My new home that I bought from a developer which is supposed to be air tight leaks air from some of the sockets on outside wall.  Is there any tips on how I could find the area of leakage?
The sockets right by my bed and it’s like a fan on me at night.
thanks
Is it brand spankers? Did the developer give you a figure of how airtight it was?
If so, get a professional air test done to find the real figure and demand the builder rectifies the situation.
Yeah it’s less than a year old.
to be honest the developer is useless I can’t even get them here to fix small snags. Don’t have much hope for tearing down plasterboard looking for air leaks. I’ll have to rectify it myself somehow
What's the wall make-up out of interest?  Dot and dab? Timber frame? Service void? Which ever, I suspect the fix will the same 'sticking plaster': remove socket/back box, fill all gaps with something (foam, airtightness tape, mastic, all of the above), refit.
I think you can safely assume no physical air test was ever carried out.
The wall build up questions above will determine the next sensible step.
So what did they actually promise? Any figures?
What ventilation system did they install?
MVHR?
dMEV?
Intermittent running fans?
It’s a timber frame house.
12.5mm plasterboard
service Batten
foil Vapor barrier
PIR
rockwool
140mm stud
The way it’s leaking i wouldn’t be surprised if they skipped the test
That's your money though.
Demand first.
A little local pressure might help too. Such as asking thd selling agent fof "advice" " they won't have any but might pressure (oops can't think of a better word) the developer. Ask them for the specifications.
Then social media... without being too disparaging at first...
I've got a new house by Bodgit Ltd  on "Used to be an orchard" Mews. Does anyone else have this problem of know what I can do?
If that's the case the normal would be an airtightness of 3-5m³/m², so not really airtight in the grand scheme of things. With MEV you should have trickle vents as well - there are improvements you can make there (new thread)
To get a timber frame airtight you need to use a membrane behind the plasterboard. I would find a double socket and unscrew from wall, clip out the pattress box and have a feel and look about.  Then report back. Switch of the electric off - if you are messing about near electric.
I
A practical option might be a smoke source e.g. incense stick or smoke pen to figure out where the worst leaks are. If they’re small leaks, there’s a system called Aerobarrier that might help. Agree though that a ‘professional’ leak test measurement would be something to go back to the developer with - particularly if the result is outside the building control limits.
1 hour ago, Alwayslearning22 said:
It has a continuous foil membrane. I’m assuming it’s not taped well or it’s punctured somewhere
Inside or outside the frame?
Was there anything in your purchase 'stuff' which states an air-tightness test result. If not, ask the developer what is was. It may cost around £400 to get a basic A/T test which will give you a 'number' (in m3/m2/hr or air-changes per hour), or a fair bit more to get A/T and thermography at the same time. De-pressurise the house with the fan on a day when you can get a +10 degree C diff between inside and outside temp, and you get an IR 'pic' of the leaks. If the discrepancy between the developer's stated no. and yours is significant, ask awkward Qs.
Edited by Redbeard
The EPC should give the air pressure test result - either ‘as measured’ in this house or based on site average value.
If you've got breeze coming from your sockets, it's very likely they punctured the membrane while installing the electrics - it happens a lot because the contractors simply don't understand airtightness.
