Anyone remember the 1980s fad for stone effect cladding. Hardly see it now, that was meant to enhance the value. Regarding the 'moisture' problem. All houses have the same issues, just the better insulated and airtight they are, the more sophisticated the control of it has to be. 'Hydrogen Ready' reminds me of Windows 95 Ready. An OS that lasted 3 years before something better came along.
I have a vague recollection that non 13A loads i.e. anything hard wired, has to disconnect i.e trip or blow a fuse, within 5 seconds. This swapping over from grid to local storage may be a legacy of those rules. We tend to think that microprocessors, running in the gigahertz speed range is all that is needed. Probably find that power electronics cannot run at those frequencies reliably and sensibly. I may just be talking bollocks, but if it was simple, it would have been done.
Air Source Cylinder to power both hot water and underfloor?
SteamyTea replied to cee's topic in Air Source Heat Pumps (ASHP)
That all depends on the amount of stored energy, plus the power and time the ASHP is running, and the power the house needs to keep itself at the desired temperature. Though it isn't coming to work too well with a small Ecocent. -
Welcome. As a rule, before you start to think about replacement heating and water system, of any kind, you really need to establish what your requirements are. If you are living in the house, this is pretty easy to establish. Monitor you usage, either by manual meter readings or getting a data logger (not that hard to make one for electricity, but harder for gas). Then draw up your house and calculate wat difference any changes should make i.e. change a wall from U-value 0.8 down to 0.5. If the roof is good, and at suitable angles, get a basic PV system up there, this will always be useful. -
Yes. I think, since 2012/13 they have clarified. Did it specify the temperature resolution i.e. 0.1⁰C. Again, in reality not that important.
Please help me find a Structural Engineer in Cardiff
SteamyTea replied to Adsibob's topic in General Structural Issues
Not for a dog kennels or tree surgeon. -
Will it be worse than the bite? -
Is that 99.7‰ (or whatever) temperature distribution or time? I thought, from years ago when I was involved with MCS, that it was time. 8734 hours out of 8760 hours in a standard year. Not sure how much real difference it makes knocking off the third standard deviation on the cold tail of the OAT distribution in reality. Probably none, but it does depend on the variance (spread) kurtosis (tailedness) of the distribution, and skew (lopsidedness).
Here is a register that showed a few. https://www.istructe.org/find-an-engineer/members-directory/ I just set the location to Cardiff -
Is this the sort of work that can be done under a building notice? -
Heating controller and thermostat change
SteamyTea replied to James94's topic in Boilers & Hot Water Tanks
Even easier would be a standard control system. Similar to car pedals. It is really for the manufacturers to make a common standard, and stick to it. -
How much room do you have to play with? Mineral wool, blown cellulose or even poured polystyrene beads would all work well.
Have a look around the base of the cylinder and see if it has a boss blanked off. You could try setting the thermostat to the maximum it will reliably go to i.e. 85°C. Tat will at least allow more cold to be mixed with it at the tap. You can also time your usage to allow a decent recharge time that coincided with PV production, i.e. use before 10AM, usage after 2PM. Use less.
how to facilitate PV at future date?
SteamyTea replied to CalvinHobbes's topic in Photovoltaics (PV)
Why would anyone pay for a tree. Just dig up one the council has recently planted. What we pay our rates for isn't it. Can also pick up a nice, sturdy bench seat. -
I was asked the best time to plant a tree. "20 years ago. If you didn't, then today" PV is the same. -
Aim for zero waste. Bins become redundant then.
Any use https://sealsdirect.co.uk/
I think I read that article 15 years ago. Don't hold your breath. Have you compared the price of roof integrated PV compared to tiling/slating. Bear in mind that you will have scaffolding up anyway. -
MVHR is Largely Bogus
SteamyTea replied to DavidHughes's topic in Mechanical Ventilation with Heat Recovery (MVHR)
One of the problems the public have is caused by governments hanging their tune. "Greenest government ever" "Get rid of this green crap" Same bloke said it. So if a government says something will be done, or something must never happen again, we all know to ignore it.
