Post and beam Posted Monday at 14:54 Posted Monday at 14:54 What i saw at the show when i looked inside their unit. Cheap looking bent tin and electronics that looked like a 4th form GCSE project using an Arduino. Untidy & cheap looking. Their summer by-pass was an extra cost add on, dont like that. Rega vents design was a branched idea as well which i expressly did not want. 1 1
Nickfromwales Posted Monday at 18:29 Posted Monday at 18:29 6 hours ago, Indy said: Care to expand why? I was also quoted a similar amount for a REGA unit - £5k for supply only, £7k for supply and install. Chose to go with Zehnder based on recommendations (which has turned out to be much more expensive sadly!) but I'd like to understand why REGA are considered so bad. I could show some pics of installs, ducting like tumble drier hose, held up (strangled) with cable ties, and other such very 1st year apprentice stuff. Looked like fed up teenagers fitted it as part of community service. Just worse than bread & butter stuff, and failures of whole house systems which needed total gut out by replacement suppliers and installers. As said, avoid. Or don’t.
Pocster Posted 21 hours ago Posted 21 hours ago @Wadrian . I did it. That's all you need to know for how easy it was. I think from memory and some years ago unit and pipework maybe 3k ish.
Pocster Posted 21 hours ago Posted 21 hours ago On 02/07/2026 at 17:42, Wadrian said: Think I had read £10k on earlier post on Buildhub. Would be good to know if this is wrong 10K is correct. That's what I charge.
Nickfromwales Posted 14 hours ago Posted 14 hours ago 7 hours ago, Pocster said: 10K is correct. That's what I charge. He actually only charges £9k, the rest is my manager's fees.
Indy Posted 2 hours ago Posted 2 hours ago I know some will baulk at these costs but £10k is exactly what I paid so that number is not unrealistic for a fully designed, supplied, installed and commissioned system. Mine is the Q450 with 90mm ducting 1. Design - £600 2. Supply - £6400 3. Commissioning - £500 4. Install - £2500 1
