November 7Nov 7 So the builders have built the corners up to plate and I went out with the wife to measure the diagonals, and there is a 40mm difference between the two diagonals. I appreciate that it is not great, but do I request the walls to be rebuilt?
November 7Nov 7 Author 2 hours ago, Mr Punter said:As long as they are plumb it is acceptable. Will it make any difference to you?I was just more concerned that when I come to cut the roof, it will mean that each rafter will have to be cut individually.
November 7Nov 7 1 hour ago, flanagaj said:... when I come to cut the roof, it will mean that each rafter will have to be cut individually.ex-bleedin-actly.Our chippy's rueful comment about our roof instal " Chippy's always end up correcting everyone else's mistakes "
November 7Nov 7 I mean how good is the wife at holding a tape? Perhaps she is winding you up?!Do you have a laser?
November 7Nov 7 Author 6 minutes ago, Oz07 said:I mean how good is the wife at holding a tape? Perhaps she is winding you up?!Do you have a laser?I don't have a laser measure.
November 7Nov 7 I've not seen your rafter layout but I'm sure you will make it work. A lot worse has been done. Is it deffosquare at the bottom. I'd be worried if the wall was 20mm out of plumb in 1 lift.
November 7Nov 7 17.5m is a long way and you've got a 99.8% agreement. Depending on the aspect ratio of your rectangle, you're talking about an angular error of around 1/8 degrees which is pretty small. Also, measuring with a tape can have issues like sag etc. I'd expect that to be fine. Any rafters can happily accommodate 40mm over the likely length of run which is over 12m.2 hours ago, flanagaj said:I was just more concerned that when I come to cut the roof, it will mean that each rafter will have to be cut individually.If it's a parallelogram, all the rafters will still be the same :-). You'd want to measure ridge to plate for each rafter anyway to check all is well. The thought of getting away with one pattern rafter for a run of >20 is optimistic. Someone may prove me wrong, but that's my feeling.Plumbness is more important
November 8Nov 8 13 hours ago, flanagaj said:I don't have a laser measure.Get one. No ifs buts or maybes. Today. Green one.Get one with a memory function and an image function (so you can check the measurement point) . One that attaches to a tripod. One you can drop in a puddle. One you can read upside down. One you can measure from an internal corner. One that'll do areas and volume calculations. Price? Too much say many. In the context of a house build? Nothing.
November 8Nov 8 and 360 degree too, absolutely worth the investment. Trying to think how often mines been used, oh yeah, all the bloomin time really...Setting out stud walls and making sure they are perpendicular. Setting the ceiling timberwork/battens before plasterboard, joists are rarely level/flat so needed battening/packing prior to boarding. Floors for slc. marking floor and ceiling and end walls prior to plasterboarding, guttering downpipes... Tiling, making sure the tile edges are all in line round the room (how easy for a noob to tile all around the room and find you've gone on the piddle by a few mm).Mine's a relatively cheap huepar jobbie, but it's served me well, and when it jumped of the scaffold (dropped) and it went on the wonk they replaced it for me FOC. Edited November 8Nov 8 by crispy_wafer
November 8Nov 8 Also a decent 3D laser. I have a Huepar 603CG which I have found to be good. Huepar have a reasonable reputation, but I periodically check it to be sure because it's so critical and you don't want to find out that it's wrong. If you are ever going to try to convince someone else of a measurement, a branded one adds credibility. Leica and Bosch are probably the most reputable.
November 8Nov 8 Seems pretty damned good to me over that distance. Do you have any idea how difficult it actually is to set out anything of size with accurate 90 degree corners ?If you get your 9m, 12m, 15m right angled triangle out you'll be able to check it 😂Laser levels are very useful, but if they are not calibrated (how many builders EVER calibrate their laser level once in their lifetime?) you have no idea whether what you are looking at is truly level or not.
November 8Nov 8 On 07/11/2026 at 13:58, flanagaj said:So the builders have built the corners up to plate and I went out with the wife to measure the diagonals, and there is a 40mm difference between the two diagonals. I appreciate that it is not great, but do I request the walls to be rebuilt?40mm across diagonals, in masonry, and you want them rebuilt?? Jeezzzzz.The joiner cutting the roof in won't even raise this with you as they will NEVER have seen anything better in all their days.
November 9Nov 9 The simplest way to check your laser level is to put it in the middle of a large room and mark the height of the laser on each wall. Then rotate the laser round 90 degrees at a time and check the laser still passes through all four marks. Takes about 5 minutes, but gives you confidence nothing has drifted.
November 9Nov 9 If you draw or calculate you'll see that 40mm error over diagonals is about 15mm to 20mm (guess) over the lengths. It isn't good or skilful or helpful but it's normal. 5mm is easily achievable but few care or know it can be done. And few can use a laser or tape properly.So you are alright.
November 9Nov 9 9 hours ago, MortarThePoint said:The simplest way to check your laser level is to put it in the middle of a large room and mark the height of the laser on each wall. Then rotate the laser round 90 degrees at a time and check the laser still passes through all four marks. Takes about 5 minutes, but gives you confidence nothing has drifted.I did this in a big sports hall we worked in for my little laser level. Was 19mm out between the lines. Looked in the specs and that was within tolerance based on the distance. Surprised me! I'd like to think my rotary laser level be a lot more accurate. I have had it calibrated before but won't make a habit of it. If I set out my next plot with it, then check all my pegs with an optical dumpy level I have and they are all the same I'll take that as good enough.@flanagaj as I said earlier be less concerned about that square more about the plumbness
November 9Nov 9 40mm over 17.5m is something you definitely want to flag before the timber frame or roof trusses go on mate. brickies can sometimes fudge small discrepancies but 40mm will give you headaches down the line with plasterboarding and flooring
November 10Nov 10 22 hours ago, MortarThePoint said:to check your laser levelFor level (horizohtal) checking, Choose 2 points.Set the machine up midway and take readings. Alternatively mark the 2 points where the laser hits.Move the laser much closer to one of the points than the other.Take the same readings and the height difference should be the same. OR 2 new marks should be the same distance from each other.This checks if the plumb mechanism is sweeping a true horizontal or is leaning up or down. By doing it equidistant the error cancels out.On old optical levels this could then be adjusted. I don't know about new cheap lasers as I haven't had one, so would like to hear. Edited November 10Nov 10 by saveasteading
November 10Nov 10 But we are not discussing a 40mm level issue here, are we? Just checking. But 40mm discrepancy on the squareness? A long tape or even an inaccurate distance laser will be good enough to assess the difference.
Just now1 min Did you check the flank dimensions? If they are out of parallel to each other,then the diagonal check isn’t really telling you much.
