I want to put together a cheap internet radio, to link to the hifi, the main objective to be to listen to Radio Caroline that is only available on the internet.
So it needs a computer connected to the internet with audio output.  A Raspbery Pi?
I want this to be a cheap one trick pony, just turn it on and it will connect and play audio from Caroline.
I am a Pi novice so don't have a clue which version of the Pi I would need and how one would even set this up.  Is it even feasible as a "switch on and go" setup?  (I don't want it connected to a screen and keyboard for anything other than configuring it)
Just done this, built a single-channel, line out audio, internet radio, using a Raspberry Pi Zero W with a Phat DAC audio board.  When powered up it just connects to BBC Radio 4 via wifi and starts playing the stream, which feeds into the audio system.  The quality is pretty good, the only slight snag is that it takes around 30 seconds or so for the Zero W to boot up and connect to the stream.
I've probably scribbled down the details of the script I used somewhere, but if I didn't I can always SSH into the thing and copy it off.
That's exactly what I want to do. As a Pi novice I will no doubt need some help.  I do have a Pi kicking about, it's a model A iirc bought a long time ago for a project that never happened and has never been powered up. I will have to look at what it has and hasn't got to see if it is any good, otherwise buy the right one.
surprised it needs a DAC board, I just assumed as it was a "min computer" it would already have audio out.
It will be going in the same cupboard as the router, so a hard wired ethernet is available if that makes it simpler than a wifi connection.
The audio out on the bigger Pi is pretty rubbish, IIRC it's not got a DAC, but just uses PWM to generate audio.  The cheap Pi Zero doesn't have even the crude audio that the bigger Pi has, but the Pi Zero W only costs £9.30 and the Phat DAC £13.25, so even with the cost of the header it's still cheaper than buying a Pi Model 3 at £34.00.
I wrote up the stuff I used to get a single channel internet radio running, it seems (getting old, forgot I'd documented it!):
Quote
Internet Radio setup – Raspberry Pi Zero W
Simple version
Uses a Raspberry Pi Zero W, fitted with a Phat DAC that just has a line out audio connection.
Load an image of Raspbian Stretch Lite to µSD and edit by adding an empty file with the title SSH to the /boot/ section.
Set up WiFi by adding a Unix text file (created with Notepad++) to /boot/ called wpa_supplicant.conf that contains the following (Raspbian copies this from /boot/ to /etc/wpa_supplicant/wpa_supplicant.conf on first boot):
(see code excerpt below - the forum screwed up the formatting)
Put card in Pi Zero W and boot.  Find IP address and SSH in using Putty.  Change default password to a new password (for username pi).  Update using sudo update.  Install driver etc for Phat DAC using the following command:
curl https://get.pimoroni.com/phatdac | bash
Install MPD and MPC to stream and play via the internet:
sudo apt-get install mpd mpc
Get the current radio stream URL from here: http://steveseear.org/high-quality-bbc-radio-streams/
Add the following lines to the bottom of the /etc/rc.local/ file, using nano (just before the exit 0 line):
sudo nano /etc/rc.local
mpc clear   #clears the MPC playlist
mpc add http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_fourfm.m3u8  #adds BBC Radio 4 in high quality
mpc play    #starts the stream playing
The Pi Zero W should now play Radio 4 as soon as it has booted and acquired the stream.
Note that if using Windows you need to use a text editor that can create Unix-like text files.  Notepad++ works well and is free.
PS: Note also that Unix-like text files don't format properly in the quote function of this forum.  Here it is as a code insert (note that the SSID and password needs the inverted commas around them):
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=GB
network={
    ssid="your network SSID"
    psk="your network PSK password"
    key_mgmt=WPA-PSK
PPS:  If you have wired Ethernet, then you can use a USB to Ethernet adapter plugged in to the µUSB port on the cheaper Pi Zero (rather than the Pi Zero W).  The Pi Zero is a fiver, IIRC.
@ProDave did you ever get a chance to have a look at that internet radio I dropped off some time ago - just wondering if you could cannibalise anything from that?
I have spent hours on that. It works in short bursts, and that has whetted my interest in getting something to listen to Radio Caroline.  But I can't find any service information and am convinced I am never going to get that one working, hence this project.
I have just found the Pi that I have.
I did say it was the basic version available when it was bought at least 5 years ago.
It appears to have 2 USB connectors, a mini one labelled "PWR" and a full sized one.  It has what looks to be an hdmi or similar socket. A yellow phono socket and blue 3.5mm jack socket (which I had thought would be audio out)
It does not appear to have a network socket. So it might not be any good for this.
There is an 8GB memory card plugged in, and when I put that into a card reader on the laptop it appears to be empty at the moment.
Not sure what Pi that is, TBH, but here's the parts needed to build a pretty cheap internet radio with hifi quality audio (you'll need a 5 V power supply)
Pi Zero, £4.66:  https://shop.pimoroni.com/products/raspberry-pi-zero
Micro USB to Ethernet adapter, £3.30: https://www.ebay.co.uk/itm/5-Pin-micro-usb-2-0-to-RJ45-LAN-ethernet-network-adapter-100mbps-for-tablet-AL/264224644254?hash=item3d85041c9e%3Ag%3Ad5sAAOSw2gNb6UVs&LH_BIN=1
Phat DAC, £13.25: https://shop.pimoroni.com/products/phat-dac
Header, £1.00:  https://shop.pimoroni.com/products/male-40-pin-2x20-hat-header?variant=10476117383
You'd also need a micro SD card, 2Gb is plenty big enough to take Stretch Lite.
21 minutes ago, ProDave said:
I have come across the Pi Music Box https://www.pimusicbox.com/
I will give that a try on the Pi that I have once I get a network adaptor for it.
Depends how you want to control it, or whether you need to control it at all, really.  I just wanted a simple device that had no controls and needed no form of interface to work.
All mine does is start playing Radio 4 (could be any stream you like) shortly after it's powered up.  I didn't need a built-in interface (which would cost far more than all the other components put together), and definitely didn't want to have to power up a PC, tablet or whatever just to listen to the radio, so I opted not to go for something like Pi Musicbox, just to keep things really simple.  It doesn't get much simpler than just having something come on when you turn the power on.
That Pi Music box has a web interface.  I am assuming once you have logged in and selected an interned radio channel it will continue playing that forever until you tell it to play something else.
I don't expect to be using the interface very often.
I am expecting the "music" Pi to be powered up 24/7
2 hours ago, Miek said:
You could use a chrome cast audio and a mobile phone.
https://www.mymemory.co.uk/google-chromecast-audio.html
For £20 you can't beat the value of these things. High quality output too, I use one to stream radio and personal cloud based audio through my hifi. Very easy to use and handy to be able to control everything via a phone.
This would be my approach too (given I already have a few Chromecast audios)
To avoid fiddling with a phone (or shouting at Siri), I would use my server that is on 24/7 anyway to watch for the chromecast to powering. on and automatically send the cast command to it using https://github.com/barnybug/go-cast (or with home assistant if feeling fancy).
In fact, this thread has inspired me to give that a go. (~10 years ago I used my squeezebox as an alarm clock on R4 for much the same purpose. I still have the squeezebox, but their server software is a pile of steaming Perl and I have no inclination to going back to running it)
The snag with that is the bandwidth the thing will use when you aren't listening to the audio from it.  If you have enough broadband capacity for this not to be a concern, then this is fine, but I prefer being able to shut the stream off when I'm not listening to it, as our broadband isn't that great and there are times when we need all the bandwidth we can get.
The other thing with leaving the stream on is that there's a reasonable chance that it will just stop.  One thing that bugs me with internet radio in general (and as well as the Pi Zero we have a Roberts internet radio) is that the stream can just glitch from time to time.  The Roberts recovers from stream glitches within 30 seconds or so, the Pi Zero needs rebooting to recover (takes around 30 seconds too).  This doesn't happen that often, but often enough that if I had to fire up a PC and log in to the thing to get it running again it would annoy the living daylights out of me.  Turning it off and on again is the lesser of two evils, and something I may well fix sometime by detecting the stream going down and making it automatically restart.
We get about 3MB download, so the audio stream is not going to use more than 10% of the bandwidth if left on.
when I was trying to get the one from @Stones working, when it was working for a short while that was left on 24/7 with no noticable difference to general interned performance. But judging by how hot it got, I am sure it used more power than a Pi will.
I can't now do any more for a couple of days until the USB - Network adaptor arrives.
Okay some help needed from Pi / Linux experts.
So I have downloaded the image file for the Pi Music box.  I followed the instructions to copy the image file to my SD card.  At the end of the process it told me it had coppied 892 MB.  I did the copying using my Ubuntu laptop and with the card plugged into a USB card reader.
After the copying, Ubuntu does not recognise the memory card any more and does not see it.
I tried the card reader into the windows PC and it sees 4 empty volumes.
Oh well I plugged the memory card into the pi, connected the hdmi socket to a tv and powered up the Pi hopefully expecting to see some boot up messages giving me some confidence that the image has worked and the Pi is booting up. But all I get is a blank hdmi raster.
I feel I am "somewhat in the dark"  I obviously can't try connecting to the Pi Music player via the web interface until I get the network adaptor, but it would have been nice to have had some assurance the first part of the process had worked.
There's a good chance that the Pi Music box version of Raspbian (I'm guessing it will be a cut down version of Raspbian) may not natively have an enabled desktop.  Might be worth trying to load an image file of Raspbian to the SD card and see if that boots, as by default the "full fat" version of Raspbian has a desktop and keyboard/mouse interface.
Best bet once you can connect it to Ethernet is to SSH into it and see what's going on, but there's a trick needed to do that.  By default, newer versions of Raspbian (and I'd guess variants of it) don't enable SSH, so you need to create an empty file in the root directly of the SD card called SSH (no suffix).  You can create this file using Notepad on a Windows machine, just save an empty file as SSH, then edit it to remove the .txt extension.  When the SD card is put into the Pi and booted it will automatically enable SSH and delete the blank file.
Having done this, you should be able to connect to the Pi by finding it's IP address on your router, then using a terminal programme, like PuTTY, to SSH in and see what's going on from the command line.
I have a feeling that there may be a way to SSH in to a Pi from USB, but it's not something I've done, as all mine have Ethernet.  Might be worth digging around on the Pi support forums to see if you can find anything out about using USB to connect to a Pi directly.
I feel near certain the process of imaging the memory card has not worked. And feel frustrated at my lack of knowledge.
These are the instructions I used https://elinux.org/RPi_Easy_SD_Card_Setup#Flashing_the_SD_Card_using_Windows
Near the bottom, the section that starts "flashing the memory card using linux"
I wanted to use the GUI method they suggested using "Image Writer" unfortunately the Ubuntu software centre denies any knowledge of that existing. So I used the command line method.
That starts by unmounting the card (umount /dev/sdd1)  Then copying the image file with the DD command.  That appeared to work.
I would have expected to have mounded the card again at the end of the process but no mention to do that.
I am convinced that step is needed because now ubuntu does not see this memory card in it's file manager (so I could not even try as you suggest as you say re SSH if I cannot see the card and write to it)
I only put the card into the Pi as a matter of desperation to prove it had worked and was not surprised that it seems dead.
So thinking the card needs to be mounted, and not knowing the format for the mount command, I have tried the obvious "mount /dev/sdd1" but it says "can't find /dev/sdd1 in /etc/fstab or /etc/mtab
Getting frustrated.
I think you may well be on the right track, as RPi's do seem a bit sensitive to the way that the SD/µSd card is imaged.  Part of the problem seems to be that the card seems to have a Windows-compatible partition, AFAICS, so isn't wholly formatted as a Linux-like file system.  I believe this was done to allow Windows users to be able to access the boot part of the file system, but may be wrong.
The SD card section of this page may help, as you can write the image to the SD card using dd from the command line, which should faithfully create it on the card OK: https://www.raspberrypi.org/documentation/linux/filesystem/backup.md
That's interesting.  It makes no mention of unmounting before using the DD command.  Perhaps the "mistake" was me reading those other instructions and unmounting the card?
How do I get it back to square 1 so I can at least read the card again on the ubuntu PC?
Okay got it sorted.
I had copied the image to /dev/sdd1 whereas I should have copied it to /dev/sdd
Now I can read the copied image and see all the files and the good news is the Pi is working and you see it booting up via the hdmi output.  Of course it now reports a "network timed out" error as there is no network adaptor yet.
So I have the Pi, I have sorted the memory card programing, I have ordered the network adaptor. All  I need is a DAC board.
The pHAT DAC linked above has a 40 pin header, as do modern versions of the Pi.  but mine being an old Mk1 only has the original 26 pin header.  As I undrstand it this DAC works over the I2S lines, which are on the original 26 pin header, so I see no reason why a pHAT DAC would not work if I just fit a 26 pin header to it.  But the supplier linked to above says it won't work.
I have however found this one that clearly only has the 26 pin header so should work, but not yet found a UK supplier so may just have to wait for it from China https://www.ebay.co.uk/itm/HIFI-DAC-HIFI-Audio-Sound-Card-Module-I2S-Interface-For-Raspberry-Pi-B-Black/292203010088?hash=item4408a81828:g:Jz0AAOSwJLJZguV4
