Hello. Advice regarding basement build
I’m planning a single-storey rear extension with a basement underneath, and I’d love to hear from anyone with experience of something similar — particularly around costs (£/m²) and who to get involved.
The rear of the property sits on a significant slope, so a retaining wall will be needed regardless. I’m in North Somerset, about 20 minutes from Bristol. The basement doesn’t need to be the same size as the basement. I’ve put a picture of the rear of the property below. IMG_4833.jpeg.73678906178fff56bbaa4d8c16645f51.jpeg
The main reason for the basement is acoustic separation — I want to use the space as a music room (drums, electric guitar) along with a cinema room or gym. Being below ground should help keep the noise away from the rest of the house naturally.
I’m keeping it single-storey partly because light is already a consideration on this plot, and I don’t want to affect the neighbours’ light either. The plan is to use rooflights to bring as much natural light into the extension as possible.
So — who exactly needs to be involved (specific type of architect, structural engineer, specialist basement contractor?), and what are realistic cost expectations for this kind of build in the South West?
I know basements aren’t everyone’s first suggestion, but I’m genuinely keen on the idea and would love to hear from people who’ve actually done something similar rather than just being talked out of it!
Ok, lol. Which way around does that need to go and I’ll edit it for you ;)  :D
Go for it, I’m a big fan of basements, and I think this would be a good candidate for an EPS based ICF. Many birds, one stone.
Any plans you can share yet, for comment?
Need to know a lot more.
Existing house construction.
Which way is the slope
 the gradient.
Are other structures or boundaries nearby.
Ease of access.
What kind of ground.
Size of course.
Basements are inherently expensive.
Gut feeling with no info: 3 x normal cost.
but perhaps yours is more an extension at lower level. Double?
So start with that. 8k/m2 or more.
I wouldn't start with any consultant as long as you can sketch to scale.
You sketch your ideas first and put them on here.
What do you mean by a "single storey extension with basement underneath"
Looking at your picture, a single storey extension level with the existing ground floor would already be part underground (semi basement) Are you suggesting a basement below that?  That would be really deep.  Or some split level design (extension not necessarilly level with existing floors)
A separate building well away from the house is what most people do for a drum kit.
Can you clarify if you intend to extend the existing ground floor, also adding a basement under?  Without a floor plan there is a limited amount anyone can suggest.  I think that having a measured survey of the existing building and plot would be a good start.  Have it include a section through the house / plot, neighbouring properties, front and rear elevations.  Budget £1,200.  Make sure you own the rights to use the plans.
Yeah, we’re just starting the basement part of our build. This is ‘not easy’ (basements are quite unusual in the UK remember) unless you’re very comfortable with risk and/or have deep pockets. Most UK suppliers won’t want to guarantee water-tightness, the odd European supplier might, but my experience is that they are v difficult to deal with.
As others have said, without some kind of sketch - to give an idea of size & shape & ground levels, we’re fairly much in the dark, so can’t say much.
On 04/06/2026 at 18:35, Alan Ambrose said:
This is ‘not easy’
Indeed. There is a huge learning curve to go though, but if you persevere it's worth it at the end of the day.
This is also true! Basements carry higher risk.
Build a garden room for your music and put the £75k you saved yourself into your retirement fund.
That's a better use of your money, looks like you have a huge garden, so may make more sense.
We had a basement in one of hire properties, a pain in the arse is how describe basements. But depends where the water table is etc.
On one occasion the sump pump failed, and it filled with water - fun - not.
But be careful with sizing so you don’t overheat the place.
Yes to all the above
