MortarThePoint Posted August 5 Posted August 5 I need some beams under a loggia (veranda) with 3.1m spans. The drawing calls for 2no. 8x2 but I'm tempted to go with a Glulam instead for the following reasons: Normal tanalised timber will twist / cup / bow as it dries. The two timbers being joined together would help that but still The total length of the beam is almost 10m including its bearings (atop 150x150 oak posts) so there will need to be joins between sections if done in normal timber. I can have a single length of glulam. Glulam is fun to say The downsides of the Glulam approach are: It's not treated timber It's more expensive: 8x2 joined together. 8x2 is around £3.80/m exVAT around my parts and I'll need to carriage bolts, timber joiners and square washers (£0.25, £0.23, £0.30 ex VAT) about every 400mm so that makes for a cost of £9.55/m exVAT. The Glulam is about £24/m + delivery. As the beam is exterior but under the cover of a roof eave the glulam suppliers are saying Service Class 2 is OK. I could make my own 95mm x 225mm glulam out of tanalised 4x2 at a cost of about £9/m: Timber: £1.60/m * 5 = £8/m Waterproof Urethane Glue: £0.331/m based on 0.16mm thick gives (0.16L/m2) * (4*0.045m) = 0.03L/m , £8.63/0.750 = £11.51/L -> £0.331/m (Soudal Pro 45P D4 professional waterproof polyurethane wood adhesive). Fixings: £0.45/m based on 1no. 5mm x 80mm every 400mm for each joint so works out as one every 100mm, 10/m and they cost £4.50/100 The eased edges would make for bumps in the beam which are a shame. Scant timber is actually more expensive (+33%) than eased edge and I don't know how available it is tanalised. Planing off the eased edge would reduce the timber to about 40mm and the glulam to 95mm x 200mm or raise the number of laminations to 6. It would likely cost a jointer blade too (£12) as well as taking a very long time. It will get painted, so I could not remove the eased edges and fill all the grooves with waterproof wood filler (120ml/m -> £1.50/m). Has anyone else been down this road, either buying a premade glulam or making one themselves?
Oz07 Posted August 5 Posted August 5 5 hours ago, MortarThePoint said: I need some beams under a loggia (veranda) with 3.1m spans. The drawing calls for 2no. 8x2 but I'm tempted to go with a Glulam instead for the following reasons: Normal tanalised timber will twist / cup / bow as it dries. The two timbers being joined together would help that but still The total length of the beam is almost 10m including its bearings (atop 150x150 oak posts) so there will need to be joins between sections if done in normal timber. I can have a single length of glulam. Glulam is fun to say The downsides of the Glulam approach are: It's not treated timber It's more expensive: 8x2 joined together. 8x2 is around £3.80/m exVAT around my parts and I'll need to carriage bolts, timber joiners and square washers (£0.25, £0.23, £0.30 ex VAT) about every 400mm so that makes for a cost of £9.55/m exVAT. The Glulam is about £24/m + delivery. As the beam is exterior but under the cover of a roof eave the glulam suppliers are saying Service Class 2 is OK. I could make my own 95mm x 225mm glulam out of tanalised 4x2 at a cost of about £9/m: Timber: £1.60/m * 5 = £8/m Waterproof Urethane Glue: £0.331/m based on 0.16mm thick gives (0.16L/m2) * (4*0.045m) = 0.03L/m , £8.63/0.750 = £11.51/L -> £0.331/m (Soudal Pro 45P D4 professional waterproof polyurethane wood adhesive). Fixings: £0.45/m based on 1no. 5mm x 80mm every 400mm for each joint so works out as one every 100mm, 10/m and they cost £4.50/100 The eased edges would make for bumps in the beam which are a shame. Scant timber is actually more expensive (+33%) than eased edge and I don't know how available it is tanalised. Planing off the eased edge would reduce the timber to about 40mm and the glulam to 95mm x 200mm or raise the number of laminations to 6. It would likely cost a jointer blade too (£12) as well as taking a very long time. It will get painted, so I could not remove the eased edges and fill all the grooves with waterproof wood filler (120ml/m -> £1.50/m). Has anyone else been down this road, either buying a premade glulam or making one themselves? Use the 8x2
Gus Potter Posted August 5 Posted August 5 (edited) 10 hours ago, MortarThePoint said: need some beams under a loggia (veranda) with 3.1m spans. Is this a trick? Some say a loggia is part of the main structure or are you just being too smart. If it is part of the main structure then you also have to often transfer sideways sway resistance back in the main structure. Or have another way of resisting lateral sway. Post a dimensioned drawing and let us see what you are wanting to achieve. It looks to me like you are designing on the hoof, but don't actually understand what you are doing. Get a grip of this first and then think about your timber / Gluelam selection and the appropriate connections. Your connections are vitally important. But I suspect you have to date not given this some serious thought. Just ask yourself what is going to stop this swaying sideways. Edited August 5 by Gus Potter
MortarThePoint Posted August 6 Author Posted August 6 7 hours ago, Gus Potter said: Is this a trick? Some say a loggia is part of the main structure or are you just being too smart. If it is part of the main structure then you also have to often transfer sideways sway resistance back in the main structure. Or have another way of resisting lateral sway. Post a dimensioned drawing and let us see what you are wanting to achieve. It looks to me like you are designing on the hoof, but don't actually understand what you are doing. Get a grip of this first and then think about your timber / Gluelam selection and the appropriate connections. Your connections are vitally important. But I suspect you have to date not given this some serious thought. Just ask yourself what is going to stop this swaying sideways. Sorry, I should have shared more context and the other thread about the loggia which you have kindly contributed to. My last query there was whether I needed ceiling level ties to constrain the main beams laterally or whether the bracketry would achieve that on its own.
markc Posted August 6 Posted August 6 An alternative to Glulam especially if you are going to paint it is PSL .. think of OSB in beam form. Dense, doesn’t rot, bend or split etc.
MortarThePoint Posted August 6 Author Posted August 6 20 minutes ago, markc said: An alternative to Glulam especially if you are going to paint it is PSL .. think of OSB in beam form. Dense, doesn’t rot, bend or split etc. Interesting, but I'd be a little nervous of using them externally.
SimonD Posted August 6 Posted August 6 20 hours ago, MortarThePoint said: either buying a premade glulam Yes, and they're great. All ours came from https://www.bucklandtimber.co.uk/ They'll design and supply all junctions and fixing for you too. 2 1
saveasteading Posted August 6 Posted August 6 I made a pergola with a Glulam equivalent. The main difference being that this was in Spain. So termites and heat were more the worry than wet. After 7/8 years it's good. In UK conditions I'd ve worried about the effect of prolonged dampness on the wood and the glue. So my suggestion is to get treated timber, preferably choosing the lengths yourself. Now would be a good time because they might be dry. I'd want to set them aside with air flow and a cover for a few weeks. If they distort then get them changed because they are not supposed to. The timber association TRADA says they should be kept dry but no merchants pay any attention.... I had 50 big pieces exchanged without protest. Then bolt them together at 500mm cc max and perhaps add nail plates.
MortarThePoint Posted August 6 Author Posted August 6 I like the idea of making my own glulam as it saves a lot of lead times and would be fun to do. The main concern would be the effects of weather (humidfity and temperature) and whether that could cause delamination. I guess if I choose the right glue, it shouldn't be much more likely to fail than an off the shelf glulam, though those probably use pressure during the glue curing and I could only use the pressure provided my screws.
saveasteading Posted August 6 Posted August 6 1 hour ago, MortarThePoint said: if I choose the right glue, That's why I suggested bolts and nail plates. Add glue if you want and the bolts will pull it tight. But even if the glue fails completely it will perform as well. Nailplates: I've used the wrong term. I had in kind these, called plate connectors but meant that they had spikes on both sides to join the touching faces. But these linking the tops and bottoms would work. I'm assuming it's out of sight!
MortarThePoint Posted August 6 Author Posted August 6 37 minutes ago, saveasteading said: That's why I suggested bolts and nail plates. Add glue if you want and the bolts will pull it tight. But even if the glue fails completely it will perform as well. Nailplates: I've used the wrong term. I had in kind these, called plate connectors but meant that they had spikes on both sides to join the touching faces. But these linking the tops and bottoms would work. I'm assuming it's out of sight! Was hoping to leave it on show and paint it. Using screws internally to the glulam would allow three faces to have no fixings showing
saveasteading Posted August 6 Posted August 6 52 minutes ago, MortarThePoint said: Was hoping to leave it on show and paint it. Isn't the attraction of glulam , other than the long spans which you don't have, that it looks pretty? Painting and screws kind of lose that. OK I think I'm going to let you get on with it. But good luck.
Russell griffiths Posted August 8 Posted August 8 I have a couple of large beams under a carport i used a kerto beam instead of gluelam, loads cheaper.
Oz07 Posted August 8 Posted August 8 19 minutes ago, Russell griffiths said: I have a couple of large beams under a carport i used a kerto beam instead of gluelam, loads cheaper. Did you price it up vs steel? Not sure if just went to a dear supplier but had a price years ago and steel was cheaper. Crazy.
saveasteading Posted August 8 Posted August 8 3 hours ago, Oz07 said: steel was cheaper. Crazy. Not really. Steel is old tech and mass produced. Kerto is hitech and a smaller market...and heavy. You might even find second hand steel.
Gus Potter Posted August 8 Posted August 8 On 06/08/2026 at 07:06, MortarThePoint said: Sorry, I should have shared more context and the other thread about the loggia which you have kindly contributed to. My last query there was whether I needed ceiling level ties to constrain the main beams laterally or whether the bracketry would achieve that on its own. Hiya. The base brackets you show act as pins, they are just intended to carry vertical load only. They do have a minimal shear load capacity, but it is minimal. That (shear) is the load horizontal to the plane of the ground surface. The brackets you show are of minimal strength. To stop it moving sideways there are a number of different options. We can do a flat portal type of frame, often with knee braces. But this is going to introduce shear load into the brackets you show, they are not big enough and likely neither are the pads they rest on by the looks of things. The pads might be able to carry vertical load but not horizontal loading. Or you can fit a stiff floor and roof. These then act as a diaphragm and transfer the sideways loads back to the main house. But you have to check the main house can carry this extra load. To give you a better answer, with more explanation on how it works, need to see cross section drawings and a bit more of the house you are going to add load to if you use the diaphragm method. On 06/08/2026 at 17:21, MortarThePoint said: I like the idea of making my own glulam as it saves a lot of lead times and would be fun to do. The main concern would be the effects of weather (humidfity and temperature) and whether that could cause delamination. I guess if I choose the right glue, it shouldn't be much more likely to fail than an off the shelf glulam, though those probably use pressure during the glue curing and I could only use the pressure provided my screws. Ah like your idea. Quick story. When I was at uni one of my structures lecturers was into wood as a hobby. He used to buy tree trunks, cut them up into sizes in his garden, season the wood and make stuff. He did an extension with a curved vaulted ceiling in oak. To make it work he wanted to laminate the planks, turn them into a Glulam type beam We had remained in touch and once I started practising he asked me if I though I could prove this calculation wise. The answer is yes. I won't explain here but it's not too hard, if you know how to do it. This can be done DIY on a modest scale. In fact I'm deploying the same idea over a set of doors with a triangular glazed window above. I'm turning the individual 95 x 45 into a "Glulam" to carry the weight from the triangular glass above. But also I turn it into a solid timber so it better resists the wind load on the doors and glass. The cranked steels above carry the roof load. Here are the notes that go with the transom. For you you are going to needs lots of clamps. You can used tie bolts also, messy unless you want to leave them in place. The secret is to condition your timber and make sure all glue surfaces are clean, free from oils etc, roughen them a bit and don't rush the job. In other words cleanliness is next to godliness as is diligence. Here is a bridge near where I live. The photo, near where I live is not that good of a laminated bridge. There are bolts going down from the top to the bottom of the beam. These transfer the shear loads between the laminations. Glue is more efficient. Hope this help inspire you to give it a go!
MortarThePoint Posted August 9 Author Posted August 9 Thanks Gus, nice examples of Glulams 9 hours ago, Gus Potter said: The base brackets you show act as pins, they are just intended to carry vertical load only. On another thread I has detailed changing to using Staddle Stones and my rough calculations there suggest a lateral force capacity at the bottom of the post of at least 80kg (without pin and resin into concrete below stone) and I'd expect much more (with pin and resin into concrete). The main structural question I am struggling with is whether I need ceiling level timber ties back to the house structure. I'd consider the coupling between the post and the staddle stone to be free to rotate, so just providing lateral and vertical constraint but not rotary. More discussion here:
Russell griffiths Posted August 9 Posted August 9 14 hours ago, Oz07 said: Did you price it up vs steel? Not sure if just went to a dear supplier but had a price years ago and steel was cheaper. Crazy. It’s visable and will be stained to match the rest of the timber, steel wasn’t even an option. I didn’t think it was expensive really.
saveasteading Posted August 9 Posted August 9 It's easy to fix it down with Simpson angles. Then it is fixed, not pinned. Best to use one each face. I'd also suggest keeping the timber up on a small plinth so it gets a chance to dry between wet times. (And I'd paint the bottom in blackjack) You quite likely don't need glulam if the joints are all solid, but it does look nice.
Oz07 Posted August 9 Posted August 9 13 hours ago, saveasteading said: Not really. Steel is old tech and mass produced. Kerto is hitech and a smaller market...and heavy. You might even find second hand steel. I think a lot more energy goes into producing steel. I bet you would find a keto type product is cheaper vs steel in the states where they seem to use timber products a lot more
JohnMo Posted August 9 Posted August 9 If your drawing say 2 off 8x2 I agree with @Oz07 do that, no need to over think it. By the time the 2 pieces are all joined together and fixed in place they aren't going anywhere. 2
saveasteading Posted August 9 Posted August 9 5 hours ago, Oz07 said: A lot more energy goes into producing steel. I'm sure that's right but that may come second in countries where energy is cheap: US, China. The efficency of steel is the I (eye) shape as the top and bottom do the work and the web separates them. Whereas in solid kerto or glulam the middle is full of wood. The timber isn't waste but prime material shaved off s log then lots of resin. So it doesn't spring to mind as an obvious winner... but I don't know. I've done jobs where we analysed joists in timber, steel Z purlins, and fabricated timber ( web of osb). What's best you ask? Used all 3 in different circumstances of load and span. 1
Gus Potter Posted August 10 Posted August 10 (edited) On 09/08/2026 at 07:50, MortarThePoint said: On another thread I has detailed changing to using Staddle Stones and my rough calculations there suggest a lateral force capacity at the bottom of the post of at least 80kg (without pin and resin into concrete below stone) and I'd expect much more (with pin and resin into concrete). For these to work, there is a bit more to the equation. I can see how you are thinking about shear load transfer between the bottom of the post and the straddle stone, but what you show still acts as a pinned joint in terms of rotation between the bottom of the column and the top of the stone. . Unless the bending force is fully transferred by the dowel it's going to cause an over turning effect in the stone. A pin like this does not work. Also to resist this you need adequate soil lateral passive resistance, which I think you will struggle to achieve. And then we need to look at frost resistance ( the ground freezing and heaving) for example. It's up to you, if it heaves or moves then the risk is yours. Main thing is if it starts to fail that no one gets hurt and you don't damage the house. On 09/08/2026 at 07:50, MortarThePoint said: The main structural question I am struggling with is whether I need ceiling level timber ties back to the house structure. I'd consider the coupling between the post and the staddle stone to be free to rotate, so just providing lateral and vertical constraint but not rotary. Technically you don't need ceiling ties if the roof is made stiff, like a big deep beam. This can be achieved by using say OSB / Ply / traditional timber sarking to the tops of the rafters. Lining the underside with ply makes it even stiffer. In the round we want to: 1/ Stop the front of the logia moving sideways parallel to the main house wall. We can do this by making the roof stiff and connecting it back to the main house wall so the main house wall resists the basic sideways shear, but also what we call complimentary shear. Here is quick diagram I copied from the internet. You can test this at home using a cardboard box with one side cut away. If you want to understand what's going on try it yourself for a bit of fun. Tape the box down to a table in different places and experiment, you can learn a huge amount about structural behaviour by just having a glass of wine and mucking about. 2/ The front of the logia moving away from the main house wall, perpendicular movement. The main thing here is to check the house can take these extra loads. Often you'll find that the external leaf, particularly masonry protests a lot if it is pulled outwards between the floor levels. I think the best thing, and most probably less hassle is to allow the house to carry half the vertical loads roof, they will be small as any snow, snow drift or snow falling off the main house roof will just slide of as the roof is steep. Normally we design for a roof access load, this get reduced when the roof is steep. Then look to see if it works along the front / sides Architecturally with a knee braces shown in red. The base of the columns would have some beefy 6.0mm thick or so fabricated brackets. The corner columns well attached to say 600 x 600 x 600 deep concrete pad foundations. I'll not explain here how / where the forces go in detail. But if you are thinking about laminating timbers up yourself it could be great fun to do and cost effective. The vaulting with no ceiling ties is attractive Architecturally to me. Try the cardboard box thing! if you can live with knee braces then it's a very efficient way of doing it. Let us know your thought on the braces. To add a bit. I like to design stuff using glue, but am always cautions that a builder may not follow my instructions. The previous drawing I posted is reasonably idiot proof as there are the nails as well. But I have some Client's, some are self builders who are really diligent. One in particular has built small boats so is experienced in gluing bits of timber together, they know to keep things clean and take care. If you're careful then you'll find that laminating up your own stuff, making joints is very satisfying. Glue works particularly well when in shear, we all know a good glued joint is often stronger than the wood itself. Edited August 10 by Gus Potter 1
MortarThePoint Posted August 10 Author Posted August 10 Thanks Gus. The main thoughts on the Staddle Stone thread are along the lines of assuming the top of the post is constrained by a connection that leave it free to rotate, would the Staddle Stone be a point of failure. So only really considering if the Staddle Stone could constrain the post vertically and horizontally, but not rotationally. I then assume that if you have a rigid body translationally constrained in two separate locations, it is then also rotationally constrained. 24 minutes ago, Gus Potter said: 1/ Stop the front of the logia moving sideways parallel to the main house wall. Interesting, I was so focused on whether the posts were sufficiently supported in terms of tipping away or towards the house walls that I forgot to consider them tipping parallel to the walls. I can see that OSB/plywood on top or sandwiching the rafters would prevent that. I was hoping to have V-groove on top of the rafters so this could work as plywood. 29 minutes ago, Gus Potter said: 2/ The front of the logia moving away from the main house wall, perpendicular movement. This has been my main quandary. Really I want the loggia to only place a vertical load on the outer leaf of the house. The weight of the tiles onto the top ledger should be about ((1.375m / 2) / COS(46)) * 77kg/m2 = 76.8kg/m -> 0.8kN/m. If I crudely double that for snow etc, I'm looking at 1.6kN/m order of magnitude which is the weight of 1m height of brickwork [ (1m*0.1m*1600kg/m3) = 160kg -> 1.6kN ], so easily within scope. Lateral forces on the brickwork are much more of a concern as they rely on the wall ties and or weight of brickwork above as I understand it. The weight of brickwork above isn't much for most of it at the possible height of any ceiling ties and is tiny at the height of the top ledger due to a large group of windows. I should have shared that image earlier I suppose, sorry. 43 minutes ago, Gus Potter said: Then look to see if it works along the front / sides Architecturally with a knee braces shown in red. The base of the columns would have some beefy 6.0mm thick or so fabricated brackets. The corner columns well attached to say 600 x 600 x 600 deep concrete pad foundations. I'll not explain here how / where the forces go in detail. But if you are thinking about laminating timbers up yourself it could be great fun to do and cost effective. The vaulting with no ceiling ties is attractive Architecturally to me. The knee braces could work aesthetically if they are needed structurally. The foundation pads are around 600x600x600 poured on top of larger concrete pads of around 1m x 1m x 1.25m. I agree that the vaulting with no ceiling ties is a much more attractive look.
MortarThePoint Posted August 11 Author Posted August 11 9 hours ago, MortarThePoint said: Lateral forces on the brickwork are much more of a concern as they rely on the wall ties and or weight of brickwork above as I understand it. The weight of brickwork above isn't much for most of it at the possible height of any ceiling ties and is tiny at the height of the top ledger due to a large group of windows. I should have shared that image earlier I suppose, sorry. That should have said lateral forces towards and away from the house are much more of a concern ... 1
