sansserif Posted 7 hours ago Posted 7 hours ago Hi all Wondering if anyone has any thoughts re: exterior wall insulation for my timber frame build. I'm shooting for an energy efficient build, but not chasing perfection by trying to hit passiv standards. I'd like to hit a sweet spot between price and performance. It looks like the "standard" exterior wall build-up from TF firms is 140mm studs + PIR to hit a decent U-value. But I'm wondering wondering if I'm missing a trick by not considering other insulation options? In particular, it would be great to have something that's a more organic material, lower VOC etc... Anyone have any advice? What's worked well for you all?
saveasteading Posted 6 hours ago Posted 6 hours ago 24 minutes ago, sansserif said: any advice before any further thoughts could you advise on the roof verge detail? ie if you built 150mm or so out from the walls, does that fly past gutters and roof covering? similarly at the bottom, are there any obstructions such as manholes? And what distance is the nearest wall to a boundary. roughly if it over 2m, otherwise exactly in case it affects fire regs or any access you have.
sansserif Posted 6 hours ago Author Posted 6 hours ago The designs have an allowance for a ~300mm exterior wall thickness, excluding rain screen and plasterboard etc. Would be great to not need the full 300mm though. Design has a gable roof with a that overhangs about 50mm over the gable end. Distance to nearest boundary is 0.8m, and around 1.8m to the nearest building. No (known) nearby obstructions!
Mr Punter Posted 5 hours ago Posted 5 hours ago 1 hour ago, sansserif said: In particular, it would be great to have something that's a more organic material, lower VOC etc... Insulation tends to be mineral wool or PIR. What is the proposed "rain screen"?
sansserif Posted 5 hours ago Author Posted 5 hours ago Rain screen would be brick (ground floor) and render (above)
Mr Punter Posted 4 hours ago Posted 4 hours ago You could fully fill with 140mm pir between studs and line internally with 50mm pir, held on with 38 x 50 battens to create a service cavity. You could put the 50mm on the outside but you will need different wall ties and another layer of breather membrane etc. You will need about 30mm cavity to the brickwork. If the timber frame co quote for the insulation it saves a lot off faff and mess on site.
Roundtuit Posted 1 hour ago Posted 1 hour ago Typically I think 140mm studs are filled with 120mm PIR due manufacturing tolerances, then we lined with another 40mm. I'm sure there are other rockwool/cellulose options you could look at with 300mm to play with. A 50mm cavity between frame and outer skin is required if you have masonry I believe. Mixing insulation will probably need some sort of condensation risk doing to avoid a dew-point in the wrong place.
G and J Posted 56 minutes ago Posted 56 minutes ago Ummm, the title confused me. At first I thought you were talking about insulation outboard of the frame/OSB. But I think you are looking at insulation between the studs of the frame and inboard of that. I think the 120mm PIR in a 140mm stud is about an air gap next to a reflective coating. So better insulation overall than full fill PIR. I am biased. I hate PIR with a passion. Used it under our floor a bit and regretted it. Should’ve made sure I had enough space for polystyrene only. We used mineral wool in our frame and another layer inside. I may be kidding myself but I now believe it’s a nicer job to do and nicer to live in. The only place PIR looks good is on a spreadsheet.
