MVHR controls mvhr old school automation Entry posted by Marvin January 31, 2022 7358 views Share https://forum.buildhub.org.uk/blogs/entry/912-mvhr-controls/ More sharing options... Followers 4 This is what my system controls would look like if I didn't have a computerised home automation system: Wait a minute, I haven't got a computerised home automation system! 2
dpmiller 1140 Posted February 1, 2022 But you do have the satisfaction of knowing where every wire goes and what the function of each relay, switch , or timer is. ? 1
JohnMo 4560 Posted February 1, 2022 Why does MVHR need complex control or even coupling to home automation. It's supposed to run at a constant flow 24/7, except when on boost? My option is you are making thing complex for the sake of it.
ProDave 9295 Posted February 1, 2022 Just make sure you document it all so the next person has a chance of understanding it.
Marvin 551 Posted February 1, 2022 Hi @JohnMo Your comment: Why does MVHR need complex control or even coupling to home automation. My opinion: An MVHR system doesn't have to have complex controls or coupling to home automation. HOWEVER, several issues have arisen with different parts of the building and these controls have been introduced over the last 4 years to overcome these, and also the control of water coils added to the ducts due to the lack of emitter (radiator) area required for the ASHP to function properly. Your question: It's supposed to run at a constant flow 24/7, except when on boost? My opinion: Your quite right. In fact if there isn't a constant flow of air through the system this can cause problems. HOWEVER, when required to boost (due to a humid shower room, or heavy cooking smells in the kitchen, or even after the loo has been used) this options speeds up the air flow to the whole building not just the effected areas. Your thought: My option is you are making things complex for the sake of it. My comment: Have you been talking to my wife? Actually there are valid reasons due to this building, its location and its use, as to why we wanted more controls. The main issues were heating and cooling requirements caused by solar gain because the windows are all east and west and the supply of either heating and cooling to combat the problems. Even if I was not able to add the controls I absolutely feel that a normal MVHR system is far better than no MVHR at all. And finally, I see in more expensive and more recent models that several of the problems are already integrated into the system. We bought a very basic model. Good luck M
Marvin 551 Posted February 1, 2022 4 hours ago, ProDave said: Just make sure you document it all so the next person has a chance of understanding it. At least they will not be able to complain to me as I will be dead. 1 1
Pocster 2518 Posted February 1, 2022 2 hours ago, Marvin said: At least they will not be able to complain to me as I will be dead. A man that takes a problem and claims there is no problem is a woman. A man that takes a problem and complicates it so it's a problem for another man is a CHAMPION! The said 2nd man needs to man up . 2
SteamyTea 5933 Posted February 1, 2022 2 hours ago, Marvin said: I see in more expensive and more recent models that several of the problems are already integrated into the system I want one of those. I work with people that make a simple job difficult.
joth 991 Posted February 1, 2022 This is what my MVHR control looks like (sensor.mvhr_boost_request is set true when the Hob is on, the showers are running, or a triple click on a bathroom light-switch indicates a big one has dropped) Quote alias: Set MVHR Speed description: '' trigger: - platform: state entity_id: sensor.mvhr_boost_request - platform: state entity_id: sensor.all_out - platform: state entity_id: sensor.night - platform: state entity_id: sensor.at_home condition: [] action: - service: fan.set_speed target: entity_id: fan.comfoairq data: speed: | {% if is_state('sensor.mvhr_boost_request', 'On') %} high {% elif is_state('sensor.at_home', 'Off') %} off {% elif is_state('sensor.night', 'On') %} low {% else %} medium {% endif %} mode: restart
MJNewton 453 Posted February 1, 2022 7 minutes ago, joth said: triple click on a bathroom light-switch indicates a big one has dropped All that automation and you have to press a button? I was expecting a rim mounted break-beam detector or something... ? 2
SteamyTea 5933 Posted February 1, 2022 19 minutes ago, MJNewton said: rim mounted break-beam detector Still illegal down here. Sometimes I feel we are living in the dark ages.
Pocster 2518 Posted February 1, 2022 24 minutes ago, MJNewton said: All that automation and you have to press a button? I was expecting a rim mounted break-beam detector or something... ? I reckon that can be made....
markc 1504 Posted February 1, 2022 31 minutes ago, pocster said: I reckon that can be made.... I’m not volunteering to adjust it 1
Pocster 2518 Posted February 1, 2022 Just now, markc said: I’m not volunteering to adjust it Tbh I looked at a way of boosting the mvhr when a ? is done . I have a manifold of manifolds so everything has its own pipework for water feed . Therefore in theory a “ flow sensor “ on the the toilet cistern pipework could trigger the mvhr boost . But I have a million much more fun / destructive HA things to implement at the moment. 1
Marvin 551 Posted February 1, 2022 1 hour ago, pocster said: Tbh I looked at a way of boosting the mvhr when a ? is done . I have a manifold of manifolds so everything has its own pipework for water feed . Therefore in theory a “ flow sensor “ on the the toilet cistern pipework could trigger the mvhr boost . But I have a million much more fun / destructive HA things to implement at the moment. Yes I bought a flow sensor but that went off every time you have a weeee. We have now resorted to a non latching pullswitch by the side of each loo with a time delayed relay to turn it off again. 1
Marvin 551 Posted February 1, 2022 5 hours ago, Marvin said: And finally, I see in more expensive and more recent models that several of the problems are already integrated into the system. We bought a very basic model. What I meant was, more recent models that already solve these problems.
Pocster 2518 Posted February 1, 2022 12 minutes ago, Marvin said: Yes I bought a flow sensor but that went off every time you have a weeee. We have now resorted to a non latching pullswitch by the side of each loo with a time delayed relay to turn it off again. Can it not differentiate between a big flush and little flush ??
SteamyTea 5933 Posted February 1, 2022 2 minutes ago, pocster said: Can it not differentiate between a big flush and little flush ??
Pocster 2518 Posted February 1, 2022 Just now, SteamyTea said: I’m none the wiser . Is a big job bigger than a proper job ?
SteamyTea 5933 Posted February 1, 2022 1 minute ago, pocster said: I’m none the wiser . Is a big job bigger than a proper job ? Who knows, I am a good Methodist.
Marvin 551 Posted February 1, 2022 37 minutes ago, pocster said: Can it not differentiate between a big flush and little flush ?? Not without measuring the Bowl contents
Pocster 2518 Posted February 1, 2022 9 minutes ago, Marvin said: Not without measuring the Bowl contents I see . Thought maybe it could measure the flow rate in the pipe over a period of time . Other than that install cctv in bathroom and set a ‘trigger’ zone over the pan . As a bonus get some nice footage
Marvin 551 Posted February 1, 2022 1 minute ago, pocster said: I see . Thought maybe it could measure the flow rate in the pipe over a period of time . Other than that install cctv in bathroom and set a ‘trigger’ zone over the pan . As a bonus get some nice footage Haven't you got anything better to do??? 1
Pocster 2518 Posted February 1, 2022 5 minutes ago, Marvin said: Haven't you got anything better to do??? This is important
40 Comments
Recommended Comments
