Waterworks Posted 4 hours ago Posted 4 hours ago Would it be possible to design a Shepards hut on a passive house principle ? This would be a pretty big maybe 3 x 6 metres internally , and clad in galvanised corrugated sheets. The design would take into account up to 300mm of PIR insulation, maybe vacuum panels in the front door and there would certainly a small wood stove. What would the design need to consider ?
JohnMo Posted 3 hours ago Posted 3 hours ago 5 minutes ago, Waterworks said: 300mm of PIR insulation Why that much? 7 minutes ago, Waterworks said: vacuum panels in the front door Over thinking things. You can use passivhaus principles for any build. Main things are thermal bridges, continuous insulation, form factor, airtightness. So you need to consider ventilation.
ProDave Posted 3 hours ago Posted 3 hours ago With that level of insulation and such a small space, don't fit a WBS, you will melt the first time you light it.
saveasteading Posted 4 minutes ago Posted 4 minutes ago 2 hours ago, Waterworks said: Shepards hut on a passive house principle ? Of course. But any time you open the door most heat will shoot out so I can't see the point. And the surface area compared to volume also provides a poor figure. Spending a fortune on sustainability for a building that is far from sustainable through the material/carbon content doesn't make sense. A shepherd would not do that.
