September 10Sep 10 Another flash gimmick and waste of money thinks philistine me. But "we" are attracted to having a flash hob because it will look sleek and be easy to clean. But will it? A 1mm gap will fill with crumbs and spills and be difficult to clean. Maybe they come with a clever and unobtrusive gasket. Or a tube of special mastic. And cutting it into a stone surface will need some clever and ultra precise work, presumably with a ledge for support. Eg cut the hole then router the perimeter.. to 0.0 mm. I've done no homework. In other words this question is the start of my homework.
September 10Sep 10 I would like one, but think it is too hard to make it dirty free. And a replacement hob won't fit.
September 10Sep 10 This totally sounds like a scene on grand designs where the woman boasts about her expensive kitchen widget and kevin Mc Kevin understands how they are 10 million over budget. Sounds like a way to lock you in to only being able to buy a certain type of hob, whereas a normal one is basically the same size hole. I'd do myself a favour and just keep it simple and not create my future self another nightmare.
September 10Sep 10 gas, glass hob, a bit different. Crappy photo I’m afraid. Edited September 10Sep 10 by Russell griffiths
September 10Sep 10 5 minutes ago, Russell griffiths said: gas, glass hob, a bit different. Crappy photo I’m afraid. If thats a solid wood worktop what happens if it shrinks?
September 10Sep 10 33 minutes ago, Russell griffiths said: gas, glass hob, a bit different. Crappy photo I’m afraid. Possibly the ugliest thing I have ever seen TBH !
September 10Sep 10 1 hour ago, Tony L said: This one looks easy to clean Looks like it may have been around a while but not catching on. So now you have to guess whereabouts to put your pans. So now you just destroyed that mobile phone someone left on the invisible induction area. So now it is invisible, except for the kitchen extractor positioned prominently above it. So now you have to choose a compatible worktop only.
September 10Sep 10 SWMBO has chosen one with a small frame at the edge with the specific opinion that this will help keep spills on the hob. I think the flush mounted can look very cool (saw a white one in a white worktop somewhere) but do we actually want hobs where the boiling over and the spills and spits etc are free to run over the worktop ?
September 11Sep 11 11 hours ago, Beau said: If thats a solid wood worktop what happens if it shrinks? Been there 3 years now, not a bit of movement, kiln dried timber with a near zero moisture content.
September 11Sep 11 13 hours ago, Russell griffiths said: gas, glass hob, a bit different. Crappy photo I’m afraid. Braver man than me. Still if it's not given you any problems yet. That invisible one is shit.
September 11Sep 11 17 hours ago, SteamyTea said: And a replacement hob won't fit. Exactly why the "gap" where our American-style fridge freezer goes is oversized. When I looked at all the different sizes from different manufacturers, and even different models from the same manufacturer, it was a nightmare. Something like a hob with those sort of tolerances in stone? No way.
September 17Sep 17 A modern glass induction hob is less than 5mm thick. I admit that a flush fit may look a tiny bit better but I'm sitting here looking edge-on to my island hob and it isn't exactly unsightly (unlike that glass gas monstrosity above) I would suggest that the astonishingly marginal benefit of easier cleaning is vastly outweighed by the cost and complexity of the install, plus the risk of a replacement not fitting correctly Regards Tet
