Or polyurethane.
Double up the wall thickness and get a decent U Value. Durisol going will the the ICF industry a favour. But as it is just a garage, why not block and render.
Distributed battery power banking
SteamyTea replied to Radian's topic in Networks, AV, Security & Automation
The hotspot in my cheap Motorola phones has a fantastic range. Not sure how long the battery would last moving data about, may give it a go oneday. The reason I mention this is that they are low powered, have battery storage, charge controllers, screen and networking via USB built in. And for 20 quid a month 100GB of 4G connectivity. So for a grand, you get 50 months of usage from an old phone. The NAS can be a large SD card (trying a 256 GB one in my camera at the moment). Just a thought. -
When Part P came into force, couple of places I was working on, Building Control allowed the sparks to work to the older regs, as long as they had already started.
aroTHERM Plus DHW Flow Temperature
SteamyTea replied to Dan F's topic in Air Source Heat Pumps (ASHP)
Is 70°C a function of the refrigerant gas? May the be upper limit to make the compressor more efficient. Maybe the lower limit is varied i.e. between -30°C and 0°C. Does changing the water flow rate make any difference? -
Anyone identify this door handle manufacturer?
SteamyTea replied to Bemak's topic in Doors & Door Frames
https://www.isaaclord.co.uk/product-category/ironmongery/door-furniture/?pa_categories=levers-on-rose -
44% being ready could be considered a success in the building trade. We all know that 90% of builders are (expletive deleted)wits and chancers.
Best model acoustic insulation for studs and joists?
SteamyTea replied to ashthekid's topic in Sound Insulation
Sculpted sound 23 March 2002 By Philip Ball PUBLIC sculpture is all very impressive to look at, but what use is it? It just sits there providing a perch for pigeons and a backdrop for tourists’ photos. But a few years ago, Francisco Meseguer of the Institute of Materials Science in Madrid found an unexpected answer. He discovered that a minimalist sculpture on display in Madrid can block out sound. Erect such barriers throughout a noisy city or along the sides of a motorway and the tumultuous modern world might not only become a quieter place, but a more attractive one too. The structure he stumbled across is called a sonic crystal because it scatters sound waves from a periodic array of “atoms”—anything from glass spheres to metal rods. Unlike conventional, solid sound barriers, sonic crystals are mostly empty space. And they’re a lot easier on the eye, too. Now Meseguer and his colleagues have shown that these structures can do a lot more than simply block sound. Sonic crystals can shape and manipulate sound as if it were putty, reflecting, bending and filtering it in unexpected ways. They might even transform unpleasant environmental noise into something far more soothing. And the Spanish team hopes to make similar structures for controlling other kinds of unwanted vibrations. In the grandest and, by their own admission, the craziest of such schemes, they think it might be possible to build gigantic sonic crystals that dampen seismic waves and protect buildings from earthquake damage. Meseguer first stumbled across sonic crystals while he was working on tiny structures called photonic crystals. Developed in the 1980s, these can be used to manipulate light, and are now being turned into devices such as lenses and fibres for all kinds of optical communications technology (New Scientist, 12 June 1999, p 36). One of the simplest forms of photonic crystal is simply a block of silica with a regular array of holes drilled in it. The difference in refractive index between the silica and the air in each hole means that light is scattered at the boundary where they meet. Make the distance between the holes about the same as the wavelength of light shining on it and the scattered photons interfere destructively. Simply put, the crystal blocks light in that range of wavelengths. It has a “photonic band gap”. Nowadays, photonic crystals are often made by allowing microscopic glass beads to settle out of a suspension into organised lattices called colloidal crystals. Structures like these form in nature too. The iridescent appearance of opal, for instance, comes from the light-scattering properties of the tiny silica spheres that make up its lattice. For photonic crystals with band gaps in the visible region of the spectrum, the holes or spheres must be a few hundred nanometres apart. But in 1995, while Meseguer was chatting with acoustics expert Jaime Llinares of the Polytechnic University of Valencia (UPV), they realised that if these structures were scaled up to centimetre dimensions—corresponding to the wavelength of sound—they might be able to create an acoustic analogue of a photonic crystal. Inside their imaginary sonic crystal, the scientists reasoned, sound waves should bounce off the “atoms” in such a way that the waves interfere destructively, cancelling out the oscillations in the air. Llinares suspected that some form of sonic crystal might already exist. He remembered that on the UPV campus there was a sculpture by the Spanish minimalist artist Eusebio Sempere, made from an array of vertical metal bars of various lengths, of about the right thickness and spacing, like a set of surreal organ pipes. Could this block sounds? To find out, they placed a loudspeaker on one side of the sculpture and a microphone on the other. The speaker broadcast white noise through the sculpture, but when they measured the intensity of the sound on the other side, there was no sign of a band gap. The problem, they decided, was that the sculpture was made of hollow metal cylinders which resonated like organ pipes. Since some of the pipes were very short—about 10 centimetres, the same as the separation between pipes—they were resonating at frequencies inside the expected acoustic band gap, and this vibration masked the gap. Fortunately, Sempere had constructed a similar, but larger bar sculpture, on display at the Juan March Foundation in Madrid. In this outdoor sculpture the pipes are up to three metres long. The two researchers set off with their loudspeaker and mic to try again. This time they found that the sculpture actually blocked out sound. It wasn’t a perfect “crystal”, however, so the acoustic band gap was rather leaky. Worse still, the measurements were muddied by noise reflected from nearby buildings. To improve their data, the researchers decided to make their own minimalist sculptures by hanging cylinders of stainless steel or wood from a frame. This created a regular forest of bars that wouldn’t look out of place in any modern art gallery. In 1998, instead of entering it for the Turner Prize, they mounted their crystal in an echo-free acoustic chamber and began experiments to measure how sound travelled through it. Their data revealed that the structure strongly suppressed sound waves in the audible range, at frequencies between 1400 and 1700 hertz. At last they had clear evidence of a sonic crystal. Just months ago, the team also revealed how sonic crystals could be used not only to block sound but also to manipulate it (Physical Review Letters, vol 88, p 023902). At frequencies below the acoustic gap, sonic crystals are transparent to sound. But they don’t let sound waves pass unscathed. Just as light is bent by refraction when it passes from air into glass, so sound waves are bent when they pass into a sonic crystal. The researchers realised that they could use this to create a lens that focuses sound. The lens they built is a convex array of cylinders (see Diagram). Put a sound source on one side and the lens focuses the sound waves on the far side. The focus is rather blurred, however, partly because the surface of the lens is quite rough—you can’t make a smoothly convex surface from a small number of cylinders, the structure is just too “grainy”. It’s like trying to make a lens from a handful of atoms. They also built an acoustic analogue of another common optical device: a Fabry-Pérot interferometer. This is made from a stack of thin films that create interference patterns when light reflects off each layer. The acoustic version is simply a “slab” of sonic crystal, with rows of cylinders hanging parallel to the flat faces of the slab. Fabry-Pérot devices are commonly used in microwave technology as filters. But Jose Sánchez-Dehesa, a physicist at the University of Madrid who worked on the project, admits that it is not yet obvious where the team’s sonic analogues of lenses and filters might be used, because they are so large. The basic sonic crystal, however, which blocks sound waves within a tunable frequency band, might find all sorts of uses. Imagine a barrier made from crystals that are designed to have all the aesthetic qualities of a Sempere sculpture but which cuts out traffic noise on the far side. “Sound-deadening barriers could be an interesting application of our findings,” says Sánchez-Dehesa. They would be more expensive than regular barriers, because they’re more elaborate, but he argues that in residential areas they would be a definite improvement on “ugly concrete panels”. His colleague Juan Vicente Sánchez-Pérez at UPV is now planning to patent a prototype sound barrier based on an array of cylinders. Not everyone is convinced that sonic crystals offer any real advantages over conventional materials. Victor Krylov, an acoustics specialist at Loughborough University, believes that the sound barriers currently used along motorways and railways are at least as effective, and cheaper too. Certainly, the need to space the cylinders at a distance of about one wavelength is a drawback, because it means that sound-proofing structures have to be big and thick. In 2000, however, Ping Sheng and his colleagues at Hong Kong University in Kowloon showed that there might be a way around this. They made sonic crystals from a cubic array of lead balls just one centimetre across, each ball coated with silicone rubber and glued into the array with epoxy resin. It was a kind of giant sonic opal. This structure displayed acoustic band gaps for sounds with wavelengths of around 1 metre and 25 centimetres—wavelengths that are hundreds of times as large as the spacing of the sound scatterers. They attributed this unexpected effect to the rubber-coated balls resonating at specific frequencies—they vibrate like heavy masses attached to springs. Sheng’s colleague Che Ting Chan says the Hong Kong team are now making sonic crystals that absorb sound. They believe sonic crystals like these could be used to block sonar signals at sea, for instance. Make submarine hulls from this stuff and they would be invisible to sonar from ships or other subs. Alternatively, say Peter Matic and Narendra Batra from the Naval Research Laboratory in Washington DC, the acoustic gap might be useful for filtering out particular frequencies generated by heavy machinery. They aim to design multifunctional materials which can be stiff and tough as well as providing acoustic shielding. Build them into a ship’s hull and you might be able to silence the sounds of the vessel’s engine, making it harder for submarines to detect. Sánchez-Dehesa thinks it might even be possible to design barriers that change the quality of the sound as it passes through. Just as photonic crystals can filter the wavelength of light passing through, it might be possible to design a sonic crystal so that objectionable noise passing through it becomes more tolerable—even pleasant. “My goal is to look for a panel based on a sonic crystal that could transform bad sound on one side, like traffic noise, to good sound on the opposite side, like the sound of the trees or ocean waves.” If that sounds daring, it is nothing compared to another idea they are toying with. Since these materials work for light and sound waves, it should be possible to build a structure that can block or transform other kinds of wave—including seismic waves in the ground. Just as you can make a slab of material impermeable to light by perforating it with a lattice of tiny holes, so you might make the Earth’s crust impenetrable for seismic waves by drilling an array of huge holes in it. Surround a city with such a lattice, and you could shield it from earthquakes. “If seismic shielding could achieve an attenuation of two points on the Richter scale [a hundredfold reduction in energy], it would be great,” Meseguer enthuses. To test the feasibility of the idea, in 1999 Meseguer and his colleagues drilled two vertical lattices—one triangular and the other honeycomb-shaped—in a bed of marble in a local quarry. Each hole in these lattices was 6 centimetres across, 160 centimetres deep and separated from its neighbours by 14 centimetres. Then they created vibrations by dropping a steel ball bearing onto the quarry floor, and used sensors to measure how the vibrations passed through the lattices of holes. Both lattices significantly damped down the vibrations. However, to protect against real seismic waves, the holes would have to be hundreds of metres across and at least a kilometre deep. “It is clear that such a proposal is not feasible yet,” confesses Sánchez-Dehesa. “But you can protect an isolated building.” Used in this more modest way, underground “ring fences” of seismic crystals could make labs or buildings immune to vibrations such as those from passing trucks. This could be very useful, since some high-precision instruments—scanning probe microscopes for studying structure at the atomic scale, for example—are very sensitive to disturbance. Meseguer has already started looking at the practicalities of such a system. And who knows, one day these giant structures could become art in their own right. A sacred bird’s voice seems to be trapped in the very stone of the Mayan Pyramid of Kukulkan at Chichén Itzá, surrounded by the jungles of the Yucatán Peninsula in Mexico. Stand at the foot of one of the stairways that climb the outer walls, clap your hands and a chirp rings back at you from the stone surface. According to David Lubman, an acoustic consultant based in California, this is the sound of the quetzal bird, the spirit of the Maya incarnated in their plumed serpent god Quetzalcóatl. Lubman claims that it takes only a little imagination to hear in the curious echo from Kukulkan’s staircases the sound of the quetzal as it would have been heard by a Maya in the Peruvian cloud forest. This, says Jose Sánchez-Dehesa, may be an example of Mayan acoustic engineering. Architects have designed buildings since ancient times to generate and exploit particular acoustic effects, such as the whispering gallery of St Paul’s Cathedral in London. But this is engineering of a particularly sophisticated kind: for the Kukulkan staircases, with their periodic array of scattering surfaces, have many of the characteristic features of a sonic crystal. Could the Mayans really have known the secret of sonic crystals as long as 900 years ago? “I think the answer is yes,” says Francisco Meseguer. Sánchez-Dehesa agrees: “We can say that the Maya are the first people to harvest sound by making a sonic crystal.” And he hopes to prove it with a series of experiments at the pyramid. We may soon know whether the quetzal bird sings at Chichén Itzá by chance or design. -
Thinking off the top of my head, but isn't sound absorption more to do with scattering, interference and deflection? So it becomes a combination of density, flexibility and shape. I have often wondered if it is possible to make a relatively lightweight garden fence that deflects the outside noise back to the source, and even better if it could cause constructive interference. -
@saveasteading Could you make something like this. Probably need a simple jig to hold it all in place, then glue and screw/nail. Maybe @Gus Potter could have some input.
Punch the numbers into PVGIS and see what comes out. Then divide the price of the best estimate by the PV production to get the price per kWh. Then decide.
Painting wood with wood coloured paint - lessons with cetol 771
SteamyTea replied to markocosic's topic in General Joinery
Would it be worth pretreating all the timber with Cetol 771 as a precaution? -
https://www.menshealth.com/uk/sex/g31237678/best-sex-toys-for-men/
Anyone bought SWA cable from armouredcable.net?
SteamyTea replied to Radian's topic in Electrics - Other
Pay with PayPal or Credit Card. -
Rainwater Harvesting...
SteamyTea replied to Mulberry View's topic in General Self Build & DIY Discussion
So older members may recall that Jeremy Harris made an ozone pump for his drinking water. If RWH is purely for non drinking, maybe a simple generator pump and some fishtank aeration stones would keep the water sterile enough to stop most problems. May only need a few minutes a day to work enough. Better than sunbed tubes in my opinion as it delivers the oxidant right to where it is needed. -
Oh, my favourite saying. Along with 'hard earned'. If I wanted a decent job, I want it to be easy money, less hassle, close to home etc. Why should every worker have to suffer for a decent living. A quick way to create jobs is to damage the environment, then employ people to put it right. Or, take all the people that currently work in the 'unemployment' business, sack them, then reemploy from the ones that have no current job. Cycle this ever month. Cut costs and gets rid of unemployment. (our fixation in the Western World goes back 90 years to the Wall Street Crash and the unemployment that caused, sometimes called The Great Trauma) -
That is interesting. I generally agree that it is more efficient to do most things at large scale i.e. I can't get a quarter pounder out of a Dexter, without harming the Dexter. The thing with water though, well waste water, is out old shared road, house and foul water sewage system. Cornwall has an annual rainfall of 1100 mm. So take a roof of 50 m2, that is 55 m3 of water, that does not need treating, being treated. Now the treatment is probably very low cost, but the infrastructure to transport it to the plant, then pump it back to the dog shit strewn beaches, as clean water, is expensive. The price of each is probably quite hard to disaggregate from the wholes. -
How to wire my renovation
SteamyTea replied to FrankHouse's topic in Networks, AV, Security & Automation
200 W. How many things you got running? I have often thought this. Why I think every house should have a 0.5 to 1 Wh or storage and a small BMS/Inverter. Mass produced, probably only cost £200. Just plug them into a spare socket and over the whole country there would be 30 GWh of flexible storage. If power deliver was 250W, that is 7.5 GW of capacity for 4 hours. A useful amount. -
decorative Cat 6 LAN cables
SteamyTea replied to Adsibob's topic in Networks, AV, Security & Automation
Cotton reel and some nails. Used to make these when I as a kid. -
21 years ago was in the 21st century. The wiring should be OK. My house is 35 years old. Wiring is fine. Mother's house is getting close to 50 years, apart from a new consumer unit when my Father (an electrical engineer) wanted to add a couple of circuits, everything is original and in good condition.
Or just use less. Charging more usually works. -
Wind and solar. And lots of gas from the Plymouth plant, though I think my nearest non RE is the diesel generators in the Island of Scilly. -
Whoever supplies your electricity.
