flanagaj Posted March 12 Posted March 12 I have just called around to get a quote for 24m3 of C25 and have quotes from £120/m3 to £191/m3 Given that concrete is something that you don't want to get wrong, is there anything I should be aware of here as that is a massive difference.
Mr Punter Posted March 12 Posted March 12 Make sure your access is OK for the truck. Could be 3 x 8m3 loads. 32 tonne each. Hopefully the lorry can back up near the trench, maybe either end. Ideally you want trench inspection 1st thing, then concrete early. It can be annoying hanging around then having to work late because you are not a priority customer.
flanagaj Posted March 12 Author Posted March 12 2 minutes ago, Mr Punter said: Make sure your access is OK for the truck. Could be 3 x 8m3 loads. 32 tonne each. Hopefully the lorry can back up near the trench, maybe either end. Ideally you want trench inspection 1st thing, then concrete early. It can be annoying hanging around then having to work late because you are not a priority customer. I really need to hire a pump as otherwise, there is going to be a lot of manual raking
Mr Punter Posted March 12 Posted March 12 6 minutes ago, flanagaj said: I really need to hire a pump as otherwise, there is going to be a lot of manual raking If there is space, a lorry mounted boom pump is a real time saver. Hire a rotating laser level. You will still need a mate to help. The pumps make a fair mess when they clean out. You can end up with a fair amount of concrete and washout, so plan somewhere for it to go. 1
cwr Posted March 13 Posted March 13 13 hours ago, flanagaj said: I have just called around to get a quote for 24m3 of C25 and have quotes from £120/m3 to £191/m3 Given that concrete is something that you don't want to get wrong, is there anything I should be aware of here as that is a massive difference. I recently got a load of C30, all the local suppliers were very simalar prices, and at the lower end of the scale you've been quoted. You could ask the more expensive ones why, are they further away or delivering in smaller loads or something. Get more quote to see if there's some simalar with costs?
Russell griffiths Posted March 13 Posted March 13 Find your nearest plant and go and open an account, work out the total you will use in the next 4 months and you will get a better price. £120 around here. For a full truck load. 1
saveasteading Posted March 13 Posted March 13 @flanagaj if this is your first time and a diy pour, we can help re level control, and waste avoidance.
Conor Posted March 13 Posted March 13 14 hours ago, flanagaj said: I really need to hire a pump as otherwise, there is going to be a lot of manual raking Make sure you get a pump able mix then. Will be a bit more than you've been quoted
LSB Posted March 13 Posted March 13 ours was 120 with an extra 600 for pump regardless of how much we had. we had 3 lorry loads. they co-ordinated themselves, sent one and then the other one despatched whilst the first pouring and same for the third one as not enough room for multiple lorries We've found, not sure why, that we've needed more for every pour than we originally thought. First lot was mix on site, next 2 were ready mixed. There is a company near here who are slightly cheaper, but they are supplying Sizewell C build and a huge wind farm and I wasn't convinced that we would be treated seriously. the guys were brilliant and worked really hard in 30 degree heat, anyone remember that last summer 🙂 But, not perfectly level due to drying very quickly, but as we need insulation and screed for UFH it's fine. 1
Markuz Posted Monday at 12:40 Posted Monday at 12:40 Things that I asked: - what happens in half load? Is there a fee? - waste taken away or left on site? - extra time fees? - where is concrete coming from? Usually 30mins ok - if your pumping is there a primer included , waste bag to wash out? - on the day if you run short, how long to get extra - how are they dispatching? Every 30 mins? we had 36m3 c20 , s3 , 20mm aggregate, and paid £120 plus vat per m3 , trucks didn’t spend more than 25mins on site. Line pump 400 plus vat We are Northants. Get a rotary laser level if you want nice and level finish , get ready to mist it or cover it in this crazy heat! Mrs floated it and she never done it so not difficult. We poured everything in 4 hours. Get some rakes as well but s3 should nicely go.
saveasteading Posted Monday at 14:34 Posted Monday at 14:34 Well done. Others readig this.,. Dong assume it's this easy.
