flanagaj Posted 2 hours ago Posted 2 hours ago I looked out of our static caravan this morning to see the below 😞  can anyone advise.  We have a 7PE tank and it’s just my wife and I.  Â
markc Posted 1 hour ago Posted 1 hour ago I’m guessing detergent .. looks too white for anything else 1
Mr Punter Posted 1 hour ago Posted 1 hour ago Have you used washing up liquid? Maybe the air treatment has made it bubble up. 1
flanagaj Posted 1 hour ago Author Posted 1 hour ago 1 hour ago, Bonner said: What does it smell like? Smells fine. It's only been in operation two days.
Redbeard Posted 1 hour ago Posted 1 hour ago 19 minutes ago, Mr Punter said: Have you used washing up liquid? Maybe the air treatment has made it bubble up.  Looks very like it. Try to get rid of the bubbles that are there and do a 'controlled experiment' with significantly smaller amounts of detergent.Â
crooksey Posted 1 hour ago Posted 1 hour ago I only use Ecover products (and recommend the same to others) when using a PTP, on my last service the engineer said "I had to put my gloves back in the box, they were that clean". Â For anyone that states you can service yourself, yes you can very easily, but if you ever come to sell your house, having years of annual services will be worth its weight in gold.
JohnMo Posted 1 hour ago Posted 1 hour ago 1 minute ago, crooksey said: Ecover products Yes  And use these each month - stops smells from vent, their other products are quite good also https://www.muck-munchers.co.uk/ Â
