Couldn’t for the life of me get a piece of pipe to hold pressure yesterday, stripped all the fittings off, double checking the pressure tester…
now I know why 🤣, bugger!
  • Sad 1
Better than that, but no photos.
Drilling a 16mm hole through a thick stone wall for a cable.  When it broke through on the inside, I cut back a bit of the plasterboard, to find the drill bit had emerged through the wall between two 22mm copper pipes that nobody knew were there.  An inch either way and it would have been a wet problem to fix.
1 hour ago, marshian said:
Ouch what caused that - clearly not a dart?
Fixing some metal frame ceiling to the other side of the top of this stud wall.
 Nearly sorted, just connected to the shower valve now under test before I put the wall board back. thankfully plant room is next door so it was only 2m of pipe to pull/push
I bullseyed a copper pipe that was less that 5mm deep in the floor screed while fixing a footplate to close up a doorway after joining up shower/toilet separates.
Managed to do it at 9pm one night, all hell broke loose, including the stopcock handle breaking off when I tried to isolate.
One thing with renovations, if it can go wrong, it usually will at the worst time possible!
Good shot sir
Posted before but I suspected what I found when I carefully excavated. The previous owner had put a dinner gong directly above the light switch:
Sam_1402.thumb.jpg.3adee235c6e7da8e484eb59f434d7639.jpg.88cffd53228e961153b4e4676fcb3ef4.jpg
SAM_2727.thumb.jpg.8724499ea57b8d5b15a292bf039c30f2.jpg.2487598ca5af4fbcb62e7a7fac4681e7.jpg
SAM_2730.thumb.jpg.b30350a5a916d71adf1dd0273544c4e5.jpg.66a747e30e110d53a497a3bb44a4e035.jpg
  • Sad 1
^^^^  Ah yes safe zones.  Everybody know never to drill a hole in a safe zone without checking first.
Except the person hanging something on the wall, and then of course they measure meticulously to ensure the thing they are hanging exactly lines up with the centreline of the switch.
BULLSEYE
Is this New Year confession time.
I drilled though a wall to install a water pipe for a shower, long drill bit.
Went through the wall fine, and then into the 300lt cylinder that was the other side.
Measure twice, drill once.
A slightly different co-incidence.
Swapped out a dimmer switch for a light. Flipped the breaker, double checked circuit was powered off, swapped dimmer, powered it all up again.
No go. In fact after lengthy investigation it turned out all circuits on that entire phase were dead. What? Surely I couldn’t have taken out  the main fuse for that phase? How?
Much more investigation. Turns out that at exactly the same time I was swapping the dimmer, a likely lad had put his digger bucket through one of the phases of the underground LV line for the entire street.
Oh I like these new year confessions as it makes me feel less uniquely dumb.   No less dumb, mind, but less alone in my folly.
I think I’ve done the same damn stupid thing three times.  Carefully put catching bowl under sink trap.  Skilfully dismantled said trap with spilling a drop.  Then thoughtlessly dumped the nasty water from the catching bowl into the above sink.  Sigh.
  • Haha 4
Made me smile, remember similar, albeit I was sat down on the floor hands under the sink and the Mrs helpfully took and emptied said bowl full of mucky water and crud down the sink.  Lots of cursing involved, thankfully I wasn’t head first under the sink.  Still reckon she did it on purpose.
I can go one better (or worse depending on viewpoint)
Utility room sink waste was slow to drain - not unusual as Mrs Alien has a small tendency to slightly overdose on the washing powder so over a period of time it tends to clog up the drain so a strip down and clean out was required
Having learnt from previous occasions the last time I rebuilt the section I put a couple of strategic compression joints in what is mainly all solvent welds.
sections removed and then rodded/scraped/chiselled out and rinsed thro in the sink.
The plan was drop all the muck and water into a bucket under the sink……
Off course only a complete idiot would pull the plug out without having placed a bucket in the cupboard under the sink…….
oh how I laughed!!!!!
Using a multi cutter to channel out plasterboard, and went straight through a plastic water feed. Got a face full of water and a huge scramble dumping the sink cupboard across the floor getting to the stop cock!
Then a frantic drive to screwfix to buy everything to resolve before the wife came home.
