How long is too long for a hot shower feed?
Nickfromwales replied to Miller3857's topic in Bathrooms, Ensuites & Wetrooms
Hot Return Circuit. The pump you have that ( when fitted correctly ) massively reduces the delay in getting hot water out of any outlet. -
Iirc the WB Greenstar 12ri will drop to 6-7kW. That's what you want.
And your shoes ? -
What happens on tour stays on tour. -
You design it according to the remit . Does the OP want :- ? To run 2, 3, or 4 or more showers simultaneously.... To size the entire system to the dwelling, or to their actual needs.... Does the OP have sufficient cold mains flow / pressure to support the above? Are accumulators to be involved if mains is insufficient? Has a thermal store been fitted yet? Why specify a TS when this may be better off with a large UVC or pair of medium sized UVC's? Lets see how the hot water is going to be pushed around the building before deciding what the hot water system can / cannot do. -
If the pipe is going to the showers, then one assumes it'll also be going to the basins in those rooms too. The showers are inconsequential as you just open the tap at high flow and wait, no bother at all there, but the basin taps will likely hardly ever see hot water when washing your hands briefly after using the loo. Hot recirculation circuit system is a no-brainer here afaic. Sounds like a big house too so I'd run the HRC to all outlets to maximise the cost / benefit. Running a HRC is not very costly, and if no concern whatsoever if you have PV to offset your energy consumption. That's exactly what @jacks plumbers did with wait times of 45 seconds for hot water to basins. I'd do the same eg 28-22-15mm series pipework and leave the manifolds, but I'd run the HRC to each bathroom 22mm supply where it tees and dropscto 15mm and super insulate all the hot and HRC pipework. More info please @Miller3857 ! -
Couldn't agree more about the fabric first approach. Why spend money building a less insulted house with a high temp heating system, with your income going towards tracking the cost of fossil fuel, when you can spend once on more insulation / MVHR / airtightness detailing and live cheaper forever? It need not cost a fortune with planning and a good degree of curiosity.
Stainless steel Panduit ties Cheap as chips We used them on RFA ships when removing redundant weapon systems. I had 3 agency electricians from Brazil and Portugal who lasted less than week before going off with repetitive stress injury from the tensioner that you have to use with them, plus you have to cut a piece of silicone rubber gasket to suit each time. The local Geordie shipwrights just stood there laughing as I watched 3 grown men walk around with bandages on going about their light duties.....on full pay Plus they managed to each snap at least two pairs of top quality Wiss tinsnips because they didn't understand to use the back of the jaws not the bloody tips. Cue cheap flights home
How did I miss this ? Beer and a pie ! Is this sorted now?
You can always use lpg for gas cooking btw.
They also are a doddle for DIY non-MCS registered installs ( e.g. cheap ) so look at what you need and aim to self-consume all, or as much of, what you generate. If you have electric only, then I'd look at a Sunamp + Willis ( immersion heater ) based UFH system with a second Sunamp as the DHW ( domestic hot water ) provider. Look to store as much of the pv generation as you can by employing a good pv diverter and once you've got a year under your belt, if necessary, you could add a few more panels if so required. Id forget oil or lpg and put the cash into something smarter. An ashp would be a cheap way to solve space heating but when you need it most, the pv won't really be up to providing what you need anyway so £'s per kW ( taking maintenance and lifespan ) the Sunamp + Willis solution has the most appeal imo. That lot fortified with grid electricity for any time the pv hasn't cut it and you've got a clean, simple, and uber-low maintenance solution.
You have to keep that T&PRV on the buffer so you're covered for the terminal failure scenario, which is all the isolations shut off and the immersion heater on and its stat to have failed. Its that situation that dictates the T&PRV's location ( and the fact that its factory fitted with half a tub of thread lock so its near impossible to remove ). Just put a 15L container under it and you'll be fine as the PRV on the boiler should be a lower setting. The buffer one is 5 bar IIRC and the boiler one will be 3 bar.
Nobody understands me....... Actually the whole conversation revolved around a sealed and pressurised TS being used as a buffer, so by the sounds of it, the guy on the other end of the phone may have been half awake. Bugger.
Looking good. 9/10 though I'm afraid......... If you follow the expansion vessel back to the buffer, you can see it could be isolated from the heating system should the right hand manifold be fully isolated and left so for any duration The expansion vessel should be connected independently to the buffer, BEFORE the isolation valves, as its to protect the vessel more than anything. Ultimately if its your house and nobodys going to work on it other than you then you can sleep easy, but the rule is that you never have an isolation, or any other valve, between the EV and the cylinder / heat source. Im such a killjoy
@PeterW, I think my crossed wire just got uncrossed.......cue another call to telford tomorrow.
Thank goodness that rats and mice have blunt teeth and no desire to knaw through things
Plastering Moisture Resistant Plasterboard
Nickfromwales replied to Onoff's topic in Plastering & Rendering
Ive only ever had to have that done when we've dabbed thin IWI boards on and they have a horrible cup to them. -
Ill nip to the offy's for another 8 ace then, and we'll see how this unfolds -
Why I said effective A header tank is called that because it has to be at the head / top of a gravity fed setup. An accumulator can be mounted in a basement or garage etc. One is non-potable, and the other is 100% drinking quality, potable water. Accumulators get size according to each instance, just like choosing between a 25 gal header ( CWS ) or a 50 gal one.
Ah, you mean in with the PVA? Not laying an actual set of bonding? -
Ah, 3 decades ago yes, probably as good as it got back then . The beauty of the accumulator is that it stores at mains pressure. No electrical connection or reliance on power, no moving mechanical parts, one pipe in / out and if the power fails to the pump that's pressurising it, you keep getting pressurised potable water to the value of the effective / stored volume. Same exact scenario as you have, but clean fresh water. Agreed that as a modern solution it would be done according to what's available and the info / feedback used to arrive at such a decision, so please ignore my 'bad decision' comment as I thought ( assumed ? ) that you'd installed this recently. Oops
A coat of bonding ? On new plasterboard ? -
@Caroline What spec are you building to? Just before we all stray off on different tangents. Are you having solar PV ? With some thought and commitment early on, you should be able to avoid the need to set fire to ANYTHING.
After youve spunked all your cash on the various potions, and devices with which to apply them, your have paid the spread. A 4' blade needs some serious skill, and I just about have the wrists for my 18" Ox for flattening off over old plaster etc. No xmas card for you this December ! Dead man walking The last customer who said exactly that asked to borrow my step ladder to skim his bathroom ceiling. When I came in the following morning, the ceiling was destroyed, his clothes were rolled up in the corner covered in plaster and about 8 litres of sweat, and my lightweight aluminium step ladder had to go in the skip as it weighed about 60kg with all the plaster that was on it. Took about 4 hours to clean the floor and walls too. My mate came in that evening and skimmed it for £80. Was like a sheet of glass. Disclaimer : After all this has been said, I really need you to cock it up or I'm going to put 2 stone on from all the humble pie and custard. -
Why would he blue grit it?!? Its new plasterboard not 30 year old render ! I give up Blue grit should not even be in the building
