a risk of the dew-point occurring at the interface. A condensation risk analysis (CRA) can guide you, but a colleague had a good rule of thumb: If you have two-thirds of the R value above the rafters and one-third below, the interface is unlikely to get cold enough to reach the dew-point. If I remember correctly the lambda of cellulose is (or was when I used it) 0.036W/mK, and PIR is 0.022W/mK. So for 125 cellulose it's 3.47m2K/W (actually less, as that does not take into account the 'intrusion' of the rafters) and for 100 PIR it's 4.54m2K/W, so not too far off but probably not two-thirds/one-third. A CRA (particularly if done in the WUFI software) will be more accurate. Edit: A thought: If noise is an issue why not consider rigid wood-fibre on top? 140-180kg/m3 as against about 32kg/m3 (IIRC) for PIR)?
- 19 replies
- vapour control layer
- standing seam
- (and 9 more)
Skimming a wall with wallpaper/skim substrate
Redbeard replied to jfb's topic in Plastering & Rendering
I would not advise skimming over paper, however well-bonded it appears to be. Borrow a steamer and steam it off. 24hrs seems a v short time to leave a deeper base-coat before skimming. I'd just say leave it longer. If you can get hold of a small amount of lime putty (which lasts forever when kept under water) you can just mix it as required with plastering sand. There are specialist lime etc. suppliers not so far from Oxford. -
Loft hatch or no loft hatch
Redbeard replied to Selfbuildsarah's topic in New House & Self Build Design
Do you really need access? What is there to access? Wiring? Plumbing? Ductwork? I am guessing none of the above, so that leaves 'the void'. Project yourself forwards 10, 20 or 30 years and think if the necessity will ever crop up. If you think it won't, don't have a hatch. Worst case scenario is that years hence you have to cut the plasterboard and get deluged with Warmcel. Not the worst deluge in the world. -
Congratulations - a big worry off your plate. Perhaps more importantly, is the house (and are the bills) comfortable?
Re the sloping roof, unless they guessed it wrong 1st time (design U value), all other things being equal (which perhaps they are not*)I cannot fathom how they get a worse U value with 150 (as-built - apparently 0.2W/m2K))than with 125mm (stated as 0.18). *Much closer rafter centres and fatter rafters (therefore larger timber fraction in the calc) in as-built than design? So this is to the pre-2022 Regs, then?
There is no discussion to be had. Not least because of that 'droop' - never mind what's hidden behind the once-wet plasterboard - they seem to be proposing to hand it back to you looking worse than it did when you bought it. Say no and stand your ground.
....and ended up with 50mm PIR (only, as far as I read) in the walls? Since SAP for new-build is a whole-house affair (with back-stop - worse - U values for each element if I recall correctly) unlike refurb, where it is 'walls must be x; roofs must be y' etc.) I am not saying 50mm PIR would not 'hack it' but it sounds like half or less what I'd have used. What was stated in the archo's dwgs? My U value calcs are only rough ('fag-packet' rather than software) but the lightweight blocks must be a lot better than the standard blocks in my default to get 0.25W/m2K. Was there really less than 50 PIR (say 100 rockwool) spec'd initially?
Removing broken cast stone window cill
Redbeard replied to Lincolnshire Ian's topic in Bricklaying, Blockwork & Mortar
But I am a pessimist! And someone for whom wonder-glues rarely do what they say on the tin/cartridge/tiny tiny little tube... -
My thoughts too, though it depends on how many pieces the 'piece' is in. Many people have a lot of success with epoxy. If you have the piece as a whole piece you could try drilling holes for, say, 3 dowels in the main cill, bed the dowels in epoxy in those holes, and drill corresponding, perhaps slightly oversized, holes in the broken piece, clean and 'butter' the faces with epoxy, then breathe deeply and and press together. If you are lucky the reveal could help wedge it together. Optimist's view: Done! Pessimist's view: (Just refuse to entertain that view!) -
While the extension is incomplete it is the best time to chase and resolve the leaks. They will bug the hell out of you in future if you don't. I agree with @Russell griffiths that the membrane on the sloping soffits looks like standard thin poly VCL. There's a small chance it could be something else but that green is suspiciously indicative of 'Bargain Basement VCL'. I'd like Intello too. Please do not give up on leak-finding! I assume the walls are leaky too? But even if they are not, as far as the roof goes you want (a) the right membrane and (b)someone to make sure it is as tight as a tight thing from an air-tightness POV. If the reason you have given up with a/t is the difficulty of finding the holes have you thought of making a basic 'blower door' (old desk fan or car radiator fan in a lump of ply) to tape into an opening? If you de-pressurise the room you're checking then, certainly in this weather, you will feel cold air rushing in. Arm yourself with good-quality a/t tape and you're off. I am sure someone(s?) on here has posted pics of such a home-made fan. Found it: 1st post on p.4 of this: Good luck. Do not give up, and please do not let them begin to plasterboard till you are happy.
Yes and no. The spare tiles were in case you cracked the existing when drilling. The 'platform' could be made of anything. 9 or 10mm ply or cement-board cut slightly undersized so that you can 'point up' with silicone. Equally if the tiles are c 10mm and you like cutting tiles, use tiles, again undersized and pointed. Re the fixing of the cistern, I have a sneaking feeling that one of mine (they are all close-coupled) never got fixed to the wall anyway, with no disastrous effects. I'll go and have a look later!
I can't see infill of 10mm looking awful, so go for that. I guess you may have to plug and re-drill the holes for the cistern, risking tile cracks, but (unless I have missed something) that looks like being your worst potential problem. Do you have a couple of spare tiles?
