50mm liquid screed UFH with Sunamp as storage
SteamyTea replied to westcoast's topic in Underfloor Heating
Non, no one has. -
Easy fix. Give a Tim almost 500 quid and he goes into the loft with a black box, comes out later with a dirty black box. Trying work out when in was fitted, probably 25+ years ago. So no real complaints.
Discount Offers of the Week
SteamyTea replied to Ferdinand's topic in General Self Build & DIY Discussion
Maybe, will it help cure my morning wood? -
Because it is a phase change material, the vast majority of the energy is stored at the phase change temperature. I am not sure, but think that 'over charging' causes the pouches to expand, this can cause damage. That is more a case of under charging most of the time. That would need some numbers. No point over charging the screen if the inside temperature of the house goes too high, with the inevitable window opening to counteract it. My house has storage heaters, the small, 1.5 kW (10.5 kWh) one has a mass of about 60 kg. -
What temperature should my hot water be set at?
SteamyTea replied to Mike_scotland's topic in Boilers & Hot Water Tanks
Seem the main concern should be going to Thailand. With around 300 cases a year, and very few fatalities, it is getting to such low levels, we should be worried about putting the phone charger in a socket. Things have to be kept in perspective, being at work is much more dangerous. Key figures for Great Britain (2020/21) 1.7 million working people suffering from a work-related illness, of which 822,000 workers suffering work-related stress, depression or anxiety 470,000 workers suffering from a work-related musculoskeletal disorder 93,000 workers suffering from COVID-19 which they believe may have been from exposure to coronavirus at work 2,369 mesothelioma deaths due to past asbestos exposures (2019) 142 workers killed at work 441,000 working people sustained an injury at work according to the Labour Force Survey 51,211 injuries to employees reported under RIDDOR -
I suspect below the 6A limit there charging efficiency is impaired. Be a bit like heating your water up from 10°C to 25°C. Not a lot of use in reality if 25°C was all you can get.
Bit bored this morning, so thought I would look up about domestic legionella infection risk. First line 'very uncommon' https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/635817/Investigating_Legionella_household_settings.pdf Seems your hosepipe is a risk as well. As is the screenwasher on your car. https://www.sciencedaily.com/releases/2014/05/140518164421.htm Here are the numbers for the UK. https://www.gov.uk/government/news/latest-legionnaires-disease-data-published-for-england-and-wales -
Not a bargain, not even bought from them, just wanted to bookmark the site as they have an excellent range of adhesives. https://www.gluesdirect.co.uk/catalog/index.php Including D4 PVA. I was actually looking for this stuff https://www.ebay.co.uk/itm/175248623735 Used it in the past and works a treat. -
Seems most advice for these Aqualisa us to turn it off and on again. Shall do they I the morning when my mother is asleep, and not watching murders in Midsomer (filmed locally). The blue light is doing a short, then medium and then two long flashes. Or a long then short, then medium then long again. Can't find anything on Google about flash codes.
No, still flashing after turning the only MCB that says Hot Water.
@joe90 @Radian @ProDave I shall go looking for a switch, or something in the consumer unit. No idea if it limits the temperature, hardly used this shower. Not a house I have been in much, until recently.
@joe90 Yes, all the rest works, even the similar shower in the next room. I have a distant memory that it has done this before. Almost as if something has got in the pipe and blocked it. Odd thing is, can't turn it off.
The shower worked fine this morning. After a day if painting, I went to use it. Pressed external button, water flowed, but did not heat up (combi boiler). Then the water stopped. Blue light is still flashing. Tried sucking in the pipe, nothing seems to be moving. VID_20220508_184223519.mp4
Small claims for metal roofing defects?
SteamyTea replied to DragsterDriver's topic in Party Wall & Property Legal Issues
That is rough. Taking a guess that they have never fitted it before. Is that something you can check out? Plan for the worse, hope for the best. -
Welcome. I am intrigued to know what a 'property developer' actually is. Seems to cover everything from someone renting out a house, to a large corporation building 1000+new homes. As far as I can see, at the lower end, it tends to be chancers. So why not go and work for a property developer for a year or two, see what it is all about.
Are solar panels worth it with my roof and sloping direction?
SteamyTea replied to MrTWales's topic in Photovoltaics (PV)
About 2000 kg. -
Not late. But at my mother's now.
Does anyone know how quickly a BMS reacts to a burst of PV power. Seem to remember someone mentioning there system was still exporting because the battery did not turn off the instant the load was removed i.e. it saw the grid as a load. Wonder if it has the same time delay to a charge. -
The head looks level. Short night for me, alarm set for 4am.
I would use a decent rule, not the ruler in the picture (that is one I had at school, so probably 50 years old now). Accumulative error is a problem, but this is for a house, not precision engineering. If you fit, say that curtain rail dead level, it would show that the ceiling isn't, or the windows. Really just a case of creating a datum and working from that as best you can.
