Warben Posted 6 hours ago Posted 6 hours ago I’m planning a single-storey rear extension with a basement underneath, and I’d love to hear from anyone with experience of something similar — particularly around costs (£/m²) and who to get involved. The rear of the property sits on a significant slope, so a retaining wall will be needed regardless. I’m in North Somerset, about 20 minutes from Bristol. The basement doesn’t need to be the same size as the basement. I’ve put a picture of the rear of the property below. The main reason for the basement is acoustic separation — I want to use the space as a music room (drums, electric guitar) along with a cinema room or gym. Being below ground should help keep the noise away from the rest of the house naturally. I’m keeping it single-storey partly because light is already a consideration on this plot, and I don’t want to affect the neighbours’ light either. The plan is to use rooflights to bring as much natural light into the extension as possible. So — who exactly needs to be involved (specific type of architect, structural engineer, specialist basement contractor?), and what are realistic cost expectations for this kind of build in the South West? I know basements aren’t everyone’s first suggestion, but I’m genuinely keen on the idea and would love to hear from people who’ve actually done something similar rather than just being talked out of it!
Nickfromwales Posted 5 hours ago Posted 5 hours ago 49 minutes ago, Warben said: The basement doesn’t need to be the same size as the basement Ok, lol. Which way around does that need to go and I’ll edit it for you Go for it, I’m a big fan of basements, and I think this would be a good candidate for an EPS based ICF. Many birds, one stone. Any plans you can share yet, for comment?
saveasteading Posted 5 hours ago Posted 5 hours ago 54 minutes ago, Warben said: actually done something similar Need to know a lot more. Existing house construction. Which way is the slope the gradient. Are other structures or boundaries nearby. Ease of access. What kind of ground. Size of course. Basements are inherently expensive. Gut feeling with no info: 3 x normal cost. but perhaps yours is more an extension at lower level. Double? So start with that. 8k/m2 or more. I wouldn't start with any consultant as long as you can sketch to scale. You sketch your ideas first and put them on here.
ProDave Posted 4 hours ago Posted 4 hours ago What do you mean by a "single storey extension with basement underneath" Looking at your picture, a single storey extension level with the existing ground floor would already be part underground (semi basement) Are you suggesting a basement below that? That would be really deep. Or some split level design (extension not necessarilly level with existing floors) A separate building well away from the house is what most people do for a drum kit.
Mr Punter Posted 4 hours ago Posted 4 hours ago Can you clarify if you intend to extend the existing ground floor, also adding a basement under? Without a floor plan there is a limited amount anyone can suggest. I think that having a measured survey of the existing building and plot would be a good start. Have it include a section through the house / plot, neighbouring properties, front and rear elevations. Budget £1,200. Make sure you own the rights to use the plans.
