SteamyTea
    200
  1. Serious question. Do we know how my concrete?
  2. @Galileo While I understand your thinking about new modules and mono v poly in low light. I doubt there is enough difference to worry about. The main thing is what size inverters you can actually buy, they are not sold in 100W increments, usually in approximately 500W increments on the small ones and the 1kW jumps. The main thing that matters is that there is enough voltage for the inverter to start working, so the more modules in series the better. But then even small shading can hurt the output. If it is all too confusing to work out, then microinverters, 1 module, 1 inverter.
  3. An underground wank
  4. Good, hope it turns up quickly. Says 'out of stock' so that is a good sign.
  5. Get this one fast. https://www.ebay.co.uk/itm/394854400892
  6. I drove past there yesterday. Can't you find a similar model on eBay. What is the model number. Is it this one https://www.diy.com/departments/bosch-laser-distance-measurer/3165140791830_BQ.prd
  7. Happened down here at Cardis Bay after the G7. Not sure of they were removed or not. https://www.bbc.co.uk/news/uk-england-cornwall-60333927
  8. That is why roof integrated is used in new builds.
  9. That is quite impressive. How much PV you got, and how much extra would you need to get it to 99% Thinking about what @JohnMo did with his 'winter solar fence'.
  10. Will this stop jerky hand syndrome when going full screen VideoCore VII GPU, supporting OpenGL ES 3.1, Vulkan 1.2 Dual 4Kp60 HDMI® display output 4Kp60 HEVC decoder
  11. Do you think my Pi 1s are vintage yet, and worth a fortune?
  12. But we still have childhood diseases, and pitchforks.
  13. Just been reading about it. They have fitted an RTC, but no battery to back it up. And still no ADC.
  14. Just had one of my long journey thoughts. Why not use rope to tie the roof structure to the ground. Even small dingy boats have quite large sails, the sheet (sailor boy talk for a sail rope) is quite thin. Could easily be thinner but it would cut into fingers. When I went climbing I think the static lines were 6 or 8 mm. They could stop 80kg after a seconds fall without hardly stretching at all, thankfully.
  15. I seem to remember that the standard has an odd methodology. Heat and use the hot water right away, then measure the losses in the residuals. So say the cylinder ends up at 30⁰C, the airing cupboard at 25⁰C, that is a delta of 5 at the start, may end up, after 21 hours at 27⁰C and 21⁰C, so delta 6. Looked at it a decade ago when I added a load of extra insulation around my E7 cylinder.
  16. Did they not announce a new grant, when they decided that climate change was fantasy and we need 300 million more barrels of crude, or was that in Scotland only.
  17. Is it a flat roof?
  18. Think that is built in with a 100 MPH wind at ground level. Getting a bit technical, the energy in a moving fluid as it hits an area is proportional to the cube of the velocity. So should not be too hard to do a rough calculation based on downward force and uplift. Then add in some safety because, as you rightly say, the failure mode is important. I tend to prefer a failure to be in very small parts, like a toughened windscreen. It can take quite a wallop before catastrophic failure, but after that, the main missile has lost a lot of energy, and the tiny bits of glass are so low energy that they are, in effect, intrinsically safe (maybe a few scratches).
  19. Yes, saw that happening as I drove past your place 4 hours ago, thankfully the speed limit was raised up to 60 MPH today, no one wanted to see your goat and mofo.
  20. I don't comment on people's house designs, but I guess, from the look of it, you don't want PV.
  21. Could have been covered with some walk on glazing. Wasn't there a bit floating about on here that would have fitted perfectly.
  22. Want it coming on when the DHW is as cold as you can get away with. The heat transfer is better, the greater the temperature difference. I would hope a lot less than that, if not, add more insulation.
  23. How small is the car battery though. In my opinion, it is best to design your electrical needs to be as low as possible, both in power and energy. Only if that proves to be impossible, then consider 3phase. The use of local storage can mitigate the maximum power problem a bit as you can draw from the battery for an hour or so.
