Jess Shannon Posted 20 hours ago Posted 20 hours ago We're building an extension on to an old stone cottage. The new foundation will be insulated raft with UFH. The extension will have a pitched roof section and a flat roof section with steel frame connecting to the old building. A builder friend is helping us design it. He's suggested 220mm studs so we can have a thick layer of insulation. He said twin studs could end up costing more due to added labour over any material cost saving. But will the cold bridging mean it's not worth it in the long run? Should we apply an external layer of continuous insulation too? I've mocked up his suggestions on ubakus to look at performance (edit it here). And this is a build up that I've put together based on other research, with an external PIR sheathing (edit this one here). Would this kind of PIR board be able to wrap up and over the roof too?
Mr Punter Posted 19 hours ago Posted 19 hours ago I think it may work well with either internal pir or insulated plasterboard, so move the 50mm celotex inside. It follows the rule of thumb of having the most insulating and vapour impermeable materials inboard.
SimonD Posted 19 hours ago Posted 19 hours ago 36 minutes ago, Mr Punter said: It follows the rule of thumb Yes, I wouldn't have the pir on the outside either. Principles are definitely to have insulation to reduce thermal bridging. In Sweden, for example, it's very common to have a continuous layer each side of the stud walls. You can then use smaller dimensioned stud. I wonder what the cost implications are of this compared to the cost of the 220 studs plus continuous layer? 1
Redbeard Posted 18 hours ago Posted 18 hours ago 16 minutes ago, SimonD said: Yes, I wouldn't have the pir on the outside either. ... and I was just about to write that too. PIR externally amounts, in my view, to a VCL on the wrong side of the 'sandwich' - and I wince every time I see a TV show depicting it. How about rigid wood-fibre with a scratch-coat of lime render before the battens and (?hit-and-miss?) larch?
SimonD Posted 18 hours ago Posted 18 hours ago 29 minutes ago, Redbeard said: How about rigid wood-fibre That's probably what I would go for too.
sgt_woulds Posted 17 hours ago Posted 17 hours ago (edited) Using woodfibre & I-Joists with a direct rendered external sheathing board will give you a quick build, that will give you more decrement delay (probably more important than ultimate u-vale in our ever heating world. You can also do away with membranes entirely and have no worries about moisture. The example build up uses (taped and sealed), 15mm OSB3 as a combined racking and V-VCL layer internally. External, directly rendered woodfibre sheathing board. I've shown 240mm I-joists as these are more common, but 220mm are available I've also shown a service void behind the plasterboard as this makes wiring easier. Edited 17 hours ago by sgt_woulds
Crofter Posted 17 hours ago Posted 17 hours ago I designed my place with 50mm PIR on the inside, which allowed me to use 145mm studs whilst eliminating thermal bridging. You want your wall build-up to be progressively more moisture permeable as you move outwards. So mine goes VCL, PIR, mineral wool, breather membrane.
sgt_woulds Posted 16 hours ago Posted 16 hours ago If you used PIR, that is already acting as a VCL. If you are careful with taping then an additional internal VCL would not be needed. I have a combination of PIR and Woodfibre in part of my own roof (due to structural loading, woodfbre alone was too heavy) with the PIR Internal and taped as the VCL.
ADLIan Posted 14 hours ago Posted 14 hours ago 2 hours ago, sgt_woulds said: Using woodfibre & I-Joists with a direct rendered external sheathing board will give you a quick build, that will give you more decrement delay (probably more important than ultimate u-vale in our ever heating world. You can also do away with membranes entirely and have no worries about moisture. Do not render direct onto (any) insulation onto timber (or steel) frame construction!! It's not accepted good practice and lots of failures reported. About this time last year I was dealing with an architect looking at remedial works on this form of construction - sole plates and base of studs all rotted on 2 houses built approx 15 years ago. Does PUR really form a VCL if the board joints are not sealed/taped in any way? Moisture vapour is a gas so will readily move through the joints. Discuss....... 2
Mr Punter Posted 14 hours ago Posted 14 hours ago 9 minutes ago, ADLIan said: Do not render direct onto (any) insulation onto timber (or steel) frame construction!! It's not accepted good practice and lots of failures reported. About this time last year I was dealing with an architect looking at remedial works on this form of construction - sole plates and base of studs all rotted on 2 houses built approx 15 years ago. Agreed. Better is a render carrier board battened off the structure to leave minimum 25mm drained and vented cavity. 2
JohnMo Posted 14 hours ago Posted 14 hours ago If doing a timber frame, look for cold bridging at the wooden sole plate and foundation also. Then design out.
Iceverge Posted 9 hours ago Posted 9 hours ago (edited) I'll attract scorn here but I like a continuous layer of external insulation. It's keeps the studs and OSB sheathing warm and away from the elements. Provided you have adequate management of air movement through the structure (airtightness) and very good control over internal humidity levels the wall will quite happily dry to the inside provided you don't add any more low permability layers like internal vapour barriors. Unfortunately airtightness is rarely done well and internal humidity control relies on the long term occupants diligence so there have been numerous building failures, hence the caution urged above. In your case the U value of the extension is lightly to be neither here nor there in the grand scheme of things. Aim for Bregs with something robust, easily buildable and cheap. What really will make it feel more comfortable is good air sealing. Make sure this is done well. I would avoid PIR internally as half of it will end up in the skip as offcuts and you'll be searching for studs to hit while screwing through it. Also it's virtually completely vapour closed so any accidental moisture in the wall will struggle to dry either in or out. Far easier to bang up a few 2*2s with a nail gun as a service cavity and mineral wool is fast and cheap to install. I really like blown cellulose for TF but it may not be worth getting the man for a small area of an extension. Importantly everything above is off the shelf at every builders merchant in the country. Robust, buildable. Cheap. Edited 9 hours ago by Iceverge
Roger440 Posted 9 hours ago Posted 9 hours ago 7 hours ago, sgt_woulds said: Using woodfibre & I-Joists with a direct rendered external sheathing board will give you a quick build, that will give you more decrement delay (probably more important than ultimate u-vale in our ever heating world. You can also do away with membranes entirely and have no worries about moisture. The example build up uses (taped and sealed), 15mm OSB3 as a combined racking and V-VCL layer internally. External, directly rendered woodfibre sheathing board. I've shown 240mm I-joists as these are more common, but 220mm are available I've also shown a service void behind the plasterboard as this makes wiring easier. As others have said, seems rather high risk and totally dependant on the render to keep it all dry. Not for me that one.
Roger440 Posted 9 hours ago Posted 9 hours ago 22 minutes ago, Iceverge said: I'll attract scorn here but I like a continuous layer of external insulation. It's keeps the studs and OSB sheathing warm and away from the elements. Provided you have adequate management of air movement through the structure (airtightness) and very good control over internal humidity levels the wall will quite happily dry to the inside provided you don't add any more low permability layers like internal vapour barriors. Unfortunately airtightness is rarely done well and internal humidity control relies on the long term occupants diligence so there have been numerous building failures, hence the caution urged above. In your case the U value of the extension is lightly to be neither here nor there in the grand scheme of things. Aim for Bregs with something robust, easily buildable and cheap. What really will make it feel more comfortable is good air sealing. Make sure this is done well. I would avoid PIR internally as half of it will end up in the skip as offcuts and you'll be searching for studs to hit while screwing through it. Also it's virtually completely vapour closed so any accidental moisture in the wall will struggle to dry either in or out. Far easier to bang up a few 2*2s with a nail gun as a service cavity and mineral wool is fast and cheap to install. I really like blown cellulose for TF but it may not be worth getting the man for a small area of an extension. Importantly everything above is off the shelf at every builders merchant in the country. Robust, buildable. Cheap. Im assuming that you would put some sort of cladding on battening on the outside of that build up?
Crofter Posted 8 hours ago Posted 8 hours ago 40 minutes ago, Iceverge said: I'll attract scorn here but I like a continuous layer of external insulation. It's keeps the studs and OSB sheathing warm and away from the elements. Provided you have adequate management of air movement through the structure (airtightness) and very good control over internal humidity levels the wall will quite happily dry to the inside provided you don't add any more low permability layers like internal vapour barriors. Unfortunately airtightness is rarely done well and internal humidity control relies on the long term occupants diligence so there have been numerous building failures, hence the caution urged above. In your case the U value of the extension is lightly to be neither here nor there in the grand scheme of things. Aim for Bregs with something robust, easily buildable and cheap. What really will make it feel more comfortable is good air sealing. Make sure this is done well. I would avoid PIR internally as half of it will end up in the skip as offcuts and you'll be searching for studs to hit while screwing through it. Also it's virtually completely vapour closed so any accidental moisture in the wall will struggle to dry either in or out. Far easier to bang up a few 2*2s with a nail gun as a service cavity and mineral wool is fast and cheap to install. I really like blown cellulose for TF but it may not be worth getting the man for a small area of an extension. Importantly everything above is off the shelf at every builders merchant in the country. Robust, buildable. Cheap. It's not that hard to hit the studs when going through 50mm of PIR. I had to go through 100mm to hit my rafters and that was a bit of a pain, but it was manageable. Wool is cheap and breathable but you'll end up with a thick wall build-up, and a lot of the money you've saved on insulation will go in to extra timber.
Iceverge Posted 7 hours ago Posted 7 hours ago 1 hour ago, Roger440 said: Im assuming that you would put some sort of cladding on battening on the outside of that build up? Yes. Didn't include it because I'm lazy.
