I know we have a canal, but we are thinking of putting in a wildlife pond... obviously no fish with the heron, kingfishers etc but more to attract wildlife don't want any pumps or anything....so, show me your ponds please?
@ToughButterCup I saw a couple of pics of your pond on a previous thread. Do you have any more pics of it, especially as you were doing it.
still probably too big for what you would need, not sure if it gives the right feel though.
about as natural as it gets.
my friend has a wildlife pond he dug and used a liner, I will see if he has any pics.
he’s the type of bloke who would have researched it for a year first.
PXL_20230630_145648900.thumb.jpg.6264da48d012a6b6bf0ee7012dbbcfb6.jpg Not much need for commentary : the pond is fed entirely from the roof run off. (SUDS)
Cost? Absolutely everything inclusive : £5 or 6 hundred. Tops
The sand (bulk bags)  in the photo below is 'buried' under the garden as a filter for the roof run off. Its been working hard recently 😑
This is where that pipe in the photo above runs into the pond.
Overflow from here  into the pond in the field below our site ( The one with the GCNs in )
  • Like 3
I didnt build this. Fed off barn roof. Clay lined. 4m deep.
Sadly, was entirely surrounded by rushes. Slowly eliminating and replacing with other stuff. But its big, so years of workIMG_20250508_080217_resized_20250603_100450816.thumb.jpg.e1b9032bfeb342ad98e9e1ed17ff2414.jpg
IMG_20240519_195518_resized_20241005_075035031.thumb.jpg.1937a5a36e471ffefebba25465892243.jpg
IMG_20240519_195535_resized_20241005_075030525.thumb.jpg.2f538b3713cd5e9a4b09bfce0a873371.jpg
IMG_20240519_195432_resized_20241005_075034559.thumb.jpg.68dea3178a6ca2f32cf11e41cd993652.jpg
What are you "filtering out"?
Nothing. Cos I'mAdickHead. I just followed the SUDS guidelines: they said
' ... use a sand bed to filter the run off ...'
So I did.
Instead of thinking about it - what could possibly come off the roof that would need to be filtered?
Nowt.
Thinking about it a bit, the pH of the sand might affect the water a bit but apparently not to it's detriment. For the last few years we regularly see four or five GCNs feeding on rising Dragonflies emerging from their underwater stage: stuck in the surface tension for just long enough to provide a meal. The sand also provides a nice wet area for the Dogwood roots.
But we have no need for sand at all.
How did you get your water lilys to grow that fast!
That's the only one of three that made decent progress, and that's still probably the case 3 years on tbh.  I did make an early mistake of using garden soil for some planting, so maybe a nutrient overdose.
I hope you’ve got the drawbridge working? 🤔😆
I built a pond once as SUDS, fir an office block, with all the roof and driveway water pipes ending up there for exceptional rain. Ie after natural drainage, rainwater harvester and French drains any surplus went in there.
We had a 'nature' consultant who advised that we did no planting or species thinking at all, and let nature do it. Although he did say plant sone miniature willows to help drink the water.
Nature took about 2 years, during which time the LA nature staff complained about the "typical builder, leaving a muddy hole behind" but were won over.
Another time I would do the same if it was distant from the building but omit the willows as they took over and needed maintenance.
If near to  the house I might compromise and have some pretty planting, and a shallows, and a gravelly pretty feature.
Nature did indeed move in. The advisor had said we would get newts or frogs or fish.....only one would prevail. It was common newts. The plants that moved in were attractive enough. Maintenance nil apart from the planted trees and sone other 'weed' trees.
No sand liner!  That seems pointless. The people who wrote these LA guidelines back then seemed to be tree huggers with little real knowledge.
As to lining it. For SUDS you want to let it empty, and nature will deal with the seasonal  changes, so no lining.
For a garden feature everything is different.
I've got an ornamental pond (brick and liner). 3 lilies on baskets on the bottom in year one. Gradually one bullied the other two. Now one lives in the bottom sludge, and the removal of leaves keeps the nutrient down and the mass of leaves keeps the summer heat out.
3 fish became about 60 and they appear to live in harmony.
Not having much success with lillies :(
Sadly not. Its on the to do list. Theres power there, but the winch motor is seized, and the cable was down to just a couple of strands. Need to buy a new winch and swap it out. But need to get the scaff tower over there. So a summer job when ground is hard(ish) Ie last year :)
Not having much success with lilies
not what I meant to say. The lily that wiped out the others is perfectly attractive and successful. it takes a bit of maintenance though, to remove the dying leaves and flower heads.
In a wild pond Id just let it take over and the fish would have to learn to find some oxygenated water between the leaves.
As with many plants, the white flowered version prevails.
I used to scoop out the sludge annually but have found it to have come to a steady state, and I think the fish get sustenance from it through the winter.
The odd thing with the fish (Sarasa Comets) is that I've seen hundreds of pretty little ones over the years but only ever 3 floaters to dispose of... the dead ones must sink and dissolve into the sludge.
each spring I remove the forest of roots that hang from the edge shelving plants, because the fish scoosh their eggs in there, and I prefer a dozen fish reaching maturity to hundreds. I assume that loose eggs and tiny hatchlings are eaten
