Pocster Posted January 3, 2019 Author Posted January 3, 2019 Well ! ive got to spend more dosh. Header tank onto gravity fed triton electric t90xr ( I think ) - quieter than the Mira . A solution at least !!
Pocster Posted January 3, 2019 Author Posted January 3, 2019 32 minutes ago, Mr Punter said: Any reason you didn't just get a BFO combi? The Combi is a leased item .
ProDave Posted January 12, 2019 Posted January 12, 2019 And how long will it stay that nice? Only "complaint" is you could have chased the tv wires into the wall.
newhome Posted January 12, 2019 Posted January 12, 2019 Looks good? When do people move in? I am trying to visualise those rooms with 50 odd bottles of p*ss on the floor . Hope your tenant screening process is better this time . 1
Pocster Posted January 12, 2019 Author Posted January 12, 2019 42 minutes ago, ProDave said: And how long will it stay that nice? Only "complaint" is you could have chased the tv wires into the wall. Not long ? Yeah TV turned up 'late'. Whats annoying is power is one side of it and AV/HDMI etc. is the other!
Pocster Posted January 12, 2019 Author Posted January 12, 2019 32 minutes ago, newhome said: Looks good? When do people move in? I am trying to visualise those rooms with 50 odd bottles of p*ss on the floor . Hope your tenant screening process is better this time . TBH I don't have that many tenant issues as a percentage . It's simply I can turn over a lot of tenants in a year. Well CCTV is in all communal spaces - so we can watch the bottles of wee build up!
Onoff Posted January 12, 2019 Posted January 12, 2019 57 minutes ago, pocster said: Not long ? Yeah TV turned up 'late'. Whats annoying is power is one side of it and AV/HDMI etc. is the other! Don't suppose you can whack some D-Line up.
Pocster Posted January 12, 2019 Author Posted January 12, 2019 (edited) 24 minutes ago, Onoff said: Don't suppose you can whack some D-Line up. I could . If it was my home - no cables would be visible . They’ve got a 50” tv with all the channels and sky sports HD ( not that I care about that ) - are they really going to worry about a few cables ? Edited January 12, 2019 by pocster
Pocster Posted January 24, 2019 Author Posted January 24, 2019 4 rooms rented . 2 to go Attracting exactly the type of tenants I want ! ? 2
Onoff Posted January 24, 2019 Posted January 24, 2019 1 hour ago, pocster said: 4 rooms rented . 2 to go Attracting exactly the type of tenants I want ! ? Single, white females with a penchant for wandering the CCTV covered communal areas in the noddy? Seriously though well done! 3
Pocster Posted September 20, 2019 Author Posted September 20, 2019 Well there you go ! Fancy that ! Multiple systems to reduce chance of failure simultaneously and they fail today ! Boiler diverter valve failure ( ain’t it always ) also uvc ( not fed from boiler ) has failed !!! . On the same day !! Coincidence?!?!?!? -
Cpd Posted September 20, 2019 Posted September 20, 2019 Yup.... it’s something I have to think about all the tine living on an island and hosting guests, i keep it as simple as possible as there will be no quick fix if something goes wrong. 1
Pocster Posted September 26, 2019 Author Posted September 26, 2019 Well ! Unsurprisingly the guy who installed the uvc has diagnosed the fault and was meant to fix it today . Whats amazing is I have my automated heating system which shows when someone’s in the room . By coincidence the tenant for the room with uvc is away . Guess what ? No one’s been in - though keys are accessible! . Better yet of course I have Cctv !! / nope can’t see uvc guy ! Thats 1 week tomorrow with no hot showers ... Guess i’ll Have to give up on his ‘warranty ‘ repair I.e never turn up and pay someone instead ffs !!!
Pocster Posted September 26, 2019 Author Posted September 26, 2019 His twat text ( even though he hasn’t been there ) says the thermostat is gone . Looking back at my photo of the tank - where is the thermostat?????????
Pocster Posted September 26, 2019 Author Posted September 26, 2019 Is the black lump on the tank the stat ?? old photo !
ProDave Posted September 26, 2019 Posted September 26, 2019 That looks like the immersion heater to me (which will have a thermostat in it) Being that high up the tank, there are probably 2 of them. Is this direct or indirect, i.e. is the immersion heater(s) the only thing heating it?
Pocster Posted September 26, 2019 Author Posted September 26, 2019 4 minutes ago, ProDave said: That looks like the immersion heater to me (which will have a thermostat in it) Being that high up the tank, there are probably 2 of them. Is this direct or indirect, i.e. is the immersion heater(s) the only thing heating it? Yes afaik - heated just by electric immersion .
ProDave Posted September 26, 2019 Posted September 26, 2019 Why is the top switch fuse feeding the time switch turned off? What test equipment do you have e.g a multimeter?
Pocster Posted September 26, 2019 Author Posted September 26, 2019 Just now, ProDave said: Why is the top switch fuse feeding the time switch turned off? What test equipment do you have e.g a multimeter? That’s just the way it was installed . So in theory I could boost hot water using the timer - but it seems fine with just 1 element heating . As I pay the electric bill ...
ProDave Posted September 26, 2019 Posted September 26, 2019 Just now, pocster said: That’s just the way it was installed . So in theory I could boost hot water using the timer - but it seems fine with just 1 element heating . As I pay the electric bill ... So I am guessing the bottom switch fuse is the off peak feed feeding the bottom heater? So that's where you need to look, at the bottom heater. Turn the switch fuse off, take the cover off. You should see a thermostat. There will be a (often VERY tiny) overheat trip. If it has popped out, try pushing it in and see if it clicks. Otherwise you need some test gear. 1
Pocster Posted September 27, 2019 Author Posted September 27, 2019 All fixed Thermostat blown so replaced . As the 1 thermostat is always on would it be wise to put that on a timer also . My logic being that 1 element cold heat for 12 hours ; turn off ; then the other comes on . Kind if like spreading the load . Or is that pointless???
ProDave Posted September 27, 2019 Posted September 27, 2019 The normal arrangement with E7 is to heat the tank with the bottom heater at night on the cheap rate, and have the top heater on a boost timer that you can turn on at any time if you have ran out of hot water.
Pocster Posted September 27, 2019 Author Posted September 27, 2019 11 minutes ago, ProDave said: The normal arrangement with E7 is to heat the tank with the bottom heater at night on the cheap rate, and have the top heater on a boost timer that you can turn on at any time if you have ran out of hot water. No E7 i’m Afraid
