SteamyTea
    200
  1. So tomorrow night for my surprise.
  2. @Pocster offered me a cream pie.
  3. The old MKS system will do, if you can make it fit. Maybe the GMS will work.
  4. My place is TF, while I have no mortgagor, my neighbours do. There are literally 10s of thousands of TF places in Cornwall, all seem to get mortgages easily enough.
  5. Shall have to post it up on my TOR server then.
  6. Is the Shelley used with a mechanical switch? Think you said something about an overflow. If so, could it be switch bounce causing a problem?
  7. I thought that, then thought of @Pocster's trousers. It is probably ab ESP32 type board, so this may help. https://www.reddit.com/r/esp32/comments/1birg1q/design_question_internal_pullup_resistor_or/
  8. I posted it up as a pdf, not sure why I can't find it now.
  9. Show us the circuit. Or try a 1 mega ohm.
  10. That will be a 2m by 3m shed so an area of 6m2 You are after 4m by 6m, so 24m2. 4 times the size, not double.
  11. The options I showed. This is often the problem with energy comparisons. I wonder if anyone has correlated the efficiency of MVHR against HDDs.
  12. That was my thinking. By maybe we should say it could/should have been. A warm room is just a tilted wall after all.
  13. Compared to what though. May sound an odd response but you would save the running costs by switching your MVHR off and the building airtightness would remain unchanged (may get a bit smelly indoors). Doing that is not the same as comparing a house with an ACH figure below 1 with MVHR and a non MVHR house with an ACH figure of 7. Volume of the house makes a difference as well.
  14. There is a fig tree in Moron Gardens that I always admire, thought about pinching a fruit and seeing if it grows in a pot. How long a cutting would I need to take to get a successful cutting?
  15. Does B&Q still have a pensioner day on a Tuesday. Failing that, a Garden Centre.
  16. Make sure you have CIL exception if it applies in your area. Download the latest Building Regs and keep reading them. Plan your build to comply with them (use their examples if you can) then Building Control should not give you too much trouble.
  17. It is hard to get two hinges perfectly in line with each other, each hinge has three degrees of freedom, so two hinges have 9 and 3 hinges 27. So what happens is that a slight misalignment causes movement in at least one hinge, but most probably in all 3. This causes the screws to be stressed and start to damage the timber they are screwed into. As for a fix, get all three hinges inline, properly, then use some non expanding PU adhesive down the holes in the frame. Spray the screws with a bit of WD40, screw it all in place and wait till the adhesive cures. Do not overtighten. The WD40 will act as a release agent for when you need to remove the screws.
  18. Half of the originals are alive. If you want to see pensioners, just come to Cornwall in September.
  19. Welcome. I like doing things 'on a budget'. Seems a lot of the self build expenses are the non building things like surveys and professionals fees.
  20. Welcome. Trying to help him makes me wince. But he is the expert at unblocking SaniFlo's.
  21. My Russel Hobbs induction hob can also be wired in as, what I think is really called split phase (2 of the 3 phases), but I have it wired in as single phase. I asked @ProDave to confirm. I did post the question up a few years back. I have not melted anything yet. As an aside, I bought some cheap Russell Hobbs kitchen knives, fiver for 3. They look identical to the ones from ProCook that cost 4 times as much, each. I can testify how sharp they are.
  22. Does the local West Indian community call that pub 'The Batty Boy' by any chance.
