Roger440 Posted Saturday at 08:12 Posted Saturday at 08:12 1 hour ago, Dillsue said: I put self installed on my G99 and my son in law put self installed on his G98 both accepted by our DNO Some sort of notification should exist so DNOs can manage the network. That could be a part prefilled G98 included with plug in solar so the buyer only has to fill in their address and post it. Not onerous stall to do that Thats good to know as ill be self installing too. I did ask before, but no one seemed clear on that. Ie someone with no electrical qualifications. Well i did qualify under the 16th edition, but i dont think that means alot now. I still say this will be exempted from G98. There will likely be millions of these things. Which would mean millins of G98 forms. Just not going to happen. Not in the real world.
JohnMo Posted Saturday at 08:18 Posted Saturday at 08:18 4 minutes ago, Roger440 said: ill be self installing too We've been saying that for ages. March was great for solar! 1
Roger440 Posted Saturday at 08:21 Posted Saturday at 08:21 2 minutes ago, JohnMo said: We've been saying that for ages. March was great for solar! If we can move to a 30 hour day, that would help progress!
TedM Posted Saturday at 08:32 Author Posted Saturday at 08:32 (edited) 1 hour ago, Dillsue said: Some sort of notification should exist so DNOs can manage the network. That could be a part prefilled G98 included with plug in solar so the buyer only has to fill in their address and post it. Not onerous stall to do that Even better - barcode on the hardware that you scan with your phone, add your name and address and press send. It creates the certificate for you and sends the notification to the correct DNO and puts the info in a national database 👍🏻 (I create mobile apps as my business and that would literally take 15 minutes to create!) Edited Saturday at 08:35 by TedM
Roger440 Posted Saturday at 08:39 Posted Saturday at 08:39 6 minutes ago, TedM said: Even better - barcode on the hardware that you scan with your phone, add your name and address and press send. It creates the certificate for you and sends the notification to the correct DNO and puts the info in a national database 👍🏻 (I create mobile apps as my business and that would literally take 15 minutes to create!) And still most people wont do it. Come back to the real world please.
SteamyTea Posted Saturday at 09:00 Posted Saturday at 09:00 27 minutes ago, TedM said: I create mobile apps as my business and that would literally take 15 minutes to create Do it. Then let the government (expletive deleted) up the database.
Dillsue Posted Saturday at 14:57 Posted Saturday at 14:57 6 hours ago, Roger440 said: I still say this will be exempted from G98. There will likely be millions of these things. Which would mean millins of G98 forms. Just not going to happen. Not in the real world. Firstly, it can't be exempted as G98 covers a load of safety requirements. If they do away with G98 they'll have to write a new spec for plug in solar and that isn't gonna get done in a few months. G98 already covers sub 800watt generators and gives a few exemptions for those. Recognising plug in systems may be an additional exemption but still part of G98 Secondly, they can't dispense with notification because.....if all your neighbours installed 3.68kw solar but didn't tell the DNO then first sunny day the local voltage would rocket and push the voltage past the max limit and your inverter(when installed!) could trip. You wouldn't be happy. Imagine 50% of a block of flats installing plug in systems that the DNO didn't know about it so could bolster the local grid and/or drop the supply voltage, it would be bedlam.
-rick- Posted Saturday at 15:10 Posted Saturday at 15:10 That's not quite right is it? I thought they couldn't refuse G98. So within current regs every household can install 16A of solar with just a notification which is not refusable. The grid has to cope and if it can't the co's have to make changes. G99 can be refused but the basis G98 is just notification. Also, inverters will shut off if the voltage gets too high (before the voltage gets dangerously high) so installing too much capacity will self regulate to a degree with each user generating less than they would otherwise expect. I believe the 800W limit comes from keeping it to a size where things are easily absorbed by the grid. Whatever update to the rules they make I would expect them to be such that you are not allowed to install more than 800W capacity using this scheme. Any more than that and you need normal G98 and electrician install. Less than that and maybe technically G98/some form of registration required but if it doesn't happen it's not going to cause problems.
JohnMo Posted Saturday at 15:43 Posted Saturday at 15:43 32 minutes ago, -rick- said: inverters will shut off if the voltage gets too high 253V from a quick search
JohnMo Posted Saturday at 15:49 Posted Saturday at 15:49 Easy way - plug and play inverter is limited to 800W. Anything higher goes to CU and controlled by G98. You will still get people that install multiple systems, but difficult to control those. Unless you get the PV police, that's not happening, you can't get normal ones.
Dillsue Posted Saturday at 15:49 Posted Saturday at 15:49 32 minutes ago, -rick- said: I thought they couldn't refuse G98. So within current regs every household can install 16A of solar with just a notification which is not refusable. The grid has to cope and if it can't the co's have to make changes. Yep that's as it is....as previous page!! 35 minutes ago, -rick- said: Also, inverters will shut off if the voltage gets too high (before the voltage gets dangerously high) so installing too much capacity will self regulate to a degree with each user generating less than they would otherwise expect. It will "self regulate" but those at the extremities of the flats will never get started on sunny days as the voltage will be too high. Without a stream of notifications every block of flats could have problems for years before the DNO recognises the problem and schedules in any alterations needed
SteamyTea Posted Saturday at 15:50 Posted Saturday at 15:50 Just now, JohnMo said: Unless you get the PV police, that's not happening, you can't get normal ones. I can, by doing a reckless 27 MPH.
-rick- Posted Saturday at 15:52 Posted Saturday at 15:52 2 minutes ago, JohnMo said: You will still get people that install multiple systems, but difficult to control those. Unless you get the PV police, that's not happening, you can't get normal ones. If multiple systems became a problem it would be possible to introduce technical measures for one inverter to detect others and shutdown if found. I doubt it would be necessary thought (and of course would only be present in new compliant systems anyway)
Dillsue Posted Saturday at 15:52 Posted Saturday at 15:52 1 minute ago, JohnMo said: Easy way - plug and play inverter is limited to 800W. Anything higher goes to CU and controlled by G98. If your ditching G98 for sub 800watt systems how are all the safety requirements going to be specified??
Dillsue Posted Saturday at 15:54 Posted Saturday at 15:54 10 minutes ago, JohnMo said: 253V from a quick search For some maybe. Out of the box our solaredge ones are higher!!!!
-rick- Posted Saturday at 15:55 Posted Saturday at 15:55 1 minute ago, Dillsue said: If your ditching G98 for sub 800watt systems how are all the safety requirements going to be specified?? Just because you ditch notification doesn't mean the products don't have to comply with standards. Go after retaillers selling non-compliant systems (it will only be the Amazon/ebay/aliexpress type stuff anyway and those will be a problem whatever you do with notification)
JohnMo Posted Saturday at 16:48 Posted Saturday at 16:48 55 minutes ago, Dillsue said: ditching G98 Wasn't really saying ditch, the inverter would be still compliant, you are just allowed to plug it into the ring main, and not bother with registration.
Beelbeebub Posted Sunday at 08:40 Posted Sunday at 08:40 16 hours ago, Dillsue said: If your ditching G98 for sub 800watt systems how are all the safety requirements going to be specified?? Via CE/UKCA marking? At least for the device and any requirements for it to operate safely. Obviously it can't control shoddy house wiring (eg not using an outdoor rated socket or just running a really long extension cable) but those risks exist with any electrical equipment.
Beelbeebub Posted Sunday at 08:42 Posted Sunday at 08:42 15 hours ago, JohnMo said: Wasn't really saying ditch, the inverter would be still compliant, you are just allowed to plug it into the ring main, and not bother with registration. There would be an interesting case for people with old style meters, they would just run backwards so any export would be effectively net metered, ie your effective payment per kwh export would be whatever you import unit cost would be! 😁
ProDave Posted Sunday at 09:49 Posted Sunday at 09:49 On 24/03/2026 at 20:13, saveasteading said: That's more for an 850W system than it cost me for my original 3.68kW system. No wonder there is interest in selling this plug and play kit, it allows suppliers to charge a lot for a small system just for the users that think they are getting something special.
JohnMo Posted Sunday at 10:55 Posted Sunday at 10:55 1 hour ago, ProDave said: That's more for an 850W system than it cost me for my original 3.68kW system. No wonder there is interest in selling this plug and play kit, it allows suppliers to charge a lot for a small system just for the users that think they are getting something special. I was thinking similar.
Dillsue Posted Sunday at 13:47 Posted Sunday at 13:47 4 hours ago, Beelbeebub said: Via CE/UKCA marking? At least for the device and any requirements for it to operate safely. G98 has more onerous/specific requirents than those in the harmonised standards associated with the various EU/UK directives. As an example you can get a CE/UKAS marked inverter that meets all the requirements to legitimately be sold in the EU/UK but you can't connect that to the grid without complying with the countries grid connection standards, G98/G99 for the UK
Beelbeebub Posted Sunday at 13:52 Posted Sunday at 13:52 Just now, Dillsue said: G98 has more onerous/specific requirents than those in the harmonised standards associated with the various EU/UK directives. As an example you can get a CE/UKAS marked inverter that meets all the requirements to legitimately be sold in the EU/UK but you can't connect that to the grid without complying with the countries grid connection standards, G98/G99 for the UK As long as thr unit cannot output more than 800w (about 3a) will it be able to cause much damage to the grid. If it tried to distort the waveform by being put of phase it wouldn't be able to "overwhelm" the natural grid waveform. I wonder if that is why the plug in limit is so low. The biggest issues will be islanding but that would be covered by the prongs not being live whan unplugged, which would surely be covered by thr CE marking. That said, it would be sensible if the approval for being put on sale in the UK included some basic specs that make it suitible for grid connection. Eg can only be put on sale if the inverter is listed in the g98 list. 1
Dillsue Posted Sunday at 14:26 Posted Sunday at 14:26 13 minutes ago, Beelbeebub said: That said, it would be sensible if the approval for being put on sale in the UK included some basic specs that make it suitible for grid connection. Eg can only be put on sale if the inverter is listed in the g98 list. So that would make it a G98 compliant unit
SteamyTea Posted Sunday at 15:04 Posted Sunday at 15:04 5 hours ago, ProDave said: That's more for an 850W system than it cost me for my original 3.68kW system 4 hours ago, JohnMo said: was thinking similar Mentioned this a while back about these system won't be that effective. 6 hours ago, Beelbeebub said: old style meters, they would just run backwards Very few left now, and it is illegal, was a problem 15 years ago, but most meters are changed every 20 years.
