Couldn’t for the life of me get a piece of pipe to hold pressure yesterday, stripped all the fittings off, double checking the pressure tester…
now I know why 🤣, bugger!
  • Sad 1
Better than that, but no photos.
Drilling a 16mm hole through a thick stone wall for a cable.  When it broke through on the inside, I cut back a bit of the plasterboard, to find the drill bit had emerged through the wall between two 22mm copper pipes that nobody knew were there.  An inch either way and it would have been a wet problem to fix.
1 hour ago, marshian said:
Ouch what caused that - clearly not a dart?
Fixing some metal frame ceiling to the other side of the top of this stud wall.
 Nearly sorted, just connected to the shower valve now under test before I put the wall board back. thankfully plant room is next door so it was only 2m of pipe to pull/push
