Crofter Posted July 25, 2016 Share Posted July 25, 2016 I'm thinking of not bothering with a landline connection for my wee house, and using a wifi extender instead. The distance from my own house is about 40m with a clear line of sight. Not really sure what I'm looking at though- any advice? Link to comment Share on other sites More sharing options...
Nickfromwales Posted July 25, 2016 Share Posted July 25, 2016 Netgear stuff is good quality and reliable. You may want an outdoor unit that can go on the outside wall, or one with an arial port so the antennae can go on the high point of the outside wall. @JSHarris may be able to offer some wisdom. Link to comment Share on other sites More sharing options...
Construction Channel Posted July 25, 2016 Share Posted July 25, 2016 Have you got a power line going between the houses? we've got an extender that uses the power lines to carry the signal, supposedly, I don't trust it, but it seems to work somehow, plug the transmitter into the router and a wall socket, then the receiver into virtually any other socket, i even had it running off a 50m extension lead to get WIFI into my workshop not this model, but similar and same brand http://www.ebay.co.uk/itm/TP-Link-TL-WPA4220KIT-AV500-Powerline-300M-Wi-FI-Extender-Two-Ports-Home-Plug/281497297768?_trksid=p2045573.c100505.m3226&_trkparms=aid%3D555014%26algo%3DPL.DEFAULT%26ao%3D1%26asc%3D20151005190540%26meid%3D7e95933ad4b748af8c4dfde36893594f%26pid%3D100505%26rk%3D1%26rkt%3D1%26 1 Link to comment Share on other sites More sharing options...
PeterW Posted July 25, 2016 Share Posted July 25, 2016 These are pretty good as they are PoE so as long as you use copper Cat5 not CCA cable then they are fine. We had one at about 110m through trees and no problems at all https://www.ballicom.co.uk/ap150wn1x1og-startech-com-outdoor-150-mbps-1t1r-.p999295.html?ref=PLA&gclid=CjwKEAjw8da8BRDssvyH8uPEgnoSJABJmwYoTL4bvw_rxdiXajE5tx4bRBCNRRjlmMzqKSl5J1QbXxoCeWLw_wcB Link to comment Share on other sites More sharing options...
Nickfromwales Posted July 25, 2016 Share Posted July 25, 2016 Iirc, the plug in ones use the earth to transmit / receive. Voodoo to me tbh. Link to comment Share on other sites More sharing options...
Construction Channel Posted July 25, 2016 Share Posted July 25, 2016 Black magic indeed, I plugged it in and it worked thats ALL i needed to know 1 Link to comment Share on other sites More sharing options...
Crofter Posted July 25, 2016 Author Share Posted July 25, 2016 The wee house is on its own electricity supply, so no direct link that way. Didn't even know doing it over the 240v was an option! @PeterW I might need that dumbed down a wee bit... POE?? Link to comment Share on other sites More sharing options...
vfrdave Posted July 25, 2016 Share Posted July 25, 2016 Have a look at ubnt.com they do great kit for wireless point to point links. 1 Link to comment Share on other sites More sharing options...
Barney12 Posted July 25, 2016 Share Posted July 25, 2016 (edited) 50 minutes ago, Crofter said: The wee house is on its own electricity supply, so no direct link that way. Didn't even know doing it over the 240v was an option! @PeterW I might need that dumbed down a wee bit... POE?? Power Over Ethernet. In other words the power required for the unit is carried on the same cable (cat5/6) as the signal. Thus very simple to set up / install. Edited July 25, 2016 by Barney12 Link to comment Share on other sites More sharing options...
PeterW Posted July 25, 2016 Share Posted July 25, 2016 Yep basically you plug in the power supply somewhere near the router, feed a standard network cable in one side and then the one coming out the other side becomes PoE.. There are lots of different protocols but the simplest form is that you use the spare 4 cores of the 8 core Cat5 to carry power - usually at 48v. The device on the other end then uses this to power its "stuff" whether it be access point or IP camera. CCA cable doesn't do as well for current capacity as full copper cored hence the suggestion. If it's not far from the house router to the external wall then sometimes a pre-made patch cable (up to 20m is not that expensive) is cheaper than buying cables and plugs and tools to make connections. Link to comment Share on other sites More sharing options...
Nickfromwales Posted July 25, 2016 Share Posted July 25, 2016 Can't help thinking that for 40 m or so, can't you get a cable there? Cat6 is cheap as chips, so you could bury 2 runs in cheap PVC conduit and enjoy hard wired performance. Maybe part buried / part arial run with catenary wire? Link to comment Share on other sites More sharing options...
reddal Posted July 25, 2016 Share Posted July 25, 2016 1 hour ago, Nickfromwales said: Can't help thinking that for 40 m or so, can't you get a cable there? This. Wifi is not as reliable as a hard cable and has far more constraints on performance. Unless there was no other option I would try to run a cable. Then you will get gigabit performance with no dropouts or interference issues etc. Link to comment Share on other sites More sharing options...
Crofter Posted July 26, 2016 Author Share Posted July 26, 2016 The problem with running a cable is that there is a road in the way. However I do have some ducts in there from when I ran the power and water to the site, but they would be a real pain to dig up and find again. I know you're not supposed to run a Bt Cable next to a power line, would this apply for ethernet as well? Link to comment Share on other sites More sharing options...
Onoff Posted July 26, 2016 Share Posted July 26, 2016 (edited) Cheap 'n cheerful, I have one of these that gets internet access across the mains to a room that hasn't got it. This is of course hard wired to the router one end and the pc the other. Just to get a feel for what's available, Maplin do wireless extenders which would allow easy tablet/phone access in the hut. You need to plug in the units on the same mains phase. http://www.maplin.co.uk/p/tp-link-tl-pa4010kit-av500-powerline-kit-n20nr Edited July 26, 2016 by Onoff Link to comment Share on other sites More sharing options...
Nickfromwales Posted July 26, 2016 Share Posted July 26, 2016 Where does the hut get it's power supply? Umbilical from yours or fresh supply ( on the same phase ? ). 1 Link to comment Share on other sites More sharing options...
vfrdave Posted July 26, 2016 Share Posted July 26, 2016 12 hours ago, Crofter said: The wee house is on its own electricity supply, so no direct link that way. Didn't even know doing it over the 240v was an option! @Nickfromwales Link to comment Share on other sites More sharing options...
Nickfromwales Posted July 26, 2016 Share Posted July 26, 2016 You'll have to give us a clue dave Link to comment Share on other sites More sharing options...
Crofter Posted July 26, 2016 Author Share Posted July 26, 2016 18 minutes ago, Nickfromwales said: Where does the hut get it's power supply? Umbilical from yours or fresh supply ( on the same phase ? ). Hut? Pah! It's a house, just a *very* small one... I've spent £2k on a new connection which is completely separate from my own house. Didn't fancy having to take showers one a time (both houses are 100% electric for heating and DHW). I'm sure we could have rigged up some sort of semaphore system to indicate who was using the power... Link to comment Share on other sites More sharing options...
Nickfromwales Posted July 26, 2016 Share Posted July 26, 2016 hut, house, it's all the same. Link to comment Share on other sites More sharing options...
PeterW Posted July 26, 2016 Share Posted July 26, 2016 Looks like wifi is your only option if it's the other side of the road. We've done some stuff with Ubiquiti before and they have (had..?) a range of directional wifi repeaters that you can "focus" on a spot to give maximum signal strength etc 1 Link to comment Share on other sites More sharing options...
SteamyTea Posted July 26, 2016 Share Posted July 26, 2016 Would it not be worth just trying out an ordinary wireless home router first, it may be good enough. My cheap phone can be set up as a wireless hotspot, it works at 20 metre away just fine. Link to comment Share on other sites More sharing options...
Temp Posted July 26, 2016 Share Posted July 26, 2016 Perhaps look at a wifi access point in your main house with a directional antenna pointed at the hut. Most access points have Omnidirectional antenna so pick on that allows you to replace it with a directional. Some people make them from Pringles cans but I've not tried that. If it's across the road you might loose connection when a high sided van drives past. Link to comment Share on other sites More sharing options...
