Redbeard
Everything posted by Redbeard
Talking of reading the photo, is that a notched 'plated' purlin bearing on that rafter/Truss? Or is it some sort of decorative 'trunking'?
Internal insulation for block cavity walls
Redbeard replied to Julestools's topic in Heat Insulation
I should probably advise a condensation risk analysis for IWI on top of CWI. WUFI is good but Glaser is at least indicative. My reason for insulated stud (in my mind a glued laminate of, say, 12mm OSB, xmm plastic insulation, 12mm OSB) is to reduce thermal bridging. Metal stud leaves a bridge all the way through the sandwich, but is a narrower highly-conductive thing against a fatter less-conductive thing. So the end result may not be so different. I don't know! -
I think , off hand, you'd want insulated stud, Intello, secondary (say 25 x 50) stud, plasterboard, but have a look at Pro Clima's site. Ecological Building Systems (UK importers of Pro Clima) may advise too. Note I was writing that when @Oz07's post came in. I like Intello as it acts as a VCL but, if any moisture has got where it shouldn't, can become slightly vapour-open to let it out. -
Depends what you are putting it on top of. If it's gypsum painted in vinyl silk then your hopes of breathability are arguably less well-founded than with a lime plaster with breathable paint (opinions vary!!). I would make insulated studs and I'd use Intello membrane as VCL. -
Can I suggest you use Illbruck FM330 air-tight foam? Pretty well all foam will help, but not all is air-tight, nor dries as flexible as FM330. More expensive, but just better.
Waterproofing window sill with too little incline
Redbeard replied to Bruce's topic in Waterproofing & Sealants
Here's a link to one size of overcill: https://ewistore.co.uk/shop/external-wall-insulation/over-sill-2-5m-110mm-depth/?Size=110mm&mh_matchtype=&mh_keyword=&mh_adgroupid=&mh_network=x&gad_source=1&gad_campaignid=22700066520&gbraid=0AAAAADhexNg4SlS0vhlOGHW8qltiU573b&gclid=Cj0KCQiAgvPKBhCxARIsAOlK_Er-hrpGbM79I9UzdR6ULRJrRkfMPUlaJsyl8HDjKihsiIaeqvNunQEaAlohEALw_wcB -
Triple glazed Vs double glazed patio doors
Redbeard replied to flanagaj's topic in Doors & Door Frames
As others say, check the glazing spec. 'Skinny' 3G might perform not much better than high-spec 2G. Incidentally I have just had my first triple-glazed unit fail after 11 years (just out of warranty!) which is a bit sad, and expensive, but I am an advocate of 3G. I will cross my fingers and watch the other 20+ panes for signs of failure! This does not seem great against 29 years and counting for 4/16/4 DGUs. -
Sorry to hear this. Is that OSB in pic 2 a full-thickness thermal bridge, bridging inside to out of the wall? If so that could be part of your answer. I take it that you are in mid-build (?) without the ventilation system being 'fired up' (?). If that supposition is right then the general atmosphere may/will be more moist than you'd normally expect, and coupled to a thermal bridge (?) that could 'do the business' re mould. Must say I have never had this happen, but I have never done a New build (except an extension) and that horizontal detail, in my refurb works, would normally be 25-40mm rigid WF. Sorry if this does not help.
Assuming lambda values of 0.042 and 0.08 respectively for rigid WF and hemp-lime, and assuming an R value of 0.588m2K/W for the 'base case' wall, your U value with 60 and 45mm would be about 0.39, so yes, short of the requirement (of 0.30), but (a) I think you could argue for stopping there on 'safety' grounds (have you done a CRA for the WF and hemp/lime?) and (b) they may not even ask. Even though things seem to have tightened up in the new Regs and with the Bldg Safety Act it will depend on the individual BCO as to whether they ask the U value. I generally used 100mm of rigid WF which, on a 225 brick wall, gave about 0.34. Under the 'old regime' not only did no-one ever quibble; they never even asked. In fact I used to insist on telling them the U value I had achieved and why I had limited it. Like you, I ignored the adhesive layer (one only in my case) and the plaster layers in my calcs. And I always used RK70 for the adhesive layer, not RK38 - RK70 always felt much stickier. I used RK38 for the parge coat, though. (The calc above is done from R values, and my calculator, not on software).
- 17 replies
- building regs
- insulation
(and 2 more)
My advice (for reasons I have stated, particularly on subsequent sale) would be to do it under BC. Re floor insulation you need your exposed perimeter/area ratio to work out the 'base case U value, from which you can work out the base-case R, then add that to the R value of your to get the combined R, then 1/R = U. I'm a bit concerned about the VCL cradle, which puts your VCL on the wrong side of the insulation, but maybe I have misunderstood.
- 17 replies
- building regs
- insulation
(and 2 more)
Real world feel of MVHR +heat system
Redbeard replied to MPx's topic in Energy Efficient & Sustainable Design Concepts
If it's the same system I looked at via T.H.E for a client some years ago then it's a small exhaust air HP in the MVHR system. But you do ask how the THE system (via the MVHR) might 'feel'. If there's any risk that, while the sums (heat in via the MVHR to replace heat loss) might work the 'insurance' might be worth it in case it doesn't 'feel' right *to you* in practice. It's going to be much cheaper doing it at screed stage 'at risk' than digging up the floor. -
So BC did visit. Have they agreed in principle your 60mm WF and hemp/lime? Did you state a U value? (I know you do not have to in a BN). The trouble, to my eyes, with the clause which says: "Historic and traditional dwellings 0.10 The energy efficiency of historic and traditional dwellings should be improved only if doing so will not cause long-term deterioration of the building’s fabric or fittings. In particular, this applies to historic and traditional buildings with a vapour permeable construction that both absorbs moisture and readily allows moisture to evaporate. Examples include those built with wattle and daub, cob or stone and constructions using lime render or mortar." (p.3 of Part L) ...is that it is open to debate as to what thickness of WF EWI will "cause long-term deterioration of the building’s fabric or fittings". Some say 'Let WUFI tell you', (which could mean up to 100mm on a solid 225 brick wall) and others say never go above 60mm. I always try to get WUFI to prove that 100 is OK, but the BCO does not *have* to agree. My local BCOs always have, but it may be more hit-and-miss elsewhere. If they quibble you could substitute Diathonite for your hemp/lime.
- 17 replies
- building regs
- insulation
(and 2 more)
Can you show us a pic with a little 'boat' spirit level on the cill so we can see the nature of the fall (or not)? I *seem* to see a fatter mortar bed at the back than at the front, which suggests a fall, but an accurate spirit level will be a better judge than my old eyes. I have used the EWIstore overcills with success. -
'Renovation of a thermal element' is 'adding or replacing a layer'. The 50% is *of the relevant thermal element in the room you are in*, so if there are 2 external walls and you IWI them both, you have done 100%, so definitely BC approval required. Theoretically if you did 49%, 49% and 2% in separate tranches you could arguably do it 'outside the Regs'. However when questions are asked when you come to sell the purchaser or their solicitor may not understand the 'letter of the law' under which you carried out the works, and may ask for an indemnity of a Regularisation Certificate. Your walls and ceiling to unheated space would be treated separately if done at separate times, but for counting purposes the 2 external walls are 100% of the wall area and the ceiling is 100% of the ceiling area. I always get BCO approval even for IWI of 1 external wall since, if and when I sell, I would want to be able to wave the completion cert in front of the person who was trying to find reasons to reduce the price. 200mm of wool will not reach the 0.16 U value for compliance (Edit: It might, just, if the exg 200mm was 'extra special' sheep's wool with a (lower-than-mainstream-sheep's wool) lambda of 0.035W/mK) but if it was done at a time when 200mm did 'cut the mustard' then as you are not adding a layer or replacing a layer (the pl'bd) you do not *have* to add anything. I would if I were replacing the ceiling (and of course arguably at that stage you have to stump up the £180 or whatever (may have changed since last I did one) for a Building Notice).
- 17 replies
- building regs
- insulation
(and 2 more)
Can I ask what you had there before? I think I understand that there was simply the existing opening - unadorned by frame or anything - and a conservatory bolted on the back. What was on the floor at that junction between room and conservatory - i.e. over the area in which condensation and mould is occurring? Hypothesis is that the brick was 'sucking' enough to disperse the condensation so that you did not see it as droplets. Then you put something else hard and not terribly insulated next to that area and *that* became the 'target area'. As I say, simply a hypothesis....
OP, forgive me if I have missed this, but where do you see the mould and condensation? Is it on the main frame members (perhaps the bottom of the uprights and on all of the horizontal members) or perhaps only at the very bottom of the bottom members? The former could suggest that the specific frame sections are much less well-insulated than many of us thought* and the latter that it's perhaps the cold floor cooling the frame and taking it below the dew-point, in which case replacing the course of bricks immediately below the cill with Compacfoam could arguably warm things up enough to address (I hesitate to say 'cure' as we do not know enough about the specifics) the worst 'manifestations'. *Do they still use galv steel reinforcement at the corners of bigger frames?
@fandyman sounds like a 'bowing-out' post. I was about to trawl back for/ask for further details of the condensation/cold, and exactly how it was manifesting. I thought I had read more of cold spots than of condensation of mould, but I may have skipped past a significant bit. If you're bowing out I won't trawl back/ask my Qs (which would have included what the issues were with condensation and mould on the old door. Edit: I think maybe you did not have a door there at all, as you had a conservatory.). Is the condensation forming on the frame and running down onto the screed, or forming on the screed, *not* on the uPVC? The more detail you can give the more help we can be. I wish you luck with it, whether you pursue it here or by other means.
I think the points being made by those who have responded to your OP suggest that, however regrettable it is, most window/door re-fitters do 'fit the hole'. In the absence of any other instruction (such as re thermal bridging mitigation, which might be included on an architect's or other professional's spec.) that's 'what they do'. If they have not 'fitted the hole' very well (the sealant is poorly-detailed or the opening lights do not 'kiss' the draught-stripping well) this can and should be amended. Then they would have done the job 'with reasonable care and skill', 'fit for purpose' (it's a door without draughts) and 'as described' insofar as their 'offer' probably said something along the lines of 'supply and fit XYZ door'. (What did it say?) If peripheral insulation measures had been promised and not installed then the CRA (of which I know nothing, TBH) may 'kick in'. Knowing that you are unhappy about the cold threshold I suggested a careful and painstaking 'stitching' job with Compacfoam or similar. That could be done (with caution - don't accidentally introduce 'droops' as others have said) but it would be an extra over and above (as far as we know) what was quoted for.
Answers: 1. I doubt if any of us here would say it was acceptable but I suspect it is common. 2. Yes for me, and I guess for all of us here. 3. Not much, and yes. 4. I don't know. I fear that there's no obligation to insulate below a cill. I'd do it anyway, but whether Bldg Regs would *make* me do it, I think perhaps not, but not certain. The last patio doors I was involved with were sat on Compacfoam. 5. No, sorry. I think if I had been presented with what you have there I would be cutting out a brick at a time and replacing with something like Compacfoam - expensive but effective load-bearing polystyrene. I am sure there are lots of really good uPVC window and door installations. Unfortunately I have seen a large number of average-to-awful ones, so this detail upsets me but does not surprise me. Was the uPVC door a replacement of an existing door, or is that a 'dropped' window opening? The latter, I think, given the odd cuts on the bottom half, RHS. Edit: Thinking about it, the patio doors we did were in a wall with EWI, so the compacfoam was 'buried'. In your case you'd have a 'raw edge'. It's late, so I'll think in the morning how one might deal with that. How far above ground level is the external cill? If it is close you'll get a lot of splash-up. OK, it's not a timber door, but neither is it ideal. (And whatever the Building Regs say, rain splashed up more than 150mm in many areas!
Oh I do like the potato connector idea!
?1 or 2 IBCs, cut out as necessary.
Fitting heavy triple glazed windows safely on new buildings
Redbeard replied to Simmon's topic in Windows & Glazing
Ah! Thank you! It did, however, get me digging for relative weights of alu vs timber frames, and I could find no general authoritative source. AI, however (which I don't rush to believe generally but which may be right in this case) suggests that alu and timber frames (the alu being hollow and the timber not until the CFBs get in!) are similar in weight. So I ask the OP, or anyone, where does the 350 - 450kg come from for a 4m2 window? -
Thanks for that?! At least it encouraged me to check the relative weights of alu vs timber. From motorcycling days I always thought of alu as very light, but then I never rode a wooden motorcycle...Rest assured that I never have installed alu windows and do not intend to, so all is well from that point of view! -
A question: ''350 - 450kg?'' I have just looked at the order conf for one of my windows - 3G timber approx 2.3m2 - weighs 82kg. Yours are nearly double the area, so say double that weight - 164kg. I find it hard to understand what gives you the extra 190-290kg. Or have I misread the Q?
