Roger440
    7
Everything posted by Roger440
  1. Complication. Its a screw lift. If it was hydraulic, sure, easy done. A screw lift has 2 motors (both 3.2kw), one each side, and if theres a car on it already, you are starting it at full load. Unlike a hydraulic ramp. Single phase screw lifts are liking rockig horse doo doo. And i hate hydraulic 2 posters. Pain in the backside for accurate lowering of, say a shell, over a subframe.
  2. Not entirely, as electricity prices were what i was posting about. But, yes, mostly
  3. 300sq/ft. Its big, but not THAT big. I wasnt referring to the pool, more the waste heat, as you (and Johnmo) suggest plumbed into a massive tank. Supllemented by an oil boiler. I was coming from a different angle though, ie, my electricity bill is bonkers, therefore looking at generation. "if" i had a genset (and solar and batteries) its still cheaper to buy from the grid. (ignorig a non gen set solution for now) But i hadnt factored in using the waste heat. Which rather changes the calculation. Without that waste heat factor, yes, oil is still probably the way to go. The electrics cant cope with a big ASHP. Not in addtion to everything else. Im not paying £20k for a connection. Thats just silly. For a 2 post lift, demand on start up is too high for a static convertor, Would need to be rotary. Which the manufacturers demand a 60 amp supply. Not do-able. Zoning of the building is in process, to a point.
  4. One wonders how noisy a silenced genset would be inside. Probably too noisy, but would be fine at night. It also would neatly solve my lack of 3 phase for an awful lot less than the £20k that National Grid want for a connection from a pole 50ft from said barn. In my own field.
  5. Hmmm,given I have a barn to heat as well, and that my only realistic option is oil, that much waste heat, collected, in a huge tank, would massively skew the figure in favour of self generation. Even without attempting to use the exhaust heat. If said genney was IN the barn, you would capture still more, ie, that which is radiated off the engine block. Time for some more number crunching.
  6. I priced up usin red diesel, so a bit over half the costs you used. Which helps significantly. Yes, capital costs if you just buy a turnkey set up is significant. No need for that. Found a big silenced, low hours, Kubota genset for £4k. Second hand solar panels are a tenner a pop now. Just the batteries to fund. Maybe a small domestic set plus a EV too for some proper capacity. That im even thinking about shows how messed up things are........................ But i cant keep paying for electricity at current prices as a releatively heavy consumer. Something has to give.
  7. Surprised? No. So bills will be coming down then? Err, no to that too. And so the never ending increases in electricity prices keep on coming. I was crunching the numbers on generating my own power with solar, batteries and a (proper) gen set. Currently not cost effective, but we are not that far away now. Another 20-30% increase and it will make sense. Madness for a developed country. One wonders how bad it has to get before something happens and people start demanding action. 30p, 40p, 50p per kWh?
  8. What he said^^^ The average welsh stone cottage isnt going to be remotely air tight. Start here. As far as the bifolds are concerned, normally everything is adjustable. However, the problem ive run into 3 times now, is the frame being so far out of true, that no amount of adjustment can sort it. In which case taping them up might be the sensible option.
  9. Dry stone walls are indeed not terrible. Problem is, most a sdamp or wet as a consequence of inappropiate choices made in the past. Whatever else you problems, if its not dry, thats the first thing to address. OP, you make no mention of this? There are pretty much no circumstances under which PIR or the like is a good idea on such a house with no DPC.
  10. Sensible advice. After all, if you have it removed, they are taking it away to be buried, not to be magic-ed away. Might as well stay buried where it is.
  11. The government doesnt want to bring prices down, and they are not going to break the link. Ive just calculated ive spent just over £3k in 12 months on electricity. Absolutely bonkers. Though quite what i do about is is another thing entirely. Hoping that prices will come down, however, looks like no solution.
  12. Going to be hard. In England. However, you might want to consider Wales. They have the one planet scheme that might be suitable for you. https://www.iwa.wales/agenda/2022/09/one-planet-smallholdings-a-new-path-to-rural-sustainability/?gad_source=1&gclid=CjwKCAiA2JG9BhAuEiwAH_zf3jDnvlaLXX8aSzNQcgHM_OPzeBI0vPhv525kt4_WJ9Gt1fs__gn5FBoCne8QAvD_BwE I think this was how youtuber Kris Harbour did his place.
  13. Ive got (well did have until i moved) a Vortex. I wouldnt get another. But as you asked earlier about maintenance contracts, no i didnt. I looked after it myself. Its not rocket science. Im inclined to agree you are over thinking it. Install, turn on, put the plugs in the sinks and leave. Im not a fan of turning it off. That was when i had issues, with stuff settling, and blocking the sludge return, and on one occasion the bubblers. Easy enough to fix, but its an intervention you dont want or need. Other plants maybe be more forgiving of turning it off.
  14. Coconut husks or similar i believe.
  15. To be honest, the life time of the steel is the least of the problems. The sleepers will rot out long before the steel either way. Unless you are using real, second hand hardwood railway sleepers.
  16. I wouldnt consider powder coating steel in this application. Its doomed to early failure.
  17. Theres certainly some crap foil tapes about. I found one advertised as "suitable for use in cold weather". Works a treat, actually sticks and doesnt split easily.
  18. I long since gave up with insulated plaster board. Its really difficult to ensure theres no air gaps. Well, impossible really as you cant see behind it once it gone up.
  19. make sure no households are let down in this way again, while overseeing current scheme that does exactly this. And this time, at far higher cost to the taxpayer. Some things never change.
  20. Something like this. https://glidevaleprotect.com/product/intelligent-passive-stack-ventilation-ipsv/ I like the concept, because it uses no power, or internet. And makes no noise. Minimal capex cost. Its just sits there doing its thing. I even have an existing chimney thats redundant.
  21. Proving, as is often the case, that FENSA is just bollocks. Just a license to use squirty foam. I did consider becoming FENSA registered, so i could do my own windoes, properly, but they appear to have made it more difficult.
  22. This isnt necessarily true. As i found out when selling a house. Accepting different councils may do different things, Buckinghamshire do NOT record or log ANY work done under an approved contractor scheme. Nor do the keep or log certificates issued by private building control. When asked by the buyers solicitor to provide evidence of the cert for my garage, and FENSA for doors and windows, i, naturally, like everyone else, thought i could get these from the council. Well you cant. After a long conversation, they conceeded that they just bin them. They subsequently confirmed in writing they dont log or record such things. They only record stuff signed off by council BCo's. Took some extracting though! I had to purchase indemnity insurance to satisfy the purchaser. Found the damned things a couple of years later! So if you dont keep them yourself, its very much possible to say you cant find them. How will anyone prove different?
  23. Unless your walls are made of sponge, moisture wont rise 3m. Around about 1m is normal. Id suggest you have some issue from above as well as below. Im going to guess no DPC given the age. And gypsum plastrer inside, and cement render outside?
  24. Im all for challenging stuff. Which is why i asked what you did instead. Once my house is sufficently air tight, then i will need to do something. However MVHR is certainly not my preferred option. Its complicated, difficult to retrofit, and needs maintenance. And costs power to run. And makes noise. Some time ago someone posted "passive stack ventilation" for example. I liked that as it simple. Is it effective? No idea.
