newhome Posted January 26, 2019 Share Posted January 26, 2019 7 minutes ago, Onoff said: SWMBO helping with the grouting. Doing opposite ends so we don't kill each other! That's still pretty risky in such a small area . Whose work is better? Link to comment Share on other sites More sharing options...
Onoff Posted January 26, 2019 Author Share Posted January 26, 2019 1 hour ago, newhome said: That's still pretty risky in such a small area . Whose work is better? Difficult to call. Tbh none of it helped by my sh!t tiling. Hers. Mine: I'm going to do the wet room corner. Don't think it fair if it leaks. I can certainly ram it in harder..... Link to comment Share on other sites More sharing options...
newhome Posted January 26, 2019 Share Posted January 26, 2019 11 minutes ago, Onoff said: I can certainly ram it in harder..... I think you have the edge just now unless you were unfair and chose your best bit! Link to comment Share on other sites More sharing options...
Onoff Posted January 26, 2019 Author Share Posted January 26, 2019 13 minutes ago, newhome said: I think you have the edge just now unless you were unfair and chose your best bit! Tbh we're both pretty useless! Me: Her: Not sure she's putting enough in? I am trying to sponge off at 45deg to the grout lines always. Also I keep the sponge dead flat. Seems ironic it failed at the last hurdle as in the tiling. Link to comment Share on other sites More sharing options...
CC45 Posted January 26, 2019 Share Posted January 26, 2019 Dont wash it out. Patience young grasshopper. Link to comment Share on other sites More sharing options...
Onoff Posted January 26, 2019 Author Share Posted January 26, 2019 5 minutes ago, CC45 said: Dont wash it out. Patience young grasshopper. Explain please! Link to comment Share on other sites More sharing options...
CC45 Posted January 26, 2019 Share Posted January 26, 2019 I find the grout needs to be reasonably set - if its too 'wet' still its easy to rub it out, I'd rather have to work a bit harder when polishing it up. If those were the only bits you can find then you aint doing too much wrong. You will notice stuff others wont. Ordered my front door last week - the guy running the company came around to measure and after chatting about rugby he had a shifty around. I hate tiling but he commented that he had gone through many tilers before he was happy and that my tiling was comparable to the chap he used but I know where all the little mistakes are and he didnt. I also take a long time doing it all. I dont think you probably have too much to worry about. Link to comment Share on other sites More sharing options...
Onoff Posted January 27, 2019 Author Share Posted January 27, 2019 9 hours ago, CC45 said: I find the grout needs to be reasonably set - if its too 'wet' still its easy to rub it out, I'd rather have to work a bit harder when polishing it up. If those were the only bits you can find then you aint doing too much wrong. You will notice stuff others wont. Ordered my front door last week - the guy running the company came around to measure and after chatting about rugby he had a shifty around. I hate tiling but he commented that he had gone through many tilers before he was happy and that my tiling was comparable to the chap he used but I know where all the little mistakes are and he didnt. I also take a long time doing it all. I dont think you probably have too much to worry about. What type of cloth are you using to rub out with? I've a window cleaners scrim seems pretty good for buffing up and getting the dust off. At any time does a wet finger/rubber glove come into play along the joints? Link to comment Share on other sites More sharing options...
CC45 Posted January 27, 2019 Share Posted January 27, 2019 (edited) I just use a big flat sponge. Damp sponge not a wet one. No need for finger or rubber glove. Edited January 27, 2019 by CC45 Link to comment Share on other sites More sharing options...
Onoff Posted January 27, 2019 Author Share Posted January 27, 2019 (edited) OK...whoever said it'd look better with grout might have had a point. From a distance that is... Just the bath to do now, tiling wise. Edited January 27, 2019 by Onoff 5 Link to comment Share on other sites More sharing options...
Pocster Posted January 27, 2019 Share Posted January 27, 2019 Looks bang on too me . Can’t wait for you to do ( start! ) mine !! Link to comment Share on other sites More sharing options...
newhome Posted January 27, 2019 Share Posted January 27, 2019 Looks good! What's the next job? After the grouting that is. Link to comment Share on other sites More sharing options...
ProDave Posted January 27, 2019 Share Posted January 27, 2019 31 minutes ago, newhome said: Looks good! What's the next job? After the grouting that is. Next year you mean? 1 Link to comment Share on other sites More sharing options...
Onoff Posted January 27, 2019 Author Share Posted January 27, 2019 (edited) 33 minutes ago, newhome said: Looks good! What's the next job? After the grouting that is. - I've to solder that lead to the LED strip that goes up in the long pocket. - Fit & test the extra plinth lights along the side and decide on ones on the end or not. - Fit bath end panel - Grout bath - Silicone where wall and floor meet. Got a Mapei grey. - Colour match silicone (white) any gaps at the various trims - Run a cold mains supply to the basin up in the loft. Could be an issue as I've a single hole mixer tap and the hot is gravity fed. - Shower plate to go on. Do I silicone between the back of the plate and the tiles? Presumably I don't use CT1? - Shower handset / riser to go on. - Wall drain cover to fit - Flush plate to go on - Wall mount WC to go on. Plenty of questions coming! - Paint that wall. SWMBO likes a colour in Wilkinsons of all places but it's not "bathroom" paint. Do any of the sheds make up bathroom paint if I get a Wilko match pot? Etc, etc Roll on Easter! Edited January 27, 2019 by Onoff 1 Link to comment Share on other sites More sharing options...
ProDave Posted January 27, 2019 Share Posted January 27, 2019 I revise my "next job" estimate to 2021 3 Link to comment Share on other sites More sharing options...
newhome Posted January 27, 2019 Share Posted January 27, 2019 54 minutes ago, Onoff said: Roll on Easter! Do you meet deadlines at work? If so how do you strike a balance between speed and compromise, or are you forever conflicted? And surely there must be a bathroom version of that colour paint in another make? What colour is it? Link to comment Share on other sites More sharing options...
PeterW Posted January 27, 2019 Share Posted January 27, 2019 1 hour ago, ProDave said: I revise my "next job" estimate to 2021 Optimist.... 2 Link to comment Share on other sites More sharing options...
Onoff Posted January 27, 2019 Author Share Posted January 27, 2019 59 minutes ago, newhome said: Do you meet deadlines at work? If so how do you strike a balance between speed and compromise, or are you forever conflicted? And surely there must be a bathroom version of that colour paint in another make? What colour is it? I more lurch from one crisis to the next and then manage it to death. What colour, like I know or care! 1 Link to comment Share on other sites More sharing options...
Declan52 Posted January 27, 2019 Share Posted January 27, 2019 2 hours ago, Onoff said: - I've to solder that lead to the LED strip that goes up in the long pocket. - Fit & test the extra plinth lights along the side and decide on ones on the end or not. - Fit bath end panel - Grout bath - Silicone where wall and floor meet. Got a Mapei grey. - Colour match silicone (white) any gaps at the various trims - Run a cold mains supply to the basin up in the loft. Could be an issue as I've a single hole mixer tap and the hot is gravity fed. - Shower plate to go on. Do I silicone between the back of the plate and the tiles? Presumably I don't use CT1? - Shower handset / riser to go on. - Wall drain cover to fit - Flush plate to go on - Wall mount WC to go on. Plenty of questions coming! - Paint that wall. SWMBO likes a colour in Wilkinsons of all places but it's not "bathroom" paint. Do any of the sheds make up bathroom paint if I get a Wilko match pot? Etc, etc Roll on Easter! I put the thinest bead of silicone around my shower plate. Have had to take it off twice in 4 years to clean out the gauze and change the thermostatic valve. 1 Link to comment Share on other sites More sharing options...
Onoff Posted January 27, 2019 Author Share Posted January 27, 2019 (edited) 11 minutes ago, Declan52 said: I put the thinest bead of silicone around my shower plate. Have had to take it off twice in 4 years to clean out the gauze and change the thermostatic valve. Ta. A PRACTICAL comment! Regular, but decent silicone I assume rather than sh!t to blanket stuff like CT1 is what I'm thinking? I've a couple of new tubes of Forever White here that I reckon'll do. Edited January 27, 2019 by Onoff Link to comment Share on other sites More sharing options...
Onoff Posted January 27, 2019 Author Share Posted January 27, 2019 Apparently I don't listen! SWMBO HAS found the colour she likes: However...it doesn't match the blind. Now found that B&Q do Valspar bathroom paint that they'll colour match. The blind will be the next argument. She wants it on the outside of the reveal. Pointless imo and won't help with the cold spot of the cheap 2G window. I want it inside the reveal by the window. I've just been informed (allegedly I was told previously) that it's a patterned blind we're having: I SH!T ye not! 1 Link to comment Share on other sites More sharing options...
newhome Posted January 27, 2019 Share Posted January 27, 2019 15 minutes ago, Onoff said: Apparently I don't listen! No shit huh! 16 minutes ago, Onoff said: I've just been informed (allegedly I was told previously) that it's a patterned blind we're having: Hmm, that's nice and er, busy . Inside or outside - at least you won't see all the tat on the window cill with the blind pulled down if it's on the outside Link to comment Share on other sites More sharing options...
Onoff Posted January 28, 2019 Author Share Posted January 28, 2019 Do I run a very small bead of silicone around where the tiles meet the ceiling? (I forced grout in here on the walls I did. SWMBO didn't). As an aside, I am going to run round this edge with a radiator roller / paint shield and re paint with the Dulux Matt Diamond. Link to comment Share on other sites More sharing options...
Declan52 Posted January 28, 2019 Share Posted January 28, 2019 8 hours ago, Onoff said: Ta. A PRACTICAL comment! Regular, but decent silicone I assume rather than sh!t to blanket stuff like CT1 is what I'm thinking? I've a couple of new tubes of Forever White here that I reckon'll do. Yeah I think it was just bog standard screw fix silicone. Link to comment Share on other sites More sharing options...
PeterW Posted January 28, 2019 Share Posted January 28, 2019 1 hour ago, Onoff said: As an aside, I am going to run round this edge with a radiator roller / paint shield and re paint with the Dulux Matt Diamond. Unless you’ve damaged the ceiling, I wouldn’t do that as it will show up. Would be quicker to just redo the lot carefully. Link to comment Share on other sites More sharing options...
