PeterW Posted October 22, 2018 Posted October 22, 2018 Thanks @lizzie So the trap is part of the actual unit itself so can’t be replaced. It fits into a 40mm pushfit from the looks of it so it’s a relatively simple fix to put a Hep20 dry trap in the waste and let the u-bend dry out. It needs a slim plumber by the looks of it so @Nickfromwales your luck is out ..! ? 1 1
lizzie Posted October 22, 2018 Author Posted October 22, 2018 3 minutes ago, PeterW said: 2 minutes ago, PeterW said: Thanks @lizzie So the trap is part of the actual unit itself so can’t be replaced. It fits into a 40mm pushfit from the looks of it so it’s a relatively simple fix to put a Hep20 dry trap in the waste and let the u-bend dry out. It needs a slim plumber by the looks of it so @Nickfromwales your luck is out ..! ? OK Thanks...sorry @Nickfromwales LOL I will search local yellow pages for a slim plumber that does not ride a horse and wear a stetson! Will give a above spec to plumber when I find him/her!
newhome Posted October 22, 2018 Posted October 22, 2018 1 minute ago, lizzie said: OK Thanks...sorry @Nickfromwales LOL I will search local yellow pages for a slim plumber that does not ride a horse and wear a stetson! Will give a above spec to plumber when I find him/her! Poor @Nickfromwales! @PeterW is very bad telling everyone he's a pie boy cos he's really not and nor does he wear a stetson. The horse, well I don't know if he has a horse. More likely to be sheep in Wales I guess . 1 1
lizzie Posted October 22, 2018 Author Posted October 22, 2018 1 minute ago, newhome said: Poor @Nickfromwales! @PeterW is very bad telling everyone he's a pie boy cos he's really not and nor does he wear a stetson. The horse, well I don't know if he has a horse. More likely to be sheep in Wales I guess . I never for one moment wished to give the impression @Nickfromwales had a stetson or a horse LOL....now sheep are a different matter being Welsh I know about those...and wellies! 1
ProDave Posted October 22, 2018 Posted October 22, 2018 7 minutes ago, lizzie said: I never for one moment wished to give the impression @Nickfromwales had a stetson or a horse LOL....now sheep are a different matter being Welsh I know about those...and wellies! I had a Welsh friend once that kept saying "I can see the one that I want" 1 1
ProDave Posted October 22, 2018 Posted October 22, 2018 If you are going for the "cap it off and use a bucket" solution then find out if it is 32mm or 40mm and buy the aproporiate one of these and fit to the end of the horizontal pipe 40mm https://www.ebay.co.uk/itm/Waste-Pipe-Cap-40mm-42mm-43mm-Stop-End-Compression-Stop-Cap-for-Bath-Shower-Sink/281996806964?hash=item41a851cb34:g:RO0AAOSwMFFbrOr4 32mm https://www.ebay.co.uk/itm/Waste-Pipe-Cap-32mm-34mm-36mm-Stop-End-Compression-Stop-Cap-for-Basin-Sink-Pipe/281996848267?epid=10019666338&hash=item41a8526c8b:g:bcAAAOSwCx5brOkt With the loose fit sleeved pipe as it has been done, if there was any condensate discharge, it would just have dripped onto the floor as that pipe joint would not have sealed. 1
Gone West Posted October 23, 2018 Posted October 23, 2018 @lizzie This is quite common when connecting EU to UK wastes and just needs an EU/UK 40mm waste adapter. 1
Nickfromwales Posted October 23, 2018 Posted October 23, 2018 Enough of this bollocks about buckets and cap ends ? Lizzie, a horizontal waterless trap will do the job. First off though, could you get a pic of the underside of the MVHR unit? I need to see how the trap connects to the MVHR unit if possible ? Ta. 1
PeterW Posted October 23, 2018 Posted October 23, 2018 4 hours ago, Nickfromwales said: Lizzie, a horizontal waterless trap will do the job. First off though, could you get a pic of the underside of the MVHR unit? I need to see how the trap connects to the MVHR unit if possible ? Ta. @Nickfromwales you need to catch up... 19 hours ago, PeterW said: So the trap is part of the actual unit itself so can’t be replaced. It fits into a 40mm pushfit from the looks of it so it’s a relatively simple fix to put a Hep20 dry trap in the waste and let the u-bend dry out. Wierd design but the trap is threaded to the bottom of the unit and then you would need to cut both pipes and just put the other waterless trap in the gap as a connector.
Nickfromwales Posted October 23, 2018 Posted October 23, 2018 That been confirmed then ? Wasn’t how I read it tbh but I’m not the sharpest tack ? There are shallow basin wastes with integral waterless valves ( which could screw onto a 40x32mm adapter if that’s a 40mm trap that is ) and then join the waste to the trap with a flexi connector. No glueing etc and easy, permanent ‘one trap’ fix. https://www.tapwarehouse.com/product/uniwaste for eg.
PeterW Posted October 23, 2018 Posted October 23, 2018 1 minute ago, Nickfromwales said: That been confirmed then ? Wasn’t how I read it tbh but I’m not the sharpest tack ? There are shallow basin wastes with integral waterless valves ( which could screw onto a 40x32mm adapter if that’s a 40mm trap that is ) and then join the waste to the trap with a flexi connector. No glueing etc and easy, permanent ‘one trap’ fix. https://www.tapwarehouse.com/product/uniwaste for eg. I read the manual .....
Nickfromwales Posted October 23, 2018 Posted October 23, 2018 29 minutes ago, PeterW said: I read the manual ..... How the other half live
lizzie Posted October 23, 2018 Author Posted October 23, 2018 Thanks guys......veryconfused.com here @Nickfromwales pics of underside ofmvhr unit taken from floo looking up. I really appreaciate all the help and advice thank you.
Temp Posted October 24, 2018 Posted October 24, 2018 Lizzie, This picture suggests there is another appliance or sink in the same room? Perhaps you can arrange both to share the same trap so that the other appliance/sink keeps the trap full. Might be better than a waterless trap but what do others think? Something like this..
lizzie Posted October 24, 2018 Author Posted October 24, 2018 nothing else in there it is the plant room. The pipe that runs around the wall is I think the condensate pipe from the boiler which drains into that waste rather than externally.
PeterW Posted October 24, 2018 Posted October 24, 2018 28 minutes ago, lizzie said: nothing else in there it is the plant room. The pipe that runs around the wall is I think the condensate pipe from the boiler which drains into that waste rather than externally. Is the condensate trap drying out too as that will contribute to the smell. I would put the waterless trap in the straight section after both the MVHR and the boiler join in that case.
lizzie Posted October 24, 2018 Author Posted October 24, 2018 7 minutes ago, PeterW said: Is the condensate trap drying out too as that will contribute to the smell. I would put the waterless trap in the straight section after both the MVHR and the boiler join in that case. Thank you that makes good sense. I will look for a plumber next. Do you think I should get the waterless trap myself or let plumber supply? I would just ask in the shop what they suggested I buy.
PeterW Posted October 24, 2018 Posted October 24, 2018 Looks like 40mm solvent weld so you need a HepV0 CV1 and a HepV0 CV3 running adaptor 1
Nickfromwales Posted October 25, 2018 Posted October 25, 2018 15 hours ago, PeterW said: Is the condensate trap drying out too as that will contribute to the smell. I would put the waterless trap in the straight section after both the MVHR and the boiler join in that case. They could have run the boiler condensate into a combination branch off a combination trap and the boiler ( as it’s doing DHW ) would have constantly wet the throat of the trap. Muppets. They could have used this one and run the 21.5mm boiler condensate pipe to that little branch. So easily avoided if they actually gave a feck.
lizzie Posted October 25, 2018 Author Posted October 25, 2018 1 hour ago, Nickfromwales said: They could have run the boiler condensate into a combination branch off a combination trap and the boiler ( as it’s doing DHW ) would have constantly wet the throat of the trap. Muppets. They could have used this one and run the 21.5mm boiler condensate pipe to that little branch. So easily avoided if they actually gave a feck. I think we are all agreed that plumbers and the mvhr/ufh/boiler installer seem to to be useless! Makes me so mad to feel so clueless myself, OH has bought me a book on plumbing but its not making much sense yet. LOL @PeterW I’m about to order the recommended bits ready for a plumber when found. As trap going on the straight bit of pipe after everything else do I need 2 of those running adaptors one for each end of new trap? Sorry to be so thick.
PeterW Posted October 25, 2018 Posted October 25, 2018 @lizzie you only need one adapter as the other end is already 40mm 1
lizzie Posted October 26, 2018 Author Posted October 26, 2018 On 25/10/2018 at 11:18, PeterW said: @lizzie you only need one adapter as the other end is already 40mm Thank you. I have been and bought them.....they didnt have the brand you said (despite web site saying in stock) sold me McAlpine which they said are identical...hope so! Trying to find a plumber now.
newhome Posted October 26, 2018 Posted October 26, 2018 Could you not give this a go @lizzie? With the guys here holding your hand (in a virtual sense)? Your first real plumbing job? I had to change the dishwasher plumbing once (before this forum) as it was leaking. Took me a week of sending photos to my brother and lots of cussing but I did get it done and it hasn’t leaked yet ?.
lizzie Posted October 26, 2018 Author Posted October 26, 2018 @newhome I might have given it a go if I could physically get myself folded into the space it needs to go in but unfortunately I have a back problem thats means I cant. Its an absolute nightmare having to lie flat on the floor under mvhr every few days to fill trap with water. I have to slide in and out like a worm and be drugged up on painkillers to do it. If it had just been swapping one trap for another may have been do able but sadly not. So hoping I can get a plumber out soon. Feel hugely frustrated and annoyed I cant sort this myself now lovely chaps on here have given me solution 1
newhome Posted October 26, 2018 Posted October 26, 2018 3 minutes ago, lizzie said: Feel hugely frustrated and annoyed I cant sort this myself now lovely chaps on here have given me solution I know the feeling . Sometimes it all sounds so simple until you try it too! 1
