AdamD Posted 18 hours ago Posted 18 hours ago Plug broken so doesn’t work properly but unfortunately it’s been pushed down a bit too far, absolutely no idea how to get it out - any ideas appreciated! thanks
AdamD Posted 18 hours ago Author Posted 18 hours ago 18 minutes ago, Mr Punter said: Is there anyone around that you can blame? The kids, but being 4 and 2 I can blame them but not much they can do 😂
AdamD Posted 18 hours ago Author Posted 18 hours ago Just now, JohnMo said: Go from underneath take the u bend off to get access. Yeah I assumed that, take it off and just push it all up?
JohnMo Posted 18 hours ago Posted 18 hours ago Or just unscrew the whole metal piece and replace with new assembly - you seem to find spares for this stuff
AdamD Posted 17 hours ago Author Posted 17 hours ago Can’t seem to get the mechanism out. Haven’t got a spanner big enough to loosen the black bit - any ideas?
Gone West Posted 17 hours ago Posted 17 hours ago 6 minutes ago, AdamD said: any ideas? https://www.screwfix.com/p/magnusson-water-pump-pliers-10-254mm-/1791v
AdamD Posted 17 hours ago Author Posted 17 hours ago Once I’ve got that loose, should the whole mechanism come out fairly easily?
Mr Punter Posted 16 hours ago Posted 16 hours ago I think if you unscrew the white waste pipe - which you should be able to do by hand - you may be able to get to the waste from underneath. Failing that, you may need to replace the waste. Is it a clicker one?
Russell griffiths Posted 16 hours ago Posted 16 hours ago Easier and quicker to go and buy a new pop up waste and fit it, 15 minute job.
AdamD Posted 16 hours ago Author Posted 16 hours ago 26 minutes ago, Mr Punter said: I think if you unscrew the white waste pipe - which you should be able to do by hand - you may be able to get to the waste from underneath. Failing that, you may need to replace the waste. Is it a clicker one? Yeah clicker one. Took the waste off but couldn’t get to it, argh!
Onoff Posted 15 hours ago Posted 15 hours ago 2 hours ago, AdamD said: hanism out. Haven’t got a spanner big enough to loosen the black bit - any ideas? Buy a 3D printer and print a spanner!
MPH243 Posted 14 hours ago Posted 14 hours ago If you can turn the push down plug bit it can be unscrewed to change the push bit. A suction cup might pull it up if it's strong enough?
marshian Posted 13 hours ago Posted 13 hours ago 1 hour ago, MPH243 said: If you can turn the push down plug bit it can be unscrewed to change the push bit. A suction cup might pull it up if it's strong enough? this exactly what I did when Mrs Alien used all her strength to jam it down - once out the sink stayed without a plug for months It doesn't help when she uses bleach every week down plug holes - eventually I replaced it with a swivel type (o ring seal) that also got bleached and the o ring swelled up so now doesn't close nicely - bloody woman thinks the solution to every cleaning is bleach - half my house maintenance tasks are replacing stuff ruined by bleach!!!! 1
saveasteading Posted 2 hours ago Posted 2 hours ago 10 hours ago, marshian said: used all her strength to jam it down In her defence... I have some that work well after the 10 years or more since installation, some that no longer click but screw out, and some that are permanently up. Some of these appear to simply be rubbish products. I'd suggest only buying well known brands or from a plumbers' merchant rather than the other well known outlets. 1
