Morning all,
Another conundrum!  Plan was always brise soleil on posts independent from building - but have decided shutters will be preferable for various reasons including easy access to gutters, full blocking of the sun, and cost. (not idiot proof of course for future occupants but hey-ho, that's called natural selection!). We have leftover cladding and reveal boards so aim is something simple as example image.  But now I'm thinking about it properly struggling to decide best way to hinge - reveal boards slightly proud of cladding (as intended). Also need to keep cost down - some stainless steel hinges are crazy prices! (we need stainless steel as sweet chestnut).  Ideas would be very much appreciated please :)
You also need to consider how to hold them open and secure them closed, gain ventilation as well as if they would be an issue should a fire break out.
Our last house had them but installed inside the window. Didn't use them much but they transform the way the house feels. But ours were built in to the window frame 200 years ago.
Having them inside has a number of advantages
No wind rattling them. Or trying to pull them off the wall if not fully restrained.
Friction of the hinge is enough to hold them in any position you want when inside.
They keep heat out and in if you want.
Safety, if you are trying to get out if the building on fire you can, on the outside not sure you could.
You can add a layer insulation to the inside shutter and make it thermally ace.
Not sure I understand that point
Edited by JohnMo
I still haven't worked out the hinge answer which was question number one in terms of feasibility / cost  -  holding shutters open/closed and rattling was on my mind but now highlighted (thank you both - always good to talk through :) ) it's also an issue with the need for stainless steel if I'm using chestnut I already have!  Cabin hooks (silly money in stainless) won't stop the rattle and will add to it - shutter dogs expensive (and not off the shelf anywhere by the looks in stainless).  I could make dogs / latches from chestnut but not ideal and I don't have the time - need quite a few!
(Has to be external to stop the sun before it hits the glass cutting out unwanted solar gains in summer  /  access to gutters for cleaning and maintenance - especially as we have full on RWH!  /  windows not fire escapes).
Conclusion:
1.  Hinged shutters not as straightforward and economical as I had initially thought!
2. Sliding? Unlikely to be practical using chestnut we already have and hardware going to be expensive.  And back to rattling, and probably movement issues. Cost will be very high for something bespoke say in aluminium.
3.  So, therefore rapidly going back to brise soleil it seems!  I shall explore some alternatives - we could add to the Romans list!  I'm going to start another post on this........
What can a CFO ever do for you? — The CFO Limitedimage.png.35e18ce22fe0d80207ecede3042441d2.png
Regarding the stainless steel.
isn’t it the fixings that need to be stainless not the hardware.
I could not see how a galvanised hinge would be a problem fitted to the face of a shutter if stainless screws that penetrate the timber are used.
why not do some experiments in the garden with some off cuts.
I was thinking anything in contact, but yes extremely good point...... I shall be thinking further, if indeed I solve the hinge issue without it looking like a dog's dinner!
Could you use parliament hinges.
or go to france and buy what they use, they have a crank in the arm to kick the shutter out.
order a set online then get your local blacksmith to knock something up.
depends how rustic you want it.
very common in Europe.
