September 18Sep 18 Hi, I am fitting a wood burner into an old stone fireplace, and I am not sure how to deal with the combustible materials around the edge of the fireplace. I had some insulation fitted via a grant and didn't have a lot of say over how it incorporated the fireplace. You can see from the pictures that the wood studding is directly around the fireplace with insulated plasterboard ontop. My question is can I cover it with some type of fireproof board and fill any gaps with a fireproof cement, or do I need to cut it back from the fireplace entirely to a safe distance from the stove. Which is about an extra 200mm in my case as the spec for the stove is 500mm either side from combustible materials. Currently the distance from the side of the stove to the side of the fireplace is 300mm. The fireplace itself is stone and the chimney is lined, so pretty much good to go apart from the combustible surrounding surface. Cheers, Jonny
September 18Sep 18 Author 3 hours ago, ProDave said: Have you bought the stove yet? Mine only needs 150mm each side to combustibles. Afraid so, it is just the little one in the photo. I bought it second hand, so just a cheapy (£120), so a different stove might be an option. Thanks
September 18Sep 18 That last photo looking up doesnt look great to me, the new wood looks very close, im no expert though. I have had our linner catch fire before and it generates a lot of heat. Could you cut back the drylinning around the fireplace ?
September 19Sep 19 Personally I’d stick to the letter and not have any combustibles even if hidden from sight. Use cement board, mineral wool etc. Agree with @ProDave though - modern stoves are much better made in terms of efficiency, air leaks etc. BTW you know that this is notifiable work and should either be under BC control or by a Hetas person? I did mine under local BC. A carbon monoxide monitor one of the requirements. Might want to look at your liner to check that it’s properly airtight.
September 19Sep 19 All the required clearances are here. Manufacturer's instructions also need to be taken into account in case greater: https://assets.publishing.service.gov.uk/media/6336e58be90e0772dc9651a2/ADJ_2022.pdf
September 19Sep 19 13 minutes ago, Onoff said: All the required clearances are here. Manufacturer's instructions also need to be taken into account in case greater: https://assets.publishing.service.gov.uk/media/6336e58be90e0772dc9651a2/ADJ_2022.pdf Or in my case, less, and building control accepted the manufacturers figures.
September 19Sep 19 If there was no bco, the question I'd ask myself is " can this go on fire due to being hot"? Timber being obviously a combustible material creates confusion. If it is completely enclosed so that flame can't reach it, and there is no oxygen supply, then it cannot burn. But the risk is of someone damaging or penetrating the protective boarding. The insulated plasterboard is a great concern though. It will fail purely through heat,and then maybe some air can get in. Or eps of pir at a joint might be exposed directly. I think you must remove that area of insulation. The effect on insulation is minimal. BUT it is a BCO matter so you not only should do it but must do it. And most bcos I've discussed it with think timber burns even when encased, so perhaps change the timber to something else too, just within the zone distance stated. Metal stud? Multiple layers of cement board? If you must regain the insulation then squeeze in some rockwool if you can. Then you can relax in front of the fire. NB new burners have direct air intake from outside. Yours probably doesn't have that facility so will fail regs.
September 19Sep 19 Author 14 hours ago, carlos21 said: That last photo looking up doesnt look great to me, the new wood looks very close, im no expert though. I have had our linner catch fire before and it generates a lot of heat. Could you cut back the drylinning around the fireplace ? 14 hours ago, carlos21 said: That last photo looking up doesnt look great to me, the new wood looks very close, im no expert though. I have had our linner catch fire before and it generates a lot of heat. Could you cut back the drylinning around the fireplace ? Yes it looks like a problem. I have done a quick scan of the building guidance, and it is too close to the flue. The distance above the appliance seems okay - it is about 650mm, but the distance of that bit of timber to the chimney liner is only about 200mm.
September 19Sep 19 Author 14 hours ago, carlos21 said: That last photo looking up doesnt look great to me, the new wood looks very close, im no expert though. I have had our linner catch fire before and it generates a lot of heat. Could you cut back the drylinning around the fireplace ? There is what I am thinking. Either take the whole wall back to stone, or expose more of the stone work to give the correct/ample clearances.
September 19Sep 19 Author On 19/09/2026 at 08:12, Alan Ambrose said: Personally I’d stick to the letter and not have any combustibles even if hidden from sight. Use cement board, mineral wool etc. Agree with @ProDave though - modern stoves are much better made in terms of efficiency, air leaks etc. BTW you know that this is notifiable work and should either be under BC control or by a Hetas person? I did mine under local BC. A carbon monoxide monitor one of the requirements. Might want to look at your liner to check that it’s properly airtight. Yes, I had heard that, and you promoted me to reach out to them to get a discussion going. I am a little concerned they will say that the chimney needs doing first. The liner seems okay, but the masonry on the chimney itself needs work and I am hoping I can do that later, rather than as part of commissioning the stove -- purely for cash flue priorities.
September 20Sep 20 21 hours ago, jonnym said: cash flue priorities Always the case with stoves! Presumably you want to get this up and running before the heating season? The chimney shouldn’t be an issue as long as you have a suitable and properly installed liner. I would be inclined to cover the existing materials rather than cut them back. The regs do allow for combustibles less than 200mm from the flue as long as there is an air gap of 40mm.
September 21Sep 21 It would be unusual to have a fireplace in an external wall? is that the case here? If not why the insulation?
September 21Sep 21 2 hours ago, jfb said: unusual to have a fireplace in an external wall? In terraces or semis, it has to be on the party wall, but otherwise it is often outside the gable end.
September 21Sep 21 2 minutes ago, saveasteading said: In terraces or semis, it has to be on the party wall, but otherwise it is often outside the gable end. In a previous semi I owned, the frond door and stairs were on the party wall and living room and fireplace were on the end wall. Good layout, made for a quieter living room than semi's with adjoining living rooms.
September 21Sep 21 Author On 19/09/2026 at 08:12, Alan Ambrose said: Personally I’d stick to the letter and not have any combustibles even if hidden from sight. Use cement board, mineral wool etc. Agree with @ProDave though - modern stoves are much better made in terms of efficiency, air leaks etc. BTW you know that this is notifiable work and should either be under BC control or by a Hetas person? I did mine under local BC. A carbon monoxide monitor one of the requirements. Might want to look at your liner to check that it’s properly airtight. Interestingly, I contacted building standards in Na h-Eileanan Siar (Western Isles) and you do not need a building warrant. I got the following response: Regarding the installation of the wood burning stove at the above, I can confirm that under Regulation 5, Schedule 3 of the Building (Scotland) Regulations 2004, a building warrant application is not required. However, whilst the works do not require a building warrant application, the work must still comply, it is your responsibility as owner to ensure compliance with all relevant Standards. So it is all on me...
September 21Sep 21 3 hours ago, jonnym said: So it is all on me... If you do it to the rules you can relax. I can vouch for the benefit of a flue liner. We put a very basic wbs into a traditional fireplace maybe 30 years ago. There was no requirement or expectation then. The stove pipe goes through a baffle then to open brick chimney. It would have drawn better with the smaller duct, and we get mortar coming down as sand. As to the distance to timber, I think you have the options already. Putting in a direct air connection might be trickier and needs a stove designed for it, but they work very much better.
September 25Sep 25 Author On 21/09/2026 at 10:11, jfb said: It would be unusual to have a fireplace in an external wall? is that the case here? If not why the insulation? Its fairly common in my experience (mainly older properties in rural locations). Our house is an extended old stone house, so it may have been for ease of building, and hence the insulation. I have 3 fireplaces, all on external walls.
September 25Sep 25 For me if doubt about anything get a HETAS installer out. Make sure the advice,from forums matches the country you live in, English and Scottish rules are similar, but generally different.
September 27Sep 27 Caution with flue liners. A house near me sadly burnt down when an uninsulated liner happened to sit against a timber build into the chimney. When I did my parents house there was space to shove an insulated twinwall SS liner up the chimney from the bottom.
