SteamyTea
    198
  1. Ah, why would you do that. Space heating and DHW are different things, they work at different temperatures, and different times. Have you actually done an analysis of your DHW needs?
  2. Does not have to be. That is usually a symptom of an undersized unit, or one that has had the kids bikes thrown against them too often.
  3. Our old mate, Jeremy Harris, made up his own water treatment system for his borehole. Was basically a sand filter and then bubbling ozone though the the pressurised part. I think he found out most of his stuff from the USA, where they use boreholes a lot. Can you get enough rain that is storable in reality?
  4. See Nick's reply higher up. Seems an easy solution.
  5. They are for bolting the extra sturdy manacles.
  6. They will soon make a mess, they put more on the floor than anywhere else.
  7. 0.001167 kWh/litre.K / kW
  8. Are you going to get an interim airtightness test before you close everything up?
  9. Get the airtightness sorted. All the rest becomes a smaller problem.
  10. FFS, you can calculate that.
  11. "Standard" insulation levels are pretty good in reality, that isn't really the problem. Though increasing the level in the largest surface areas, or the coldest side of a building can pay dividends. Air tightness is more than just stopping drafts, you don't want cold, outside air, to be able to bypass the insulation and get behind any interior surfaces. This is why building a are wrapped in Tyvek, or similar. They let moisture out the insulation, but don't let the wind or rain in. But because it is harder for water vapour to escape, we reduce the amount by fitting a vapour control layer, which is anything that is basically gas tight. This is not to stop drafts. I shall repeat, this is not to stop drafts (I hope I have spelt draught right). It is purely there to reduce the air mass in the house, which will be at higher absolute humidity and higher temperature than the outside, escaping. This is why MVHR is fitted. Basic fans can be used to just expel the moist air, but why throws the energy out with it. You can still open windows if you want to. So basically, it is not a trade-off with one thing or another, it is a combination of all things. Like a car, I can get away with budget tyres on my low powered C-Max as it is driven steady, but if I had someone else's Porche, or C-Max for that matter, I would expect decent tyres as I know I would drive it like a (expletive deleted) at their expense.
  12. Do you mean compare the kWh used, a gas system will not use much electricity. What puts most people off then comparing is the "known unknowns". Or the weather and build quality. Weather can be calculated pretty well within small errors, build quality can't. Why it amazes me that people don't get an interim air test done while it is still possible to easily fix things. £250 for a test, people spend more on a tap.
  13. There was almost certainly going to be mission creep when it was announced that no new had boilers could be fitted. Same will happen with cars, pure ICEs will be banned, and like CDs, the hybrid will be a short lived format. The CEO of Stellantis had already said that it is legislation that is forcing the EV route. There really is no need to continue developing combustion technologies now, our the resources into HPs and better building testing.
  14. It is worth asking the question "What are you trying to achieve?" Are you after the cheapest system to buy, run, claim subsidies, lowest energy use, reliability, comfort levels, etc. I often see a price comparison, never an overall energy usage. If heating was purely down to price, then open fires, burning rubbish, with a large kettle to boil water in, would be the easy option.
  15. This, without doing the calculations, would be my concern. Not sure if there is any real advantage, except in lightweight, prestressed concrete construction.
  16. Good old Wikipedia explains why they are called what they are. My Father was an electrical engineer, a dreadful commutator. The origins of electromechanical inverters explain the source of the term inverter. Early AC-to-DC converters used an induction or synchronous AC motor direct-connected to a generator (dynamo) so that the generator's commutator reversed its connections at exactly the right moments to produce DC. A later development is the synchronous converter, in which the motor and generator windings are combined into one armature, with slip rings at one end and a commutator at the other and only one field frame. The result with either is AC-in, DC-out. With an M-G set, the DC can be considered to be separately generated from the AC; with a synchronous converter, in a certain sense it can be considered to be "mechanically rectified AC". Given the right auxiliary and control equipment, an M-G set or rotary converter can be "run backwards", converting DC to AC. Hence an inverter is an inverted converter
  17. 1 They won't work with an ASHP. 2 They won't work. 3 They will stop working. Physics wise, the thermal losses will be higher than a single cylinder. Is there enough room to 'box them in' with insulation?
  18. Never ever take your own advice. I would still be a prisoner if I did the things I suggest to others.
  19. Yes, but it is still a nonsense term in my opinion. Why I dislike it. Engineering needs clarity, just like other industries, with the IT field being the worse, apart from Chemistry that is, they just make up long words to sound impressive (and spray spittle over everyone). Why don't they just call it a converter.
  20. It is a dreadful, and not very descriptive, term. It will mean different things in different installations i.e PV or HP. And then there is the common usage meanings. If I invert my mug of tea, I then need a cloth to clean up. If I invert my partner, I get told off on here. So, if you invert a DC current, all you are really doing is reversing the electron flow (which isn't a real flow as such, more a jiggling). But if you invert your HP, you vary the power capability. A stupid term.
  21. From whom. It seems to be one of those zombie myths that will just not die.
  22. Used to deal with WP on a weekly basis, found them very helpful and understanding. Not sure what will happen now that National Grid has taken them over, I notice the signage has been taken down on the local office.
  23. Welcome Get a security camera on your build, who knows what may turn up.
  24. Welcome @joe90 is mid century.
  25. It is sealed off like Royston Vasey at the moment. A camp has been built between PZ and Helston for the extra security staff, helicopters and extra police cars about. Almost like London after 7/7. Drains and lampposts have been inspected and tagged, and the larger potholes in the A30 repaired. Still wondering who is going to fly into Newquay, or Lands End International. Probably into the Base at Culdrose. Except a plane crashed near there the other day. I would have put them all at Lands End, then just cut that bit off from everyone. One road and two footpaths, easy. And plenty of space to land helicopters.
