We have a weak mobile phone signal inside the house, likely to do with the concrete walls and 3G glazing.
Im thinking of fitting a signal booster, something like this:
Anyone used anything like this or something similar that they would recommend?
Not enough information.  Need a link, not a picture.
But probably useless at that price.
Do you have decent broadband?  If so you only need a phone and service provider that supports wifi calling when at home.
If looking for 4G or 5G broadband, you need a router that has an external aerial that plugs into the router.  THAT is not that aerial.
5G vs 4G. As your know @SteamyTea, in Kernow 5G is a rare beast, often only to be found wondering around Truro and maybe some other larger towns in the county. Likelihood of us getting 5G where we are I suspect is very low. So, paying for something we're unlikely to get is pointless IMHO.
@ProDave, Yes, we do wifi calling in the house. I am planning for that next broadband and/or power outage that leaves us dependent on a mobile signal. This is the link to that above picture - https://ebay.us/m/TKwM6Y
There is a 5G mast 200 metres from my house.
I must go down to Goonhilly and Poldhu, the spiritual home of radio, and see if there is still no signal.
17 minutes ago, BotusBuild said:
Seems you have to spend several hundred pounds
Try putting a cheap phone up as high as possible and see what happens.
Or you could play about with an old satellite dish and see if you can get a stronger signal.
When I was at the college, I managed to get onto the university network that way, and I was about a third of a mile away.
Edited by SteamyTea
Before looking for boosters, try out the other networks. Theres only 3 physical networks now so not a huge task.
You just need WiFi. We've NO signal in our basement, very intermittent on the ground floor. No issues with WiFi calling enabled.
We have 🙂 They're all sh1te 😉
I do. SWMBO's phone doesn't!! I know, I was gobsmacked.
But this is all about when the WiFi has failed for some reason and we are reliant on just the mobile signal.
