Waterworks Posted February 9 Posted February 9 Would it be possible to design a Shepards hut on a passive house principle ? This would be a pretty big maybe 3 x 6 metres internally , and clad in galvanised corrugated sheets. The design would take into account up to 300mm of PIR insulation, maybe vacuum panels in the front door and there would certainly a small wood stove. What would the design need to consider ?
JohnMo Posted February 9 Posted February 9 5 minutes ago, Waterworks said: 300mm of PIR insulation Why that much? 7 minutes ago, Waterworks said: vacuum panels in the front door Over thinking things. You can use passivhaus principles for any build. Main things are thermal bridges, continuous insulation, form factor, airtightness. So you need to consider ventilation.
ProDave Posted February 9 Posted February 9 With that level of insulation and such a small space, don't fit a WBS, you will melt the first time you light it.
saveasteading Posted February 9 Posted February 9 2 hours ago, Waterworks said: Shepards hut on a passive house principle ? Of course. But any time you open the door most heat will shoot out so I can't see the point. And the surface area compared to volume also provides a poor figure. Spending a fortune on sustainability for a building that is far from sustainable through the material/carbon content doesn't make sense. A shepherd would not do that.
Crofter Posted February 9 Posted February 9 PassivHaus is all about energy/m², rather than total energy. Which I think is wrong and drives up house sizes. We don't measure cars in mpg per ton of vehicle. Also, it's very difficult to meet PH standard in a small build because the volume: surface area ratio favours larger buildings. Another thing counting against a PH Shepherd's Hut is the exposed floor. You've got a very large surface area and a small volume inside it. I came up against all of this on my own build, which is a 5*10m house on legs. 1
Iceverge Posted February 9 Posted February 9 20 minutes ago, Crofter said: PassivHaus is all about energy/m², rather than total energy. Which I think is wrong and drives up house sizes. We don't measure cars in mpg per ton of vehicle. Also, it's very difficult to meet PH standard in a small build because the volume: surface area ratio favours larger buildings. Another thing counting against a PH Shepherd's Hut is the exposed floor. You've got a very large surface area and a small volume inside it. I came up against all of this on my own build, which is a 5*10m house on legs. Exactly this. https://passivehouseplus.ie/magazine/insight/the-small-passive-house-problem-a-solution 1
Waterworks Posted Thursday at 12:45 Author Posted Thursday at 12:45 OK, passive house is not practical this small , so what would be the level of insulation required for the minimal heating fuel requirement in tne winter in the UK ? Im asking based on the houseboat I currently live on which has 40 mm PIR insulation and is costing a fortune to heat , I want my Shepherds hut to use the minimum fuel possible and my design is built around insulation, however much is required.
Crofter Posted Thursday at 14:28 Posted Thursday at 14:28 I would start by looking at all the background heat you expect to be generating in there- two humans, a fridge, some cooking. Then do a basic heat loss calculation based on notional insulation values and the surface area of the hut. This will be dependent on outside temperature- do you want to use this all year round, or summer only? Just to give you a data point, my little place needs no heating for about nine months of the year. The fridge, hot water tank, and a bit of solar gain seem to be enough. I've got u values of between 0.1 and 0.15, with the windows at about 1.0.
Nickfromwales Posted Thursday at 14:56 Posted Thursday at 14:56 On 09/02/2026 at 12:48, ProDave said: With that level of insulation and such a small space, don't fit a WBS, you will melt the first time you light it. Yup. Just fit A2A (air con) for heating but also for cooling. You’ll need more cool than heat. 300mm of PIR is 150% passive!! Take a chill pill and we’ll guide you back on track
SteamyTea Posted Thursday at 15:54 Posted Thursday at 15:54 On 09/02/2026 at 17:08, Crofter said: We don't measure cars in mpg per ton of vehicle. We could tax them on it. Mine does 35 mpg/tonne (ish), my last car 37 mpg/tonne, but it was not so good. 60 MPG for a 1.6 tonne car as opposed to 62 MPG for a 1.8 tonne now. Many years ago, when I was studying automotive engineering, I read an article about this, seem to remember at the time (1982) that mass divided by 540 gave the gallons per mile. My passengers on Tuesday were most impressed that my car does 4 lt/100 km (they are used to that metric).
Adrian Walker Posted Thursday at 17:30 Posted Thursday at 17:30 On 09/02/2026 at 12:28, Waterworks said: Would it be possible to design a Shepards hut on a passive house principle ? This would be a pretty big maybe 3 x 6 metres internally , and clad in galvanised corrugated sheets. The design would take into account up to 300mm of PIR insulation, maybe vacuum panels in the front door and there would certainly a small wood stove. What would the design need to consider ? Crazy idea. And the stove is a no-no
Mr Punter Posted Friday at 10:53 Posted Friday at 10:53 17 hours ago, Adrian Walker said: Crazy idea. And the stove is a no-no +1. May as well heat it with the car exhaust!
Nickfromwales Posted Friday at 12:06 Posted Friday at 12:06 1 hour ago, Mr Punter said: +1. May as well heat it with the car exhaust! Apart for all the deaths, that’s a great idea A handful of solar PV panels, small UVC for hot water, and split AC for heating and cooling. Job done. ✔️. 1
saveasteading Posted Friday at 12:14 Posted Friday at 12:14 6 minutes ago, Nickfromwales said: Job done. And a very comfortable shepherd. Isn't the point of a shepherd's hut that it's a bit basic?
Nickfromwales Posted Friday at 12:25 Posted Friday at 12:25 10 minutes ago, saveasteading said: And a very comfortable shepherd. Isn't the point of a shepherd's hut that it's a bit basic? No minibar then??? 🫣
saveasteading Posted Friday at 12:28 Posted Friday at 12:28 A spare room for a poorly or favourite sheep? 1
Nickfromwales Posted Friday at 12:28 Posted Friday at 12:28 1 hour ago, saveasteading said: A spare room for a poorly or favourite sheep? You’re being racist to me now eh?
SteamyTea Posted Friday at 13:27 Posted Friday at 13:27 I was helping on my friend's farm. Had to get some sheep into a pen. One just refused to go in and just kept stepping backwards towards me. My farming friend said 'a good sheep will do that for you'. 1 1
Waterworks Posted 4 hours ago Author Posted 4 hours ago On 13/02/2026 at 12:06, Nickfromwales said: Apart for all the deaths, that’s a great idea A handful of solar PV panels, small UVC for hot water, and split AC for heating and cooling. Job done. ✔️. There will be no connection to mains electricity. The reason for the wood stove.
Waterworks Posted 4 hours ago Author Posted 4 hours ago On 12/02/2026 at 14:28, Crofter said: I would start by looking at all the background heat you expect to be generating in there- two humans, a fridge, some cooking. Then do a basic heat loss calculation based on notional insulation values and the surface area of the hut. This will be dependent on outside temperature- do you want to use this all year round, or summer only? Just to give you a data point, my little place needs no heating for about nine months of the year. The fridge, hot water tank, and a bit of solar gain seem to be enough. I've got u values of between 0.1 and 0.15, with the windows at about 1.0. What kind and thickness of insulation have you got ?
Waterworks Posted 3 hours ago Author Posted 3 hours ago To go an alternative route to this question , if you were designing an off grid metal clad sheperds hut for one person for all year round use that will use the minimum of heating fuel how would you insulate it ?
Nickfromwales Posted 3 hours ago Posted 3 hours ago 14 minutes ago, Waterworks said: There will be no connection to mains electricity. The reason for the wood stove. Who are the intended occupants, and what are they going to do in it? Bathroom in a room, rest of the space open plan?
