Hi all
i am really keen to get great sound and heat insulation, searching on here if I see many have timber frame or other construction methods. I was wondering what the best way if achieving good results with a brick and block construction?
I dont really have extra space for thicker floors or walls to pad it out with extra insulation, maybe there is higher spec material I can use etc?
any way tips are massively appreciated
How thick can your walls be? How much insulation are you hoping to have under your floor? Thinnest bang for your u value buck in masonry build is probably single skin blocks and ewi. Cavity wall is possible but to get a decent level of insulation  to you are looking at 200mm cavity and so a wider wall
11 minutes ago, scottishjohn said:
start with full spec of house you want to alter ,  and  current insulation levels  if you want meaningful replies for solutions.
Its very much open, there is no current insulation levels.
1 hour ago, Sjk said:
Hi all
I Quik answer is yes Brick and block all day long for sound
Timber is hopeless
For sound insulation it’s all about keeping walls and cieling Seperate
as much as possible
If you go down the route of TF It is well worth hanging a mf cieling 50 mil below the floor joists
Our tf is all done with double acoustic boards which I couldn’t quite get my head round at the time but my do they work! If I shout to my hubby in another room he can’t hear me and it’s not him turning a deaf ear, if I am outside the lounge and he speaks to me I can’t hear him either!
Interesting, thanks for the replies.
I hadnt thought about single skin with ewi. Excellent to hear about the double acoustic boards :)
Likely to use easijoists for the upper floors.
Not it sure how to go about getting sound insulation between bedrooms upstairs.
2 hours ago, Sjk said:
Hi all
Timber is hopeless
as much as possible
ive put in a twin wall in MF between the two bathrooms
You can’t even hear the loo flush when you are stood at the other side of the wall
It all about transfer of sound
Timber soaks it like a sponge
Mf is not even 10% of the densety of equivelant timber
While I don’t claim to be an exspect
I’ve specialised in sound and fireproofing for over thirty years
Timber is hopeless
I wouldn't quite say timber is hopeless, relative to masonry, correctly designed and built it can perform as well as masonry overall (Rw), however where masonry comes into its own is low frequency resistance as it's got significantly more mass to it. If you compare the low frequency range sound insulation measure (Ctr) masonry is so much better.
7 hours ago, Sjk said:
Hi all
Are you looking at internal walls and floors rather than external facade elements?
If you are looking at internal spaces, building regs require a minimum sound insulation of Rw 40 dB. This can easily be achieved with standard plasterboard on timber studs with a bit of mineral in the cavity. Or if you are going masonry a 100mm block will do it.
If you want to increase over the minimum Rw requirements with timber then look to use additional layers of denser plasterboard (or even resilient bars), or with masonry use denser block.
Edited by Moonshine
I regret not double boarding our ceilings, or soundblock PB. Even though ours meet building regs I have found speech can be heard between floors ?
P.S. our build is brick and block and external noise cannot be heard indoors.?
Edited by joe90
I was speaking more about Studwork As aposed to mf
But you will always have more sound transfer on a house that is predominantly timber
But if TF are far more suited to self builders Much quicker to get watertight
We do blocks of student accommodation in T F Good for us as they are not weather dependant
Why do the major house builders not go for TF
They wouldnt sell
They wouldnt sell
Developers use TF more than anything else up here. It's just what folk are used to I guess.
30 minutes ago, Sjk said:
Looking at at both internal and external.
If you are doing a external wall with two 100mm block, and 100mm cavity noise intrusion won't be an issue, however other facade elements such as glazing and vents are the potential issue.
1 minute ago, newhome said:
They wouldnt sell
Oh they do, and they do sell. So many use timber framing, e.g. Persimmon do loads of timber frame, so much so they brought a timber frame company, Space 4.
  • 2 weeks later...
any one got any thoughts on Internal vs External wall insulation? Seriously considering a solid wall.
If i had IWI I could have a full brick wall, which would open up some different brick patterns, although this would be more expensive. I should be able to fit all the insulation myself, which I wouldnt be so confident doing with EWI.
EWI I could use cheap blocks, and I think the render would be more hard wearing than bricks... Although the bricks specs are as following.
Compressive strength ≥ 75N/mm2
Water absorption ≤ 7%
Durability F2
Active soluble salts content S2
Edited by Sjk
