BotusBuild Posted Tuesday at 09:23 Posted Tuesday at 09:23 The new garage being built with ICF walls has an internal floor dimensions of about 5m x 6m, with the single pitch (flattish) roof sloping from one 6m side to the other. My current plan is to put in a central 5.5m(ish) beam with joists at right angles (~3m each). Q. Glulam or steel for the central 5.5m beam?
Oz07 Posted Tuesday at 10:32 Posted Tuesday at 10:32 I'd be surprised if glulam is cheaper so I'd lean towards steel. I have a garage 5x5m with 45x 225 timber joists. Was looking at extending the width to 6m and I don't think you can make it work running the joists this way. I can either put a steel over garage door and run timbers 5m way, put rsj in where current 5m wall is, or you can get I beam/jji joists/posi joists to span the 6m. Would that be a solution for you?
BotusBuild Posted Tuesday at 16:44 Author Posted Tuesday at 16:44 A quick bit of research show the Glulam to be about £50-70 cheaper, but would as @Mr Punter says would be deeper. For clarity, this is an approximation of the proposed layout described above (ignore the uneven spacing of the 3m joists)
JohnMo Posted Tuesday at 17:24 Posted Tuesday at 17:24 Do you have to have a flat roof? If not simple roof rafters at a low angle, then you most likely need zero steel or glulam. You just trying hard to make it more complicated and expensive than it needs to be 1
Mr Punter Posted Tuesday at 17:29 Posted Tuesday at 17:29 It could be better as a ridge beam on a low pitched roof.
Tony L Posted Tuesday at 17:38 Posted Tuesday at 17:38 I don't have the same expertise as the other contributors to this thread, but I'd have thought buying in some ready made trusses, to give a low angle dual pitch roof would be the best solution. If you tell the truss company what your roof finish will be, they'll work out the truss spec' for you.
saveasteading Posted Tuesday at 17:43 Posted Tuesday at 17:43 Have a play with this, 5m clear span gives a few possibilities. and as it is a garage the loads can be reduced and maybe plain timber will work. That assumes that it is and always will be a garage! https://www.jamesjones.co.uk/products-and-services/engineered-timber/jji-joists/interactive-span-table 1
BotusBuild Posted Wednesday at 07:19 Author Posted Wednesday at 07:19 13 hours ago, JohnMo said: you have to have a flat roof? Yes
BotusBuild Posted Wednesday at 07:27 Author Posted Wednesday at 07:27 13 hours ago, saveasteading said: That assumes that it is and always will be a garage! It will 😀 and thanks
Russdl Posted Wednesday at 10:27 Posted Wednesday at 10:27 I used galvanised C section joist and timber firings for my almost flat garage roof. Maximum width of 7m reducing to 5m. 1
Oz07 Posted Wednesday at 17:04 Posted Wednesday at 17:04 Thats a good idea are they readily available? Is there span tables anywhere?
Russdl Posted Wednesday at 17:29 Posted Wednesday at 17:29 Definitely readily available, find your local metal fabricator or order direct on line. As for span tables they must be out there, I however relied on the professional help of an SE (Gus Potter of this Parish in my case) to do those calculations for me.
saveasteading Posted Wednesday at 18:19 Posted Wednesday at 18:19 45 minutes ago, Russdl said: I however relied on the professional help of an SE And so should @Oz07. There are overturning loads to consider, and how to fix them down. I have no idea how to fix them to an ICF.
Oz07 Posted Wednesday at 18:54 Posted Wednesday at 18:54 I've found timber span tables you can get 63x220mm c24 to do the job on 400 centres. Expensive though. I'd be interested what works out cheaper c24 or engineered timber joists
ETC Posted Wednesday at 20:17 Posted Wednesday at 20:17 https://www.buildingcontrol-ni.com/assets/pdf/TechnicalBookletD2012.pdf 1
Russdl Posted Wednesday at 20:35 Posted Wednesday at 20:35 1 hour ago, Oz07 said: c24 to do the job on 400 centres. Expensive though For comparison if it helps, in Jul 23 I got 18 cold rolled C section joists delivered, all different sizes (7.4m down to 5.3m) for £1552. And they’re relatively light. 3
Mr Punter Posted Wednesday at 22:39 Posted Wednesday at 22:39 2 hours ago, Russdl said: For comparison if it helps, in Jul 23 I got 18 cold rolled C section joists delivered, all different sizes (7.4m down to 5.3m) for £1552. And they’re relatively light. If they were cut to size that sounds like good value.
Gus Potter Posted Wednesday at 22:56 Posted Wednesday at 22:56 Here is the roof plan. I've screen shotted it, you won't be able to read the detail but can see the shape. Each cold formed cee was a different size, but cf providers can handle it provided you give them a schedule. All for £1552.00! The schedule looks like this, but if the walls are parallel then it is much simpler as all the cees are the same length. On 18/08/2026 at 10:23, BotusBuild said: The new garage being built with ICF walls has an internal floor dimensions of about 5m x 6m, with the single pitch (flattish) roof sloping from one 6m side to the other. I would explore using cold formed joists, creating the fall can be really easy!
Russdl Posted yesterday at 06:55 Posted yesterday at 06:55 @Mr Punter yep, all cut to size. Each one 100mm shorter than the previous. The longest/heaviest was 30kgs so very easy to move around.
BotusBuild Posted 2 hours ago Author Posted 2 hours ago JJI's are cheaper based on short research 16 x 86.06 = 1376.96 or
