I don't like the systems I've seen where the clips occupy the corners, simply because I want to be able to see the gaps at the junctions / intersections. Quite like the system in the vid as you can put them where you like, but REALLY don't like the price!
I'll have another look at the UK systems as I have a couple more floors to lay 'for prosperity'.
7 minutes ago, newhome said:
You mean the cheapskate ones are crap! What a shock ?
The man himself said buy the cheapest ones you can!
Clearly you managed to be even more cheap than @Nickfromwales could have anticipated then ?. Baby wipes are so cheap anyway it’s not worth saving the extra half pence IMO ?
3 hours ago, PeterW said:
We use ones from Home Bargains ... 2 packs for £1..!!
Even more cheapskate then! ?
  • Haha 1
6 minutes ago, newhome said:
Well if they’re no good for tiling you can use them to make your arse as soft as a baby ... ?
No need, I bought one of these out of Viz:
Made in Wales...
On 17/11/2018 at 14:14, Nickfromwales said:
Nah, just go to something that’s not water based so the paint doesn’t soften. CT1 / Sika etc will be fine. Don’t forget to fit the top trim whilst the goop is still ‘wet’.
A couple of questions if I may:
Grey "shelf" tiles are all stuck on the length of that wall. All the mosaics for the upstand are cut.
1) Do I sit the mosaics on 1mm shims, wipe the excess whatever adhesive off, clear CT1 the 1mm gap then finish with white silicon?
2) If using Sika / CT1 then how much do I put on the back of the tile, each corner and a centre blob or all 4 sides?
3) Clear CT1 I assume or white Sika. Both ferkin expensive.
A pity something like Sticks Like Sh!t wouldn't do it!
4) If I Sika / CT1 then how do I stop the 1mm shims getting stuck in there? If I take them out before the "adhesive" is set the tiles will slump.
5) 10mm tile trim. The "risk" is I push the tile too far back and it sits well under the trim. Dry fit first maybe then stick plastic shims onto the wall first to stop me pushing the tiles in too far?
20181116_235945
Cheers
Edited by Onoff
Don’t bother with the 1mm shims as that’ll be a cosmetic area not a splash proof one so just grout it and wipe it completely back to the tile, and then coloured silicone or white silicone for a cosmetic bead afterwards.
4 minutes ago, Nickfromwales said:
And don’t go crazy with the goop. Lots of 20p sized  blobs and push back until flush with the trim.
Appreciated.
What about a neat "seal" between back of the trim to the mist coated wall and top of the tile to the trim? SWMBO prefers not to feel a ridge at the trim edge so I'm sitting the trim on top of rather than lipping over the tile. (Doesn't always work out with my wonky tiling :) )
I've a tube of grey CT1 doing nothing so will use that up here.
Yup. Just have the baby wipes to hand.
Set the trim back to the wall with a small bead of caulk. ;)  Smooth and wipe off immediately, leave to dry, and then mask and repaint.
Bingo bango + chicken dinner in one. ?
"Caulk" as in decorator's caulk? As opposed to CT1 or Sika?
I was half tempted to stick the trim on the wall first using the mosaics to gauge height backed up by some feint pencil lines on the painted wall. Clear CT1 (trim to painted wall) seems obvious but will paint go over CT1?
If that's a goer then once the trim is on, blob the backs of the mosaics with grey CT1 (as I have it spare) and quickly push in the mosaics level with the trim.
Yes, as you'll need to be able to paint it, and you'll want to be able to wipe it off. Water based clean up requires water based goop ;)
Hmmm...so a line of caulk along the top and a line of CT1 lower down  to stick the trim to the wall?
If you think you can stick the trim on without getting a gap, and without getting goop on the paint, then do away with the caulk. Making life hard there AFAIC though. Ideally you need a slow setting goop and to fit the trim and tile upstand simultaneously. Gets tricky if theres a joint, but glue and spray should be your friend there.
A few (very few) done tonight:
2 on the floor under the basin:
20181128_213431
The left hand rip above the window that's been bugging me for ages. I removed the original tile that was just wrong ages ago and tonight multi tooled the old adhesive off and put a better rip up. I can trim the edge now and tile the soffit.
20181128_213421
Poxy little one in the top corner done now:
20181128_213350
Last two pockets done:
20181128_231534
3 rips above the bath:
20181128_231523
Focus now then is on the soffit and sides of the window reveal and the mosaics and trim along the painted wall shelf.
Then THE BATH!
20181128_213431
20181128_213421
20181128_213350
20181128_231534
20181128_231523
Then THE BATH!
looking great now mate.
Ta, I did promise a warts 'n all journey with this! Tbh the last few, up high / down low, if it was a 2mm or 4mm gap rather than 3 and I couldn't get a 3mm spacer in or it was loose I just whacked  'em up! :ph34r:
You would make a great self-builder as you want everything to be millimetre perfect and that is not always achievable as you, me and others have found out. Keep going bud and when it is all done and grouted, towels everywhere you will wonder what all the fuss was about!
