January 3Jan 3 Need some help My next job is a hot tub, will be a round wooden one, heated by a heat pump. Looking to build an insulated base for it to sit on. Weight approx 2.4Te, diameter approx 1700mm. My initial thoughts were, dig down, DPM, PIR insulation 100-150mm thick covered in slabs (have loads to use up). But base will be square, hot tub round, heat will just move sideways out of the base and make the insulation useless. So not sure that works. Anyone any ideas?
January 3Jan 3 You'll lose so much heat out of the side and top that it isn't a great concern. But I agree with @crispy_wafer, and you could score the boards to threepenny-bit principle to nearly a circle. Have you checked the insulation strength? If it squashes it becomes useless.
January 3Jan 3 Why not build it just like an insulated house slab. I would use xps not pir, rough the surface up, flexible outdoor tile adhesives and tile the bit you can see.
January 3Jan 3 Author Thanks all So looks like XPS300 should be ok,compressive strength wise. But I may need to to cover it with something to load spread to stop any point loads. So maybe slabs?
January 3Jan 3 1 hour ago, JohnMo said: My next job is a hot tub Worked in the health and leisure industry and we called them bacterial breeders.
January 3Jan 3 Author 14 minutes ago, SteamyTea said: Worked in the health and leisure industry and we called them bacterial breeders. Going to add an automatic sanitizer to add chlorine (?) as needed, plus sand filter.
January 3Jan 3 4 hours ago, SteamyTea said: Worked in the health and leisure industry and we called them bacterial breeders. Or around here…”sex pond”.
