MortarThePoint Posted 13 hours ago Posted 13 hours ago I need some beams under a loggia (veranda) with 3.1m spans. The drawing calls for 2no. 8x2 but I'm tempted to go with a Glulam instead for the following reasons: Normal tanalised timber will twist / cup / bow as it dries. The two timbers being joined together would help that but still The total length of the beam is almost 10m including its bearings (atop 150x150 oak posts) so there will need to be joins between sections if done in normal timber. I can have a single length of glulam. Glulam is fun to say The downsides of the Glulam approach are: It's not treated timber It's more expensive: 8x2 joined together. 8x2 is around £3.80/m exVAT around my parts and I'll need to carriage bolts, timber joiners and square washers (£0.25, £0.23, £0.30 ex VAT) about every 400mm so that makes for a cost of £9.55/m exVAT. The Glulam is about £24/m + delivery. As the beam is exterior but under the cover of a roof eave the glulam suppliers are saying Service Class 2 is OK. I could make my own 95mm x 225mm glulam out of tanalised 4x2 at a cost of about £9/m: Timber: £1.60/m * 5 = £8/m Waterproof Urethane Glue: £0.331/m based on 0.16mm thick gives (0.16L/m2) * (4*0.045m) = 0.03L/m , £8.63/0.750 = £11.51/L -> £0.331/m (Soudal Pro 45P D4 professional waterproof polyurethane wood adhesive). Fixings: £0.45/m based on 1no. 5mm x 80mm every 400mm for each joint so works out as one every 100mm, 10/m and they cost £4.50/100 The eased edges would make for bumps in the beam which are a shame. Scant timber is actually more expensive (+33%) than eased edge and I don't know how available it is tanalised. Planing off the eased edge would reduce the timber to about 40mm and the glulam to 95mm x 200mm or raise the number of laminations to 6. It would likely cost a jointer blade too (£12) as well as taking a very long time. It will get painted, so I could not remove the eased edges and fill all the grooves with waterproof wood filler (120ml/m -> £1.50/m). Has anyone else been down this road, either buying a premade glulam or making one themselves?
Oz07 Posted 8 hours ago Posted 8 hours ago 5 hours ago, MortarThePoint said: I need some beams under a loggia (veranda) with 3.1m spans. The drawing calls for 2no. 8x2 but I'm tempted to go with a Glulam instead for the following reasons: Normal tanalised timber will twist / cup / bow as it dries. The two timbers being joined together would help that but still The total length of the beam is almost 10m including its bearings (atop 150x150 oak posts) so there will need to be joins between sections if done in normal timber. I can have a single length of glulam. Glulam is fun to say The downsides of the Glulam approach are: It's not treated timber It's more expensive: 8x2 joined together. 8x2 is around £3.80/m exVAT around my parts and I'll need to carriage bolts, timber joiners and square washers (£0.25, £0.23, £0.30 ex VAT) about every 400mm so that makes for a cost of £9.55/m exVAT. The Glulam is about £24/m + delivery. As the beam is exterior but under the cover of a roof eave the glulam suppliers are saying Service Class 2 is OK. I could make my own 95mm x 225mm glulam out of tanalised 4x2 at a cost of about £9/m: Timber: £1.60/m * 5 = £8/m Waterproof Urethane Glue: £0.331/m based on 0.16mm thick gives (0.16L/m2) * (4*0.045m) = 0.03L/m , £8.63/0.750 = £11.51/L -> £0.331/m (Soudal Pro 45P D4 professional waterproof polyurethane wood adhesive). Fixings: £0.45/m based on 1no. 5mm x 80mm every 400mm for each joint so works out as one every 100mm, 10/m and they cost £4.50/100 The eased edges would make for bumps in the beam which are a shame. Scant timber is actually more expensive (+33%) than eased edge and I don't know how available it is tanalised. Planing off the eased edge would reduce the timber to about 40mm and the glulam to 95mm x 200mm or raise the number of laminations to 6. It would likely cost a jointer blade too (£12) as well as taking a very long time. It will get painted, so I could not remove the eased edges and fill all the grooves with waterproof wood filler (120ml/m -> £1.50/m). Has anyone else been down this road, either buying a premade glulam or making one themselves? Use the 8x2
Gus Potter Posted 3 hours ago Posted 3 hours ago (edited) 10 hours ago, MortarThePoint said: need some beams under a loggia (veranda) with 3.1m spans. Is this a trick? Some say a loggia is part of the main structure or are you just being too smart. If it is part of the main structure then you also have to often transfer sideways sway resistance back in the main structure. Or have another way of resisting lateral sway. Post a dimensioned drawing and let us see what you are wanting to achieve. It looks to me like you are designing on the hoof, but don't actually understand what you are doing. Get a grip of this first and then think about your timber / Gluelam selection and the appropriate connections. Your connections are vitally important. But I suspect you have to date not given this some serious thought. Just ask yourself what is going to stop this swaying sideways. Edited 3 hours ago by Gus Potter
