Alan Ambrose Posted January 5 Posted January 5 I've been looking at these Geberit FlowFit Pre-Insulated pipes to use as supply pipes to the bathrooms running in a 50mm service cavity. Probably 20mm ID to bathroom and split locally to taps / bath / showers? (Kind of assuming there's nobody else in there when someone is taking a bath/shower). I've highlighted the ones that have max insulation but just fit in my service cavity. No need to insulate cold? Anyone have any thoughts? https://www.pipestock.com/geberit-flowfit-pre-insulated-system-pipe-blue-coils
JohnMo Posted January 5 Posted January 5 2 hours ago, Alan Ambrose said: Probably 20mm ID That's ok for cold, but you will waiting for ever for hot to arrive. I used a 15mm pipe from cylinder to a central manifold then 15mm to each wet room then split it to each outlet in the room. I would keep it simple just use Hep2O and add insulation if you have a secondary return system in place. Maybe some thin insulation if you feel you need it otherwise. 1
MortarThePoint Posted Friday at 08:27 Posted Friday at 08:27 The concern with uninsulated cold pipes is condensation forming on them. I think a 15mm pipe is something like a litre per 10m of run. A shower at 6L/min would clear 10m of pipe in 10s. I've even wondered about the benefits of a circulatory hot system Vs just filling the toilet cistern from the hot supply. The cistern fill would clear the pipe of the cold water before the basin tap get turned on. Insulating hot pipes for between uses is pointless in my mind. Others may have experience to the contrary though. Also, regs require it.
Big Jimbo Posted Friday at 08:37 Posted Friday at 08:37 9 minutes ago, MortarThePoint said: just filling the toilet cistern from the hot supply. The cistern fill would clear the pipe of the cold water before the basin tap get turned on. I like that idea.
sgt_woulds Posted Friday at 10:08 Posted Friday at 10:08 Also the toilet cistern becomes a heat source. But Legionnaires' might be an issue
Iceverge Posted Friday at 19:33 Posted Friday at 19:33 If you're set on crimp fittings and mlcp I'd run 12mm to everything hot except showers and baths and maybe the kitchen tap in a radial fashion. Colds can be Teed off within a room and 16mm. You shouldn't need 20mm pipes unless you have a gravity system. A hot fill for the cistern could easily dump 150l per day of DHW down the bowl for a family. It's be less wasteful to just run the tap while you used the toilet until its hot. However....just use Hep2O. Don't insulate anything apart from the hot at the cylinder, it's a waste of time. I have a thread about my woes somewhere.
MortarThePoint Posted 14 hours ago Posted 14 hours ago On 16/01/2026 at 19:33, Iceverge said: A hot fill for the cistern could easily dump 150l per day of DHW down the bowl for a family. Probably still less wasteful than whizzing hot water round a circulation system all day long
BadgerBodger Posted 14 hours ago Posted 14 hours ago Has anyone used one of the Grundfos recirc pumps with the autoadapt feature??? So it learns the house schedule and records at the tiles you’re most likely to call for hat water. Seems to be a happy compromise for generally having hot water when you want it and not circulating unnecessarily… pipes would need lagging still though.
Iceverge Posted 12 hours ago Posted 12 hours ago (edited) 2 hours ago, MortarThePoint said: Probably still less wasteful than whizzing hot water round a circulation system all day long Could do the sums on it....... 150l of DHW water heaters to say 50 deg is about 7kWh. 30m of 22mm looped pipe and a room temp of 20deg and a water temp of 50deg is a heat loss of 250w. Say you run it 24hrs a day and you get 6kWh. Put it on a timer or a PIR sensor and you'd probably half it. Of course you might have less flushes in the first place. Your mileage will vary. I reckon it's still nothing compared to running a 10mm pipe run radially from the UVC. Will do sums later ... Edited 12 hours ago by Iceverge
Andehh Posted 3 hours ago Posted 3 hours ago (edited) We have a very large recirculation, probably 100m? We're a bungalow with high ceilings, and fairly spread out layout. I thinks it's a 22mm circulation loop outbound, 15mm inbound, with very thick Armaflex pipe insulation wrapped all around it. 30 to 40mm thick maybe? I wanted high flow as much as possible. The circulation is on for about 14 hours of the day, but is timed to come on in the cheap night tariff when DHW comes on, so the whole loop warms up during cheap period. It drops a 49 degree 300L cylinder 3 degrees from DHW being turned off around 5.45 am, and me walking past it now 90 mins later. Some natural cylinder loss as well. I'd say that's totally worth it for what is otherwise a near 1 minute wait at the kitchen tap for hot water. Two core bathrooms on the circulation loop is within 10 inches if the tap.. Instant... The kitchen/other bathrooms is annoying as it's in the ceiling above it, so takes around 5 seconds (!) to get to the tap, I shoulda got them to loop it into the cupboard. Can't win them all!! Edited 3 hours ago by Andehh 1
BadgerBodger Posted 3 hours ago Posted 3 hours ago Yes, my thoughts were that we are a pretty habitual family and our DHW usage is pretty much confined to two distinct blocks of time 0500-0800 (showers and washing up) and 1700-2000 (baths, showers and washing up) with random intermittent use inbetween. I’m putting the tank right above the main cloakroom which will get the majority of the use during the day. But the longest run is likely to be 55m if I did it radially (one of the kids bedrooms) and when it’s bathtime it’s bathtime if you know what I mean. Reckon I’m pretty convinced that recirc is the most water efficient (we’re on a pumped treatment tank) and could well be the most energy efficient if well lagged AND suitable automation/control is installed.
Alan Ambrose Posted 3 hours ago Author Posted 3 hours ago Can I ask - does the recirc pump somehow not interfere with the mains pressure supply from the UVC?
BadgerBodger Posted 2 hours ago Posted 2 hours ago Someone smarter than me will have to answer that precisely. I haven’t researched the install that far yet. I’ll have a stab though and someone can correct me My logic says no. The cylinder is topped up with mains water via mains inlet (top if I recall last time a was meddling with one) and then the flow which becomes the pump feed exits bottom and the return would be another top entry. So as long as the cold water supply keeps up with the usage (there would be no interference with flow) only the usual dilution of heat caused by the cold water top-up this is roughly based on my current immersion set-up so it may differ with ASHP but again my logic says no.
Nickfromwales Posted just now Posted just now 3 hours ago, Alan Ambrose said: Can I ask - does the recirc pump somehow not interfere with the mains pressure supply from the UVC? No. The pipe running from the UVC / hot manifold is direct to the outlet. The HRC pump is on the return, at the UVC, so has no effect on the delivered lpm. Sizing the pipework is critical for differing distances from the plant / UVC, and working out which outlets are needed most frequently etc, so needs a bit of thought, but a good design will reap excellent results. As stated above, even taking the return off not immediate behind the outlet has significant penalties, and my thoughts are why the feck go to all this trouble, cost etc and still suffer any kind of compromises?
