20 minutes ago, ProDave said:
All I can say is all houses I see being built up here have sarking on the roof.
Same here on the west coast, standered practice.
Major house builders don't do it purely because it is cheaper and not required.
all houses here have osb on top of the trusses. adds a considerable amount of racking strength to the roof, never seen one locally without osb or sarking if being slated.
1 hour ago, ProDave said:
Isn't that in effect a cut roof pre fabricated and lifted in in sections?
Did you see the video? Are those bits that get lifted in, like SIPS panels but in a roof?
Yes I guess they must be some form of SIP panel. The interesting thing is that it is not a continuous panel the full length of the roof, an off thin panel was added at the top.
But for the point of this discussion id does appear to have a (probably OSB) sarking layer on top.
the 20  houses built next to my current house.
making a small scheme  -built in about 1992 by robison &davison
locally know as R&D
or rough and dangerous
they were all built with english type roof ,no sarking boards ,so there must be a loop hole somewhere or SE has assured planning that they will take wind loads ??
so yes its not a new thing houses being built by the bigger builders not using sarking board roofs in scotland
I suppose it could be a balancing cost factor between   more skinner trusses +sarking and   thicker ones and no sarking
I doubt it will be a wind loading factor that sways big builders  on which way to build
Edited by scottishjohn
once i get to a plan ,that is one thing I will try to quantify .both on cost +insulation value
difference between sips panels and fully trussed roof and all the insulation etc .
and then non sarking type roof as an option as well
roof on in a day is very attractive part of the sips choice
