Would it be possible to design a Shepards hut on a passive house principle ?
This would be a pretty big maybe 3 x 6 metres internally , and clad in galvanised corrugated sheets.  The design would take into account up to 300mm of PIR insulation, maybe vacuum panels in the front door and there would certainly a small wood stove.
What would the design need to consider ?
Why that much?
Over thinking things.
You can use passivhaus principles for any build.
Main things are thermal bridges, continuous insulation, form factor, airtightness.
So you need to consider ventilation.
Of course. But any time you open the door most heat will shoot out so I can't see the point.
And the surface area compared to volume also provides a poor figure.
Spending a fortune on sustainability for a building that is far from sustainable through the material/carbon content doesn't make sense.
A shepherd would not do that.
PassivHaus is all about energy/m², rather than total energy. Which I think is wrong and drives up house sizes.
We don't measure cars in mpg per ton of vehicle.
Also, it's very difficult to meet PH standard in a small build because the volume: surface area ratio favours larger buildings. Another thing counting against a PH Shepherd's Hut is the exposed floor. You've got a very large surface area and a small volume inside it.
I came up against all of this on my own build, which is a 5*10m house on legs.
Exactly this.
https://passivehouseplus.ie/magazine/insight/the-small-passive-house-problem-a-solution
OK, passive house is not practical this small , so what would be the level of insulation required for the minimal heating fuel requirement in tne winter in the UK ?
Im asking based on the houseboat I currently live on which has 40 mm PIR insulation and is costing a fortune to heat , I want my Shepherds hut to use the minimum fuel possible and my design is built around insulation, however much is required.
I would start by looking at all the background heat you expect to be generating in there- two humans, a fridge, some cooking.
Then do a basic heat loss calculation based on notional insulation values and the surface area of the hut. This will be dependent on outside temperature- do you want to use this all year round, or summer only?
Just to give you a data point, my little place needs no heating for about nine months of the year. The fridge, hot water tank, and a bit of solar gain seem to be enough. I've got u values of between 0.1 and 0.15, with the windows at about 1.0.
On 09/02/2026 at 12:48, ProDave said:
With that level of insulation and such a small space, don't fit a WBS, you will melt the first time you light it.
Yup.
Just fit A2A (air con) for heating but also for cooling. You’ll need more cool than heat.
300mm of PIR is 150% passive!! Take a chill pill and we’ll guide you back on track ;) :)
We could tax them on it.
Mine does 35 mpg/tonne (ish), my last car 37 mpg/tonne, but it was not so good. 60 MPG for a 1.6 tonne car as opposed to 62 MPG for a 1.8 tonne now.
Many years ago, when I was studying automotive engineering, I read an article about this, seem to remember at the time (1982) that mass divided by 540 gave the gallons per mile.  My passengers on Tuesday were most impressed that my car does 4 lt/100 km (they are used to that metric).
Crazy idea. And the stove is a no-no
1 hour ago, Mr Punter said:
+1.  May as well heat it with the car exhaust!
Apart for all the deaths, that’s a great idea :D
A handful of solar PV panels, small UVC for hot water, and split AC for heating and cooling.
Job done. ✔️
6 minutes ago, Nickfromwales said:
Job done.
And a very comfortable shepherd.
Isn't the point of a shepherd's hut that it's a bit basic?
I was helping on my friend's farm.  Had to get some sheep into a pen.
One just refused to go in and just kept stepping backwards towards me.
My farming friend said 'a good sheep will do that for you'.
  • Sad 1
