SteamyTea
    200
  1. I think there has been one recorded incident of someone being directly hit by a fragment of comet/meteorite in my lifetime (as opposed to secondary damage). So that is 1/(55 x 5bn) 3.6 x 10-12 chance. I suspect that lead poisoning from a soldered joint is a lot higher. Car driving is a lot more dangerous, even on lead free fuel.
  2. Not sure about the acidity of the water down here, but my element is probably the original, so 30 years old this year. This is the inside of my ten year old and ten quid Tesco kettle (and it has a lot of use in my house).
  3. Nick Is there any reason, other than personal preference and cost, to just vent a UVC. That way you get the built in heat exchanger (only a coil of pipe after all) and you can then just plumb in as normal. I know you very much like UVC as it saves a bit of plumbing up to a tank, but that seems to be all it saves. I almost agree with you on the G3 inspection on rented places, which is why I disagree with you on a gas hob, just something else that needs inspecting and can go wrong (I can see a visitor not bothering to twist a valve to the on position and the husband pulling the installation apart to 'fix it'). A two 'ring' induction hob is probably all that is needed for a holiday cottage. Flick the switch on the wall and it is ready to go. Might be worth getting one of those pyrolytic ovens though. A clean oven says a lot (says you can't cook generally, or your staff need more training, says someone that has a dirty oven at home and a spotless one at work). This is an alternative for the shower, very cheap to fit, about as efficient as you can get, probably could be modified to work as an inline heater, and the user will not be able to say much when it fails.
  4. There is no reason why they should not work (never answer a question with a negative, but hey ho). As long as there is a good stable water supply they should perform as expected (not difficult physics). Would make the plumbing in a new build or major refurbishment easier too. Just for a laugh, and not having done a Silly Sunday Experiment for a while, I just filled up my 2 litre water jug from my kitchen tap, too 5 seconds, so 24 litres/minutes flow, took 6 seconds on the basin tap. So 20 lt/min flow there. So even allowing for some losses (friction, pressure and generally efficiency), I would think that a shower with a flow of 15 lt/min would be quite possible at my house. That is almost 50% greater than what I have (and I have no real complaints with the shower). Knowing that leads nicely into sizing a cylinder. I have 200lt of water at 50°C, which is probably closer to a mean of 40°C, but as Crofter will be running his at a minimum of 65°C, his mean would be closer to 50°C overall I would think (there are ways to reduce the temperature gradient to get a greater capacity from the same size cylinder). As a shower does not really need to be hotter than 40°C, 90% cold water would need to be added (almost 50/50 mix as it depends on mains temperature). This would give an equivalent of a 420 lt store of water for showering. At 15 lt/minute, that would give 28 minutes of showering (all these figures are a bit rough). Might not sound much, but that is before any extra energy is inputted, and working from a 200 lt cylinder (and about what my old lodger did before I educated her, with a stick). This might cause problems when on E7/10 only, but an extra 10 kWh of energy at day rate would be about £2/day. As I suspect the place will not be rented out at 50 quid a week, not really a real problem. Just let the secondary immersion heater deal with it via the thermostat (say set 10°C lower than the main E7 one).
  5. I just had a look too. Seems you can get then from about £300, so no real price difference. Be nice to see one in action.
  6. I did not even think about it ten years ago. I am not sure what they cost or how easy they are to fit. I did not want to do any major work to the party wall (casing in pipes) or pulling up flooring. When I did it, I think the total cost was less than £200 including the DPS, the DP RCD, pipe and fittings (sill have a load of the pipe left), new mixer tap with the shower attachment and pump. If I was building a new place, I may well do things differently, not sure. I like the simplicity of my system, and the reliability has been excellent. Without having ever seen, let alone tried a venturi system, I cannot really comment on them.
  7. The main problem is making sure there is enough space around the cylinder to add insulation. But that is a problem with all insulation. Just treat it as you would a house, insulate and make airtight. The other thing I have noticed about all the cylinders in all the houses I have had, the immersion heater has always been fitted at 90° to the opening. So basically, up against a wall. This makes adjusting the thermostat hard, and in this house it would be impossible to remove and replace the element without removing the cylinder first.
  8. Basically yes. But if you insulate it well, then the losses are reduced. They are probably small compared to the cylinder losses though. It is all do to with surface area and temperature differences after all.
  9. You will. and should, put a pump in for a shower. Gravity fed showers need a lot of head, and generally have increased flow, which kills your storage capacity. There is a noticeable difference between winter and summer with my shower temperature settings. My header tank is in the loft, which gets warmer in the summer, means I turn the leaver down a bit. I am not convinced that fitting the header tank inside the heated envelope would make a huge difference overall. With a rental place you will be running the cylinder at 65°C anyway (legislation for legionella), so just work with that. It is easy enough to work out the heat losses, and how to mitigate them (just add 200mm of celetex inside the airing cupboard, make a larger cupboard, and don't forget the base and the top). Make sure the wiring is correct too. I like to keep things simple when designing; a header tank, an vented cylinder, an immersion heater or two, simple controls (on or off) and a shower pump. Can't get much easier than that for a DIY project.
  10. No, that is the whole point. I have a very basic vented cylinder for the hot water. From that a hot pipe goes to the bathroom for the basin and the bath. The pump goes after the Tee to the basin and just pumps the hot water to the bath mixer tap. A secondary cold pipe had to be fitted from the header tank to the cold side of the pump (as the cold was originally mains pressure). It seemed odd at first to have a pump running when filling a bath, but I got used to that. I could have fitted a separate shower mixer, and if it was a new installation I would have, but this was a quick and cheap solution to not having a shower. In a soft water area like mine, there is no need to ever worry about plumbing. Scaling up just does not happen and I think that is one of the biggest problems with plumbing. Scale is akin to having a huge variable resistor fitted to your electricity supply, and ever day you turn it down a notch. If you have hard water, you have to fit a water softener. No argument.
  11. My shower delivers at 11 lt/min. If I had plumbed it in separately from the bath, and fitted a different (larger) shower head, it would probably deliver 20 lt/min, as that is what is pumped out of the bath taps. I don't have a thermostatic mixer, just a cheap mixer tap with a shower fitting. Something like this: http://www.screwfix.com/p/swirl-deck-mounted-bath-shower-mixer-tap/41966 It does not give me any trouble at all. The pump is similar to this: http://www.screwfix.com/p/stuart-turner-showermate-eco-s-positive-head-shower-pump-1-5bar/58337 I fitted it over ten years ago and have not done a thing to it. Was a easy half days work to install, including running the cold feed from the header tank and fitting the RCD and DPS outside the wet area.
  12. You can get a system now that will do it remotely via your phone. Would it be possible to fit a larger IWH supplying water hot enough for a shower and with a large enough flow. Then, using that same IWH, pipe of to the kitchen and ad another inline water heater to boost it up a bit further. I would seriously consider an E7/10 (or funny Scotch tariff) for DHW. The standing losses from an ordinary cylinder can easily be reduced by fitting secondary insulation. Not a hard job if you do it at the time of fitting (not that hard to retro fit either). Just seen your post Crofter. I fitted a small shower pump from Screwfix (the smallest they do) and I have a good shower. My system is a vented one and so far has not given any trouble at all. A Header tank and 200 lt cylinder, a hot pipe off it to the bathroom, tee'd off to the basin and the bath/shower, an inline pump under the bath (does hot and cold), to the bath taps and the shower. Easy and simple.
  13. What is the 14 consecutive days that the EHO is saying about. Is it a real thing, or just something that they like to work to? It should be possible to send in data from when there is a problem, not when there isn't surely.
  14. But should they make a financial contribution to society, smokers, drinkers and drivers all do.
  15. In the UK most people are, and there is always LPG. Then there is electricity. Not many houses are without it. It is easy to find an exception to most things, and very easy to do nothing because of that exception. But that isn't the point of legislation. Even when it can unknowingly greatly affect the health of the only person that is using it? On that argument it is OK to dump any pollutant in a 'sparsely populated area'.
  16. May be worth getting to grips with a basic CAD package. You can do all sorts of designing on that. Most of us that do use CAD packages will have our favourites, but Google's SketchUp is a good start. (It may be worth the 'Forum' choosing a basic open source 3D CAD package and then giving tutorials. Swapping ideas would be easy then Just a thought).
  17. I seem to remember that housing takes up about 2% of the land area (not to be confused with urbanisation at about 9%). I think the real problem is that the general public dislike new housing near them. By its very nature it is going to be near someone. The planning people probably have the same view and just use the planning rules to reinforce it. There is also a difference between releasing land and affordable prices. I am not sure that they are directly connected (correlated). It may seem they are on the basic data, but that can be very misleading.
  18. Not quickly, but with some research I possibly could. Just reread your question and worked out what you mean, the answer is 'it all depends on what you want to show, see my average car price I think there are several issues getting mixed up. This is not an argument about either cars or stoves, or smoking or not smoking. Particulate air pollution is a cumulative issue, bit like lead poisoning, so reduction from any source is a good thing. Academics, and the wood burning industries, should be chasing funding, that is how science works. If you think the scientific process is all wrong, then that is a different issue and one unrelated to the data collected. Especially when you see the 'indoor' figures. They confirm a calculation that @JSHarris did a while back, about the same as 50 diesel vehicles pumping the particulates into a living room.
  19. Average prices of 'stuff'. There are at least six ways of working this out. You need to take the mean, median and mode prices and then compare those to the volume of sales. So taking two cars, a Fiesta at 12,000 and a Bugatti at 1,500,000, gives you a mean price of 756,000 Now take 3 cars, a Fiesta at 12,000, a Bugatti at 1,500,000 and a Scenic at 22,000, mean price is now, 511,333, but the median value is 22,000 Now 5 cars, Fiesta at 12,000, a Bugatti at 1,500,000, a Scenic at 22,000 and a BMW 3 at 22,000 and an Auris at 22,000 Mean price is 38,9200, median is 22,000, and there is now a mode price of 22,000 This would change drastically depending on car sales. Say that 50% were Fiestas, 30%, BMW 3, 19% Scenics and 1% Bugatti and 100 cars were sold, then the prices are: Mean price is now 31,700. So when talking about an average price, especially when correlating it to another price, think carefully about what you actually mean.
  20. About time this started to go mainstream. https://www.newscientist.com/article/2119595-wood-burners-london-air-pollution-is-just-tip-of-the-iceberg/ By Michael Le Page Last week, air pollution in London soared to heights not seen since 2011. The usual suspects were named and shamed, including traffic fumes and a lack of wind. But joining them was a surprising culprit. “We think about half of the peak was from wood smoke,” says Timothy Baker, part of a team at King’s College London that monitors air pollution. The trendy log-burning stoves producing much of this pollution are marketed as a source of renewable energy that can cut fuel bills while helping reduce global warming. But recent findings suggest they pose a serious threat to the health of their owners, and are also accelerating climate change in the short term. If nothing is done to discourage log burning in homes, it could become the biggest source of air pollution in cities like London. In the UK as a whole, wood burning is already officially the single biggest source of an especially nasty form of air pollution. “I love sitting by a log fire as much as the next person but maybe we need to think again before it’s too late,” says climate scientist Piers Forster of the University of Leeds, UK. Air pollution is awful for our health. The smallest particles get into our blood and even our brains, increasing the risk of many disorders including heart disease. Natural killer Children are especially vulnerable: high pollution levels impair their lung and brain development. Air pollution from all sources is estimated to cause some 10,000 premature deaths a year in London alone, where it frequently exceeds legal limits. Wood smoke may be natural, but it contains many of the same harmful substances as cigarette smoke. It’s a massive killer worldwide, causing as many as 4 million premature deaths every year through indoor air pollution. In the UK, however, the problem with pollution from wood fires was thought to have been solved by clean air laws introduced in the 1950s, which banned wood burning in open fires in cities. “The official view is that residential wood burning is a thing of the past,” says Gary Fuller of King’s College London. Yet logs can still be burned in officially approved stoves in cities. Sales of these stoves have soared in the past decade, rising to nearly 200,000 a year. They are marketed as a way for people to drastically reduce their carbon emissions and save on fuel costs. Even modern stoves described as “low emission” are highly polluting. And in an echo of the diesel car emissions scandal, measurements during actual use in homes show that the stoves produce more pollution than lab tests suggest. In the “smokeless” fumes coming from the chimney of a house with a modern “eco-friendly” wood burner, Kåre Press-Kristensen of the Danish Ecological Council has measured 500,000 microscopic particles per cubic centimetre. The same equipment finds fewer than 1000 particles per cm3 in the exhaust fumes of a modern truck. The wood stove was certified as meeting Nordic Swan Ecolabel emission standards, which are stricter than the ones stoves in the UK have to meet. Big in London What this means is that a small increase in wood-burning stoves can produce a big increase in pollution. In Copenhagen, a city of 600,000 people, just 16,000 wood stoves produce more PM2.5 pollution – the most dangerous particles, smaller than 2.5 micrometres – during winter than traffic does all year round, says Press-Kristensen. Wood burning is becoming a big problem in London, too. In 2010, when Fuller analysed particulate pollution to discover its source, he found that 10 per cent of all the city’s wintertime pollution was from wood. There are many reasons to think that figure is higher now. A 2015 government survey found that domestic wood consumption in the UK was three higher than previous estimates, with 7 per cent of respondents reporting that they burned logs. “Wood consumption is increasing substantially,” says Eddy Mitchell at the University of Leeds, UK. When he, Forster and others fed the data on wood consumption into a computer model of air pollution, their conclusion was disturbing: PM2.5 pollution from residential stoves is soaring in the UK (see diagram, below). “There is a real risk that if we have a lot more residential wood burning then it could undo our other efforts to control air pollution,” says Fuller. The harm far exceeds traffic pollution, he says. While people are exposed to high levels of traffic pollution mainly when travelling on busy streets, wood burning produces huge amounts of pollution where people live, when they are at home. Indoor smog Press-Kristensen has been measuring that pollution inside homes in Copenhagen. In three out of seven tests done so far, he has found very high levels. In one home with a modern log-burning stove, he found particulate levels several times higher than the highest ever recorded outdoors there (see diagram, above). So do the health impacts outweigh any climate benefits? Astonishingly, there might not be any climate benefits, at least in the short term. Burning logs is often touted as being carbon-neutral. The idea is that trees soak up as much carbon dioxide when growing as they release when burned. In fact, numerous studies show that wood burning is not carbon-neutral, and can sometimes be worse than burning coal. There are emissions from transport and processing. Logs are often pre-dried in kilns, for instance. Burning wood also emits black carbon – soot – that warms the atmosphere during the short time it remains in the air. Most studies ignore this, but Mitchell and Forster calculate that over 20 years – the timescale that matters if we don’t want the world to go too far above 2°C of warming – soot cancels out half the carbon benefits of all wood burning. For home wood burning, the figures are even worse. “On a 20-year timescale, wood stoves provide little or no benefit, but they do on the 100-year timescale as they remove some of the long-term warming effect of CO2 emissions,” says Forster. Press-Kristensen’s calculations show much the same thing. And both sets of findings almost certainly underestimate the problem, because they assume wood burning is carbon-neutral. Defenders of wood stoves point out that there is a lot of uncertainty about how much black carbon is emitted when wood is burned and how large its effect is. Patricia Thornley of the University of Manchester, UK, thinks we need more real-world measurements before coming to conclusions. But the uncertainties cut both ways. For instance, the effects of black carbon can be amplified if it is deposited on snow and melts it, exposing dark land that absorbs more heat. It’s possible soot from wood burning is contributing to the fall in spring snow cover in Europe, but it’s very hard to study. More research is needed to pin down the precise climatic effects of wood burning, which can vary hugely depending on factors such as the source of wood and where the pollution goes. What is clear, however, is that burning logs in homes in towns and cities is not the best use of the wood we have. It produces more pollution than wood-burning power plants that can be fitted with expensive filters, it produces that harmful pollution where lots of people live, and it has the least climate benefits, if any. “If we are going to burn biomass to meet climate targets, then we ought to do it in big, remote power stations,” says Martin Williams of King’s College London, who is studying the health impacts of the ways the UK could meet its climate targets. Most researchers say it isn’t their role to make policy recommendations, but it would be best if cities like London discourage private wood burning before it becomes an even bigger health problem. At the moment, all the focus is on diesel vehicles. Press-Kristensen doubts governments will ban wood-burning; France recently backtracked on a proposed ban on open fires, for example. Instead, he proposes installing heat sensors in chimneys and taxing people when they burn wood, with the level of tax depending on how polluting the appliance is. Most importantly, governments must not ignore health impacts when deciding climate policies, says Press-Kristensen. “I like fires, but I have to say they are as polluting as hell,” he says. Thinking of getting a wood-burner? Wood-burning stoves are touted as an eco-friendly way to heat your house cheaply. But tests now show that even new, properly installed stoves can produce dangerous levels of outdoor and indoor pollution (see main story). What other options are there? Consider instead Stick with gas or oil for heating, and spend your money on insulation. Get a heat pump if you can afford it Fake it You can get the same cosy feeling from a log-effect electric or gas fireplace, the best of which are hard to distinguish from the real thing Already have a wood-burner? Here’s how to minimise its effects: Don't burn scrap wood Scrap wood or painted wood can release highly toxic substances such as arsenic when burned Burn wood that's just right Burning dry wood with a moisture content of about 20 per cent minimises pollution. But if wood is wetter or drier than that, pollution increases
  21. I assume you mean 111 kWh/month rather than 111 kh. DHW should be between 1 kWh and 4 kWh /day per person (short shower or full bath). So if we call that 3 kWh/day for the two of you, that is 90 kWh in DHW, leaving 40 kWh for the space heating. Seems pretty good to me.
  22. Right, let's escalate this further' "Ho Ho Ho, it's the first of May, outdoor f****** starts today" Sent by text from a female friend.
  23. If it stays in the garage, then the summer will be a good one. You can tell it is based on a Vitesse by the way the rear wheels point; inwards. Better turning circle than the TF though. Can you squeeze a Triumph 2500 PI under the bonnet? my Father had a TR6, seemed quite fast back in the day (Probably no faster than my C-Max TDCi).
  24. What is the kit car? And the site looks a bit different than it did when I came over. And how did your builders not get soaked, it has been horribly wet down my end of the county.
